Heart rate monitor 2.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project builds a basic Heart Rate Monitor using the MAX30102 sensor and a 16x2 I2C LCD.
It detects heartbeats by analyzing infrared signals and calculates the heart rate in BPM.
The measured BPM is displayed on the LCD. A buzzer beeps with each beat, and an RGB LED indicates heart rate level—red for high, green for normal.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
I2C LCD 1602
Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
RGB LED
Passive buzzer
../_images/heart_rate_monitor2.0_bb.png
Common Connections:
  • Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
    • VIN: Connect to breadboard’s red power bus.
  • I2C LCD 1602
  • RGB LED
    • R: Connect to 6 on the Arduino.
    • G: Connect to 5 on the Arduino.
  • Passive Buzzer
    • +: Connect to 9 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C , MAX30105 and heartRate and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include "MAX30105.h"
#include "heartRate.h"
#define BUZZER_PIN 9
#define RED_PIN 6      // Red pin of RGB LED
#define GREEN_PIN 5    // Green pin of RGB LED
MAX30105 particleSensor;
LiquidCrystal_I2C lcd(0x27, 16, 2);
int bpm = 0;
unsigned long lastDisplayTime = 0;
  Serial.begin(9600);
  pinMode(BUZZER_PIN, OUTPUT);
  pinMode(RED_PIN, OUTPUT);
  pinMode(GREEN_PIN, OUTPUT);
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("Initializing...");
  if (!particleSensor.begin(Wire, I2C_SPEED_STANDARD)) {
    Serial.println("MAX30102 not found");
    lcd.setCursor(0, 1);
    lcd.print("Sensor Error");
    while (1);
  particleSensor.setup(); // Default configuration
  particleSensor.setPulseAmplitudeRed(0x0A);  // Red light for heart rate
  particleSensor.setPulseAmplitudeGreen(0);   // Turn off green light
  lcd.clear();
  lcd.print("Heart Monitor");
  const int NUM_READINGS = 100;
  long irValue;
  static uint32_t lastBeat = 0;
  for (int i = 0; i < NUM_READINGS; i++) {
    irValue = particleSensor.getIR();
    if (checkForBeat(irValue)) {
      uint32_t now = millis();
      int delta = now - lastBeat;
      lastBeat = now;
      bpm = 60000 / delta;
      Serial.print("BPM: ");
      Serial.println(bpm);
      lcd.print("BPM: ");
      lcd.print(bpm);
      lcd.print("   ");
      // Control RGB LED: light red or green
      if (bpm > 100) {
        digitalWrite(RED_PIN, HIGH);
        digitalWrite(GREEN_PIN, LOW);
      } else {
        digitalWrite(RED_PIN, LOW);
        digitalWrite(GREEN_PIN, HIGH);
      // Beep once per heartbeat
      tone(BUZZER_PIN, 1000, 50); // 1kHz, 50ms
    delay(10); // Sampling rate
