Emergency Response
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you will learn how to use an Arduino UNO R4 WiFi with six LEDs, a button, and a passive buzzer to create a police light and siren simulator.
Press the button to start the effect. The red and blue LEDs will flash alternately while the buzzer produces a sweeping police siren sound. Press the button again to stop the lights and siren.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
220 resistor
Several
Button
LED
Several
Passive Buzzer
../_images/emergency_response_bb.png
Common Connections:
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to a 220Ω resistor then to 2 to 7 on the Arduino.
  • Button
    • Connect to breadboard’s negative power bus.
    • Connect to 10 on the Arduino.
  • Passive Buzzer
    • +: Connect to 9 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
  Police Light and Siren Project
  Board: Arduino UNO R4 WiFi
  Components:
  - 3 red LEDs
  - 3 blue LEDs
  - 1 passive buzzer
  - 1 push button
  Operation:
  - Press the button once to start the lights and siren.
  - Press it again to stop everything.
// ==================== Pin settings ====================
// Red LEDs
const byte RED_LED_1_PIN = 2;
const byte RED_LED_2_PIN = 3;
const byte RED_LED_3_PIN = 4;
// Blue LEDs
const byte BLUE_LED_1_PIN = 5;
const byte BLUE_LED_2_PIN = 6;
const byte BLUE_LED_3_PIN = 7;
// Passive buzzer
const byte BUZZER_PIN = 9;
// Button
const byte BUTTON_PIN = 10;
// ==================== Timing settings ====================
// Time between red and blue light changes
const unsigned long LIGHT_INTERVAL = 180;
// Button debounce time
const unsigned long DEBOUNCE_DELAY = 40;
// Siren frequency update interval
const unsigned long SIREN_INTERVAL = 8;
// Siren frequency range
const int MIN_SIREN_FREQUENCY = 650;
const int MAX_SIREN_FREQUENCY = 1300;
// Amount the frequency changes each step
const int SIREN_STEP = 10;
// ==================== State variables ====================
// True when the police effect is running
bool policeEffectRunning = false;
// Current light state
bool redLightsOn = true;
// Light timing
unsigned long lastLightUpdate = 0;
// Siren timing
unsigned long lastSirenUpdate = 0;
// Current siren frequency
int sirenFrequency = MIN_SIREN_FREQUENCY;
// 1 means rising pitch, -1 means falling pitch
int sirenDirection = 1;
// ==================== Button variables ====================
bool lastButtonReading = HIGH;
bool stableButtonState = HIGH;
unsigned long lastDebounceTime = 0;
// ==================== Setup ====================
  // Configure LED pins
  pinMode(RED_LED_1_PIN, OUTPUT);
  pinMode(RED_LED_2_PIN, OUTPUT);
  pinMode(RED_LED_3_PIN, OUTPUT);
  pinMode(BLUE_LED_1_PIN, OUTPUT);
  pinMode(BLUE_LED_2_PIN, OUTPUT);
  pinMode(BLUE_LED_3_PIN, OUTPUT);
  // Configure buzzer
  pinMode(BUZZER_PIN, OUTPUT);
  // Use the Arduino internal pull-up resistor
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  // Start with everything turned off
  stopPoliceEffect();
// ==================== Main loop ====================
  handleButton();
  if (policeEffectRunning) {
    updatePoliceLights();
    updateSiren();
// ==================== Button handling ====================
void handleButton() {
  bool currentReading = digitalRead(BUTTON_PIN);
  // Restart the debounce timer when the reading changes
  if (currentReading != lastButtonReading) {
    lastDebounceTime = millis();
  // Accept the reading after it remains stable
  if (
    millis() - lastDebounceTime >= DEBOUNCE_DELAY
    if (currentReading != stableButtonState) {
      stableButtonState = currentReading;
      // INPUT_PULLUP means LOW is pressed
      if (stableButtonState == LOW) {
        policeEffectRunning = !policeEffectRunning;
          startPoliceEffect();
        } else {
          stopPoliceEffect();
  lastButtonReading = currentReading;
// ==================== Effect control ====================
void startPoliceEffect() {
  policeEffectRunning = true;
  redLightsOn = true;
  sirenDirection = 1;
  lastLightUpdate = millis();
  lastSirenUpdate = millis();
  // Start with red LEDs on
  setRedLights(true);
  setBlueLights(false);
  tone(BUZZER_PIN, sirenFrequency);
void stopPoliceEffect() {
  setRedLights(false);
  noTone(BUZZER_PIN);
// ==================== LED functions ====================
void updatePoliceLights() {
  unsigned long currentTime = millis();
  if (
    currentTime - lastLightUpdate >=
    LIGHT_INTERVAL
    lastLightUpdate = currentTime;
    redLightsOn = !redLightsOn;
    setRedLights(redLightsOn);
    setBlueLights(!redLightsOn);
void setRedLights(bool state) {
  digitalWrite(
    RED_LED_1_PIN,
    state ? HIGH : LOW
  digitalWrite(
    RED_LED_2_PIN,
    state ? HIGH : LOW
  digitalWrite(
    RED_LED_3_PIN,
    state ? HIGH : LOW
void setBlueLights(bool state) {
  digitalWrite(
    BLUE_LED_1_PIN,
    state ? HIGH : LOW
  digitalWrite(
    BLUE_LED_2_PIN,
    state ? HIGH : LOW
  digitalWrite(
    BLUE_LED_3_PIN,
    state ? HIGH : LOW
// ==================== Siren function ====================
void updateSiren() {
  if (
    currentTime - lastSirenUpdate >=
    SIREN_INTERVAL
    lastSirenUpdate = currentTime;
    // Increase or decrease the siren pitch
    sirenFrequency +=
      SIREN_STEP * sirenDirection;
    // Reverse direction at the upper limit
    if (
      sirenFrequency >=
      MAX_SIREN_FREQUENCY
      sirenFrequency =
        MAX_SIREN_FREQUENCY;
      sirenDirection = -1;
    // Reverse direction at the lower limit
    if (
      sirenFrequency <=
      MIN_SIREN_FREQUENCY
      sirenFrequency =
      sirenDirection = 1;
    tone(
      BUZZER_PIN,
      sirenFrequency
