Parking Sensor
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Electronic Kit
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to create a parking sensor system using the Ultrasonic Sensor Module and MAX7219 Dot Matrix Module.
As an obstacle gets closer to the sensor, the distance will be displayed on the dot matrix module.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
../_images/Parking_Sensor_bb.png
Common Connections:
  • MAX7219 Dot Matrix Module
    • CLK: Connect to 11 on the Arduino.
    • CS: Connect to 10 on the Arduino.
    • DIN: Connect to 12 on the Arduino.
  • Ultrasonic Sensor Module
    • Trig: Connect to 4 on the Arduino.
    • Echo: Connect to 3 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LedControl install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include "LedControl.h"
// Initialize the LedControl object for 4 connected modules
LedControl lc = LedControl(12, 11, 10, 4);
// Define pins for ultrasonic sensor
const int echoPin = 3; // Echo pin for the ultrasonic sensor
const int trigPin = 4; // Trigger pin for the ultrasonic sensor
// 8x8 dot matrix representations of numbers 0-9
byte numbers[10][8] = {
    {0x3C, 0x42, 0x42, 0x42, 0x42, 0x42, 0x42, 0x3C}, // 0
    {0x08, 0x18, 0x38, 0x08, 0x08, 0x08, 0x08, 0x7E}, // 1
    {0x3C, 0x42, 0x40, 0x20, 0x10, 0x08, 0x04, 0x7E}, // 2
    {0x3C, 0x42, 0x40, 0x30, 0x40, 0x40, 0x42, 0x3C}, // 3
    {0x20, 0x30, 0x28, 0x24, 0x7E, 0x20, 0x20, 0x20}, // 4
    {0x7E, 0x02, 0x1E, 0x20, 0x40, 0x40, 0x42, 0x3C}, // 5
    {0x3C, 0x02, 0x02, 0x1E, 0x22, 0x42, 0x42, 0x3C}, // 6
    {0x7E, 0x40, 0x20, 0x10, 0x08, 0x08, 0x08, 0x08}, // 7
    {0x3C, 0x42, 0x42, 0x3C, 0x42, 0x42, 0x42, 0x3C}, // 8
    {0x3C, 0x42, 0x42, 0x3C, 0x40, 0x40, 0x40, 0x3C}  // 9
unsigned long lastMeasurementTime = 0;
const int measurementInterval = 400; // Interval for distance measurements
const int animationInterval = 40; // Refresh interval for animations
unsigned long lastAnimationTime = 0;
int targetColumnsLit = 0;
int currentCol = 0;
  Serial.begin(9600);
  pinMode(echoPin, INPUT);
  pinMode(trigPin, OUTPUT);
  // Initialize all LED modules
  for (int i = 0; i < 4; i++) {
    lc.shutdown(i, false);
    lc.setIntensity(i, 8);
    lc.clearDisplay(i);
  // Measure distance
  if (millis() - lastMeasurementTime >= measurementInterval) {
    lastMeasurementTime = millis();
    float distance = readDistance();
    Serial.print("Distance: ");
    Serial.print(distance);
    Serial.println(" cm");
    // Update the displayed number based on the measured distance
    int displayValue = constrain((int)distance, 0, 99);
    displayNumber(displayValue);
    // Update the target number of columns to light up based on distance
    targetColumnsLit = calculateColumnsToLight(distance);
  // Update the animation display
  updateAnimation();
float readDistance() {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(echoPin, HIGH) / 58.00;
  return distance > 400 ? 400 : distance; // Limit max measurement distance
void displayNumber(int number) {
  lc.clearDisplay(2); // Clear display module 2
  lc.clearDisplay(3); // Clear display module 3
  if (number < 10) {
    displayDigit(2, number); // Display a single digit on module 3
  } else {
    displayDigit(2, number % 10); // Unit digit on module 2
    displayDigit(3, number / 10); // Tens digit on module 3
void displayDigit(int module, int digit) {
  for (int row = 0; row < 8; row++) {
    byte reversed = needsMirror(digit) ? reverseByte(numbers[digit][row]) : numbers[digit][row];
    lc.setRow(module, row, reversed);
bool needsMirror(int digit) {
  return (digit == 2 || digit == 3 || digit == 4 || digit == 5 || digit == 6 || digit == 7 || digit == 9);
byte reverseByte(byte b) {
  b = (b & 0xF0) >> 4 | (b & 0x0F) << 4;
  b = (b & 0xCC) >> 2 | (b & 0x33) << 2;
  b = (b & 0xAA) >> 1 | (b & 0x55) << 1;
  return b;
int calculateColumnsToLight(float distance) {
  return constrain(map(distance, 21, 0, 0, 18), 0, 16);
void updateAnimation() {
  if (millis() - lastAnimationTime >= animationInterval) {
    lastAnimationTime = millis();
    if (currentCol < targetColumnsLit) {
      lightUpColumn(currentCol, true);
      currentCol++;
    } else if (currentCol > targetColumnsLit) {
      currentCol--;
      lightUpColumn(currentCol, false);
void lightUpColumn(int col, bool state) {
  int matrixIndex = 1 - (col / 8);
  int colIndex = col % 8;
  for (int row = 0; row < (col / 2) + 1; row++) {
    lc.setLed(matrixIndex, 7 - row, colIndex, state);
