Trash Can
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use an ultrasonic sensor module, a digital servo motor, and an Arduino board to build a smart trash can.
When the ultrasonic sensor module detects trash being thrown in, the digital servo motor opens the lid of the trash can.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Ultrasonic Sensor Module |
7 |
LED |
8 |
Digital Servo Motor |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 9 on the Arduino.
Trig: Connect to 6 on the Arduino.
Echo: Connect to 5 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
// Set up the servo motor parameters
Servo servo;
const int servoPin = 9;
const int openAngle = 0;
const int closeAngle = 90;
// Set up the ultrasonic sensor parameters
const int trigPin = 5;
const int echoPin = 6;
long distance, averageDistance;
long averDist[3];
// Distance threshold in centimeters
const int distanceThreshold = 20;
// Initialize serial communication with the computer at 9600 baud rate
Serial.begin(9600);
// Configure the trigger and echo pins of the ultrasonic sensor
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
// Attach the servo to its control pin and set its initial position
servo.attach(servoPin);
servo.write(closeAngle);
delay(100);
servo.detach(); // Detach the servo to save power when not in use
// Measure the distance three times
for (int i = 0; i <= 2; i++) {
distance = readDistance();
averDist[i] = distance;
delay(10);
// Calculate the average distance
averageDistance = (averDist[0] + averDist[1] + averDist[2]) / 3;
Serial.println(averageDistance);
// Control the servo based on the averaged distance
if (averageDistance <= distanceThreshold) {
servo.attach(servoPin); // Reattach the servo before sending a command
delay(1);
servo.write(openAngle); // Rotate the servo to the open position
delay(3500);
} else {
servo.write(closeAngle); // Rotate the servo back to the closed position
delay(1000);
// Function to read the sensor data and calculate the distance
float readDistance() {
// Send a pulse on the trigger pin of the ultrasonic sensor
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Measure the pulse width of the echo pin and calculate the distance value
float distance = pulseIn(echoPin, HIGH) / 58.00; // Formula: (340m/s * 1us) / 2
return distance;
