Mini Fan 2.0
👉 Need faster updates or support? Click [here] join our Facebook community
👉 Or join our WhatsApp group: Click [here]
🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
Universal Maker Sensor Kit |
3 in 1 Ultimate Starter Kit |
Arduino Uno R3 |
Course Introduction
This Arduino project controls a DC motor using a TA6586 motor driver and four push buttons. The system uses PWM control to adjust speed and responds immediately to button input.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Cable |
Breadboard |
Wires |
Several |
DC Motor |
TA6586 - Motor Driver Chip |
7 |
Button |
7 |
Button |
Common Connections:
BI: Connect to 6 on the Arduino.
FI: Connect to 5 on the Arduino.
DC Motor
GND: Connect to TA6586 B0.
VCC: Connect to TA6586 F0.
Button1
Connect to 9 on the Arduino.
Button2
Connect to 10 on the Arduino.
Button3
Connect to 11 on the Arduino.
Button4
Connect to 12 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4) and the correct port before clicking the Upload button.
#include <Servo.h>
// ===== Motor Control =====
const int fiPin = 5;
const int biPin = 6;
const int blueBtn = 9;
const int yellowBtn = 10;
const int redBtn = 11;
// ===== Servo Control =====
Servo servo;
const int servoPin = 3;
const int greenBtn = 12;
// ===== Variables =====
int fanSpeed = 0; // 0=off, 128=half, 255=full
int angle = 90; // Start centered
int direction = 1; // 1=right, -1=left
bool servoActive = false; // Whether oscillation is active
bool lastBtnState = HIGH; // For toggle detection
// ===== Servo Limits =====
const int leftLimit = 45;
const int rightLimit = 135;
// Motor setup
pinMode(fiPin, OUTPUT);
pinMode(biPin, OUTPUT);
pinMode(blueBtn, INPUT_PULLUP);
pinMode(yellowBtn, INPUT_PULLUP);
pinMode(redBtn, INPUT_PULLUP);
// Servo setup
servo.attach(servoPin);
pinMode(greenBtn, INPUT_PULLUP);
servo.write(angle); // Start at center
// ===== Fan Speed Control =====
if (digitalRead(blueBtn) == LOW) {
fanSpeed = 255; // Full speed
} else if (digitalRead(yellowBtn) == LOW) {
fanSpeed = 128; // Half speed
} else if (digitalRead(redBtn) == LOW) {
fanSpeed = 0; // Stop
// Apply fan speed
if (fanSpeed > 0) {
analogWrite(biPin, fanSpeed);
analogWrite(fiPin, 0);
} else {
analogWrite(biPin, 0);
// ===== Green Button Toggle =====
bool currentBtnState = digitalRead(greenBtn);
if (lastBtnState == HIGH && currentBtnState == LOW) {
servoActive = !servoActive; // Toggle oscillation
lastBtnState = currentBtnState;
// ===== Servo Logic =====
if (fanSpeed == 0) {
// Fan off → stop servo immediately (keep current angle)
delay(10);
return;
if (servoActive) {
// Oscillation active: swing between 45° and 135°
angle += direction;
if (angle >= rightLimit) direction = -1;
if (angle <= leftLimit) direction = 1;
servo.write(angle);
delay(30); // Movement speed (slower = smoother)
// When servoActive is false and fan running, servo holds its last angle
