Color Memory
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll use four LCDs, four buttons, and a passive buzzer with the Arduino R4 UNO to create a color memory game.
At the start of the game, an LED lights up at random. The player must press the corresponding button to proceed. A wrong input ends the game.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Passive Buzzer |
Button |
7 |
LED |
8 |
220Ω resistor |
Common Connections:
LEDS
Blue: Connect the LED anode to 8 on the Arduino, and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
Green: Connect the LED anode to 6 on the Arduino, and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
Yellow: Connect the LED anode to 4**on the Arduino , and the **cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
Red: Connect the LED anode to 2 on the Arduino, and the cathode to a 220Ω resistor, then to the negative power bus on the breadboard.
Passive Buzzer
+: Connect to 12 on the Arduino.
-: Connect to breadboard’s negative power bus.
Buttons
Blue Button: Connect to the Blue LED’s cathode on the breadboard, and the other end to 9 on the Arduino board.
Green Button: Connect to the Green LED’s cathode on the breadboard, and the other end to 7 on the Arduino board.
Yellow Button: Connect to the Yellow LED’s cathode on the breadboard, and the other end to 5 on the Arduino board.
Red Button: Connect to the Red LED’s cathode on the breadboard, and the other end to 3 on the Arduino board.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// LED and button pin definitions
const int redLED = 2;
const int yellowLED = 4;
const int greenLED = 6;
const int blueLED = 8;
const int redButton = 3;
const int yellowButton = 5;
const int greenButton = 7;
const int blueButton = 9;
const int buzzer = 12;
int sequence[100]; // Store the random sequence
int playerInput[100]; // Store the player's input sequence
int level = 0; // Current game level
bool gameOver = false; // Flag to check if the game is over
// Initialize pin modes
pinMode(redLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(blueLED, OUTPUT);
pinMode(redButton, INPUT_PULLUP);
pinMode(yellowButton, INPUT_PULLUP);
pinMode(greenButton, INPUT_PULLUP);
pinMode(blueButton, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
Serial.begin(9600); // Debugging purpose
// Start the game
startGame();
if (!gameOver) {
// Play the current color sequence
playSequence();
// Check player's input
if (!getPlayerInput()) {
endGame();
} else {
delay(500); // Shorten delay after player input
} else {
// Restart the game after a short delay
delay(1500); // Shorten restart delay
startGame();
void startGame() {
// Initialize game state
level = 1;
gameOver = false;
// Turn on all LEDs and play a sound to indicate game start
digitalWrite(redLED, HIGH);
digitalWrite(yellowLED, HIGH);
digitalWrite(greenLED, HIGH);
digitalWrite(blueLED, HIGH);
tone(buzzer, 1000, 500);
delay(500); // Shorten the LED on time at the start
// Turn off all LEDs
digitalWrite(redLED, LOW);
digitalWrite(yellowLED, LOW);
digitalWrite(greenLED, LOW);
digitalWrite(blueLED, LOW);
randomSeed(analogRead(A0)); // Use analog pin to generate a random seed
delay(500); // Shortened delay before game starts
void playSequence() {
// Generate a random LED sequence, ensure the number corresponds to a valid LED
sequence[level - 1] = random(1, 5); // Generate random value between 1 and 4 for colors
// Play the current LED and sound sequence
for (int i = 0; i < level; i++) {
lightUpLED(sequence[i]);
delay(300); // Shortened delay between each sequence
bool getPlayerInput() {
bool inputReceived = false;
while (!inputReceived) {
if (digitalRead(redButton) == LOW) {
playerInput[i] = 1; // Red button pressed
lightUpLED(1); // Light up corresponding LED and play sound
inputReceived = true;
} else if (digitalRead(yellowButton) == LOW) {
playerInput[i] = 2; // Yellow button pressed
lightUpLED(2); // Light up corresponding LED and play sound
} else if (digitalRead(greenButton) == LOW) {
playerInput[i] = 3; // Green button pressed
lightUpLED(3); // Light up corresponding LED and play sound
} else if (digitalRead(blueButton) == LOW) {
playerInput[i] = 4; // Blue button pressed
lightUpLED(4); // Light up corresponding LED and play sound
// Check if player input matches the sequence
if (playerInput[i] != sequence[i]) {
return false; // Player input is incorrect
delay(200); // Shorten delay after player input confirmation
level++; // Increase level after correct input
return true;
void endGame() {
gameOver = true; // Set game over flag
// Flash LEDs and play sound to indicate the game is over
for (int i = 0; i < 5; i++) {
tone(buzzer, 1000, 300); // Quick sound for game over
delay(200); // Faster flashing
delay(200);
void lightUpLED(int color) {
// Light up the corresponding LED and play a sound based on the color
switch (color) {
case 1: // Red
tone(buzzer, 500, 300);
break;
case 2: // Yellow
tone(buzzer, 600, 300);
break;
case 3: // Green
tone(buzzer, 700, 300);
break;
case 4: // Blue
tone(buzzer, 800, 300);
break;
delay(300); // Shorten LED on time
