Distance Display 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this project, we use an ultrasonic sensor and a strip of 8 NeoPixel LEDs to create a dynamic radar-style proximity visualization system.
The number of LEDs lit up depends on the distance to the nearest object—closer objects light up more LEDs.
When no object is detected nearby (all LEDs off), the system cycles through red, green, and blue color modes, adding a visual indicator of system status.
This setup creates an engaging, color-changing alert system for monitoring proximity using the Arduino board.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
LED Strip |
Ultrasonic Sensor Module |
Common Connections:
LED Strip
Din: Connect to 6 on the Arduino.
+5V: Connect to breadboard’s passive power bus.
Trig: Connect to 4 on the Arduino.
Echo: Connect to 3 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for FastLED and install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <FastLED.h> // Include FastLED library
#define NUM_LEDS 8 // Number of LEDs in the chain
#define DATA_PIN 6 // Data pin for LED control
// Define the pin numbers for the ultrasonic sensor
const int echoPin = 3;
const int trigPin = 4;
CRGB leds[NUM_LEDS]; // Array to hold LED color data
int currentLeds = 0; // Current number of LEDs lit
int colorState = 0; // Color state: 0 = Red, 1 = Green, 2 = Blue
bool colorChanged = false; // Flag to track if color has changed
pinMode(echoPin, INPUT); // Set echo pin as input
pinMode(trigPin, OUTPUT); // Set trig pin as output
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS); // Initialize LEDs
float distance = readDistance(); // Get the measured distance
int targetLeds = 0; // Target number of LEDs to light up
// Calculate the number of LEDs to light based on distance
if (distance <= 5) {
targetLeds = NUM_LEDS; // Light up all LEDs if distance is 5 cm or less
} else {
targetLeds = max(0, NUM_LEDS - (int)((distance - 5) / 1)); // Decrease LEDs based on distance
// Smoothly transition the current LEDs towards the target LEDs
if (currentLeds < targetLeds) {
currentLeds++; // Increment current LEDs
} else if (currentLeds > targetLeds) {
currentLeds--; // Decrement current LEDs
// Change color when all LEDs are off
if (currentLeds == 0 && !colorChanged) {
colorState = (colorState + 1) % 3; // Cycle through Red, Green, Blue
colorChanged = true; // Set the color change flag
} else if (currentLeds > 0) {
colorChanged = false; // Reset the flag when LEDs are on
// Loop through each LED and set its state based on the current color
for (int i = 0; i < NUM_LEDS; i++) {
if (i < currentLeds) {
// Set the color based on the color state
if (colorState == 0) {
leds[i] = CRGB::Red; // All red
} else if (colorState == 1) {
leds[i] = CRGB::Green; // All green
} else {
leds[i] = CRGB::Blue; // All blue
} else {
leds[i] = CRGB::Black; // Turn off LED if not in range
FastLED.show(); // Update LED strip
delay(75); // Short delay for smooth transition
// Function to read the sensor data and calculate the distance
float readDistance() {
digitalWrite(trigPin, LOW); // Set trig pin to low
delayMicroseconds(2); // Wait for 2 microseconds
digitalWrite(trigPin, HIGH); // Trigger the sensor
delayMicroseconds(10); // Send a 10 microsecond pulse
digitalWrite(trigPin, LOW); // Set trig pin back to low
// Measure the pulse width of the echo pin and calculate distance
return pulseIn(echoPin, HIGH) / 58.0; // Convert time to distance in cm
