Detect Fall
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use the MPU6050 sensor with the Arduino to build a simple tilt detection system.
When the device is tilted beyond a set threshold, an LED lights up and a buzzer sounds, providing a quick visual and audio alert.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
220Ω resistor |
LED |
7 |
MPU6050 Module |
8 |
Active Buzzer |
Common Connections:
LED
Connect the LED anode to a 1kΩ resistor then to the negative power bus on the breadboard, and the LED cathode to 8 on the Arduino.
MPU6050
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Active Buzzer
Connect to 9 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for MPU6050 and install it.
Don’t forget to select the board(Arduino UNO R3) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
const int LED_PIN = 8;
const int BUZZER_PIN = 9;
// Threshold angle (adjustable)
const float TILT_THRESHOLD = 45.0;
Serial.begin(9600);
Wire.begin();
mpu.initialize();
if (!mpu.testConnection()) {
Serial.println("MPU6050 connection failed!");
while (1);
pinMode(LED_PIN, OUTPUT);
pinMode(BUZZER_PIN, OUTPUT);
Serial.println("Tilt detection system ready!");
// Get acceleration data
int16_t ax, ay, az;
mpu.getAcceleration(&ax, &ay, &az);
// Convert acceleration to angles (simple approximation)
float angleX = atan2(ay, az) * 180 / PI;
float angleY = atan2(ax, az) * 180 / PI;
Serial.print("AngleX: "); Serial.print(angleX);
Serial.print(" AngleY: "); Serial.println(angleY);
// Check tilt
if (abs(angleX) > TILT_THRESHOLD || abs(angleY) > TILT_THRESHOLD) {
digitalWrite(LED_PIN, HIGH);
digitalWrite(BUZZER_PIN, HIGH);
} else {
digitalWrite(LED_PIN, LOW);
digitalWrite(BUZZER_PIN, LOW);
delay(200);
