Trash Can 4.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use an ultrasonic sensor module, a digital servo motor, an I2C LCD, led, an active buzzer and an Arduino board to build a smart trash can.
When the ultrasonic sensor module detects trash being thrown in, the digital servo motor opens the lid of the trash can.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Ultrasonic Sensor Module |
7 |
LED |
8 |
Digital Servo Motor |
9 |
Active Buzzer |
10 |
I2C LCD 1602 |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 9 on the Arduino.
Trig: Connect to 5 on the Arduino.
Echo: Connect to 6 on the Arduino.
LED
Red LED: Connect the LEDs anode to a 1kΩ resistor then to the 3 on Arduino, and the LEDs cathode to negative power bus on the breadboard.
Green LED: Connect the LEDs anode to a 1kΩ resistor then to the 4 on Arduino, and the LEDs cathode to negative power bus on the breadboard.
Active Buzzer
+: Connect to 2 on the Arduino.
-: Connect to breadboard’s negative power bus.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
#include <Wire.h>
// LCD object: address, columns, rows
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Servo setup
Servo servo;
const int servoPin = 9;
const int openAngle = 0;
const int closeAngle = 90;
// Ultrasonic sensor pins
const int trigPin = 5;
const int echoPin = 6;
float currentDistance;
// Buzzer and LED pins
const int buzzerPin = 2;
const int redLedPin = 3;
const int greenLedPin = 4;
// Distance threshold to trigger the lid
const int distanceThreshold = 20;
// Lid timing
unsigned long lidOpenTime = 0;
const unsigned long holdOpenMs = 2000;
bool isLidOpen = false;
// Buzzer and red LED blinking timing
const unsigned long beepInterval = 200;
unsigned long lastBeepTime = 0;
bool beepState = false;
// Trash count
int trashCount = 0;
Serial.begin(9600);
// Set ultrasonic sensor pins
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
// Set buzzer and LED pins
pinMode(buzzerPin, OUTPUT);
pinMode(redLedPin, OUTPUT);
pinMode(greenLedPin, OUTPUT);
// Move the servo to the closed position
servo.attach(servoPin);
servo.write(closeAngle);
delay(100);
servo.detach();
// Default status: lid closed
digitalWrite(buzzerPin, LOW);
digitalWrite(redLedPin, LOW);
digitalWrite(greenLedPin, HIGH);
// Start the LCD
lcd.init();
lcd.backlight();
// Show the first count on the LCD
updateLCD();
// Read the current distance
currentDistance = readDistance();
// Open the lid when an object is close enough
if (!isLidOpen && currentDistance > 0 && currentDistance <= distanceThreshold) {
delay(1);
servo.write(openAngle);
isLidOpen = true;
lidOpenTime = millis();
// Count one trash drop
trashCount++;
updateLCD();
// Reset blink timing
lastBeepTime = millis();
beepState = false;
digitalWrite(greenLedPin, LOW);
// Run the open-lid effects
if (isLidOpen) {
unsigned long now = millis();
// Blink the red LED and buzzer
if (now - lastBeepTime >= beepInterval) {
lastBeepTime = now;
beepState = !beepState;
digitalWrite(buzzerPin, beepState ? HIGH : LOW);
digitalWrite(redLedPin, beepState ? HIGH : LOW);
// Close the lid after a short time
if (millis() - lidOpenTime >= holdOpenMs) {
delay(200);
servo.detach();
isLidOpen = false;
// Back to the default status
// Small delay for stable reading
delay(50);
// Update the number on the LCD
void updateLCD() {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Trash Count:");
lcd.setCursor(0, 1);
lcd.print(trashCount);
// Measure distance in centimeters
float readDistance() {
// Send a short pulse
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the echo time
unsigned long duration = pulseIn(echoPin, HIGH, 25000UL);
// Return -1 if no signal is received
if (duration == 0) return -1.0;
// Convert the echo time to distance
return duration / 58.0;
