Heart rate monitor
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project aims to build a simple Heart Rate Monitor using a MAX30102 pulse oximeter sensor and an SSD1306 OLED Display. The code takes measurements of the heart rate by determining the time between heartbeats. By taking four measurements, it computes their average and presents the resultant average heart rate on an OLED screen. If the sensor doesn’t detect a finger, it sends a prompt to the user to position their finger correctly on the sensor.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
OLED Display Module
Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
../_images/Heart_rate_monitor_bb.png
Common Connections:
  • Pulse Oximeter and Heart Rate Sensor Module (MAX30102)
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
    • VIN: Connect to breadboard’s red power bus.
  • OLED Display Module
    • SCK: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 , Adafruit GFX , MAX30105 and heartRate and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#ifdef LED_RED
#undef LED_RED  // Prevent conflict with MAX30105 enum
#endif
#include <Adafruit_GFX.h>       // Graphics support for OLED
#include <Adafruit_SSD1306.h>   // OLED screen library
#include <Wire.h>               // I2C communication
#include "MAX30105.h"           // Sensor library
#include "heartRate.h"          // Heartbeat detection algorithm
// OLED screen setup
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SCREEN_ADDRESS 0x3C     // I2C address for most 0.96" OLEDs
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// Heart rate variables
MAX30105 particleSensor;
const byte RATE_SIZE = 4;       // Number of readings to average
byte rates[RATE_SIZE];          // Store recent BPM values
byte rateSpot = 0;
long lastBeat = 0;              // Time of the last detected beat
float beatsPerMinute;
int beatAvg = 0;                // Averaged BPM
// Heart icon (small)
static const unsigned char PROGMEM beat1_bmp[] = {
  // 24x21 bitmap data
  0x03, 0xC0, 0xF0, 0x06, 0x71, 0x8C, 0x0C, 0x1B, 0x06, 0x18, 0x0E, 0x02, 0x10, 0x0C, 0x03, 0x10,
  0x04, 0x01, 0x10, 0x04, 0x01, 0x10, 0x40, 0x01, 0x10, 0x40, 0x01, 0x10, 0xC0, 0x03, 0x08, 0x88,
  0x02, 0x08, 0xB8, 0x04, 0xFF, 0x37, 0x08, 0x01, 0x30, 0x18, 0x01, 0x90, 0x30, 0x00, 0xC0, 0x60,
  0x00, 0x60, 0xC0, 0x00, 0x31, 0x80, 0x00, 0x1B, 0x00, 0x00, 0x0E, 0x00, 0x00, 0x04, 0x00
// Heart icon (large)
static const unsigned char PROGMEM beat2_bmp[] = {
  // 32x32 bitmap data
  0x01, 0xF0, 0x0F, 0x80, 0x06, 0x1C, 0x38, 0x60, 0x18, 0x06, 0x60, 0x18, 0x10, 0x01, 0x80, 0x08,
  0x20, 0x01, 0x80, 0x04, 0x40, 0x00, 0x00, 0x02, 0x40, 0x00, 0x00, 0x02, 0xC0, 0x00, 0x08, 0x03,
  0x80, 0x00, 0x08, 0x01, 0x80, 0x00, 0x18, 0x01, 0x80, 0x00, 0x1C, 0x01, 0x80, 0x00, 0x14, 0x00,
  0x80, 0x00, 0x14, 0x00, 0x80, 0x00, 0x14, 0x00, 0x40, 0x10, 0x12, 0x00, 0x40, 0x10, 0x12, 0x00,
  0x7E, 0x1F, 0x23, 0xFE, 0x03, 0x31, 0xA0, 0x04, 0x01, 0xA0, 0xA0, 0x0C, 0x00, 0xA0, 0xA0, 0x08,
  0x00, 0x60, 0xE0, 0x10, 0x00, 0x20, 0x60, 0x20, 0x06, 0x00, 0x40, 0x60, 0x03, 0x00, 0x40, 0xC0,
  0x01, 0x80, 0x01, 0x80, 0x00, 0xC0, 0x03, 0x00, 0x00, 0x60, 0x06, 0x00, 0x00, 0x30, 0x0C, 0x00,
  0x00, 0x08, 0x10, 0x00, 0x00, 0x06, 0x60, 0x00, 0x00, 0x03, 0xC0, 0x00, 0x00, 0x01, 0x80, 0x00
  Wire.setClock(400000);            // Use fast I2C speed (400kHz)
  Serial.begin(9600);               // Serial monitor for debugging
  // Start OLED display
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println("OLED not found");
    while (true);                   // Stop if display is not found
  display.display();
  // Start MAX30102 sensor
  if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) {
    Serial.println("MAX30102 not found");
    while (true);                   // Stop if sensor is not found
  // Sensor configuration
  particleSensor.setup();                 // Use default settings
  particleSensor.setPulseAmplitudeRed(0x0A);  // Low red LED pulse
  particleSensor.setPulseAmplitudeGreen(0);   // Disable green LED
  Serial.println("Place your finger on the sensor.");
  long irValue = particleSensor.getIR();  // Get infrared value
  // Check if finger is detected
  if (irValue > 50000) {
    // Detect heartbeat
    if (checkForBeat(irValue)) {
      // Display small heart and current average BPM
      display.clearDisplay();
      display.drawBitmap(23, 15, beat1_bmp, 24, 21, WHITE);
      display.setTextSize(2);
      display.setTextColor(WHITE);
      display.setCursor(60, 10);
      display.println("BPM");
      display.setCursor(60, 28);
      display.println(beatAvg);
      display.display();
      // Calculate BPM based on time between beats
      long delta = millis() - lastBeat;
      lastBeat = millis();
      beatsPerMinute = 60 / (delta / 1000.0);
      // Keep only valid readings
      if (beatsPerMinute < 255 && beatsPerMinute > 20) {
        rates[rateSpot++] = (byte)beatsPerMinute;
        rateSpot %= RATE_SIZE;
        // Average the last few readings
        beatAvg = 0;
        for (byte x = 0; x < RATE_SIZE; x++) {
          beatAvg += rates[x];
        beatAvg /= RATE_SIZE;
        delay(100);  // Small delay before drawing again
        // Display large heart and updated BPM
        display.drawBitmap(18, 10, beat2_bmp, 32, 32, WHITE);
        display.display();
      // Print info to Serial Monitor
      Serial.print("IR=");
      Serial.print(irValue);
      Serial.print(", BPM=");
      Serial.print(beatsPerMinute);
      Serial.print(", Avg BPM=");
      Serial.println(beatAvg);
  } else {
    // Finger not detected - show message
    Serial.println("Place your finger on the sensor");
    display.setTextSize(1);
    display.setCursor(30, 5);
    display.println("Please place ");
    display.setCursor(30, 15);
    display.println("your finger ");
    display.setCursor(30, 25);
    display.println("and wait... ");
    display.display();
