Radar Guard 5.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
This project uses an ultrasonic sensor, a servo motor, and an Arduino to create a simple radar system with LED and buzzer alerts.
The servo rotates the sensor to scan for obstacles. If an object is within a set distance, a red LED and buzzer are activated. Otherwise, a green LED shows it’s clear.
Angle and distance data are sent via the serial port for monitoring.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
Ultrasonic Sensor Module
Digital Servo Motor
Buzzer
LED
1kΩ resistor
../_images/radar_guard5.0_bb.png
Common Connections:
  • LED
    • Connect the LEDs anode to the 3, 4 on Arduino, and the LEDs cathode to a 1kΩ resistor then to negative power bus on the breadboard.
  • Buzzer
    • +: Connect to breadboard’s positive power bus.
    • -: Connect to transistor.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 12 on the Arduino.
  • Ultrasonic Sensor Module
    • Trig: Connect to 10 on the Arduino.
    • Echo: Connect to 11 on the Arduino.
Writing the Code
  • Build the circuit.
  • Upload the code to the Arduino board using Arduino IDE.
  • In the Arduino IDE, check the current Arduino port(COMx).
  • The ArduinoRadarGUI is used here. You can click here ArduinoSonarGUI.zip to download it.
  • Open ArduinoLidarGUI.pde in the Processing IDE .
  • Modify the code in line 35 to ensure the correct port number(COMx).
  • Run the Processing sketch to visualize the Lidar data.
  Modified Arduino Radar Code with LED and Buzzer Alerts
#include <Servo.h>
// Ultrasonic sensor pins
const int trigPin = 10;
const int echoPin = 11;
const int servoPin = 12;
Servo myServo;
// LEDs and buzzer pins
const int redLED = 7;
const int greenLED = 6;
const int buzzerPin = 5;
// Distance threshold in cm
const int threshold = 50;
long duration;
int distance;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(redLED, OUTPUT);
  pinMode(greenLED, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  Serial.begin(9600);
  myServo.attach(servoPin);
  for (int i = 15; i <= 165; i++) {
    myServo.write(i);
    delay(30);
    distance = calculateDistance();
    alertSystem(distance);
    sendData(i, distance);
  for (int i = 165; i > 15; i--) {
    myServo.write(i);
    delay(30);
int calculateDistance() {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(echoPin, HIGH) / 58.00;
  return (int)distance;
void alertSystem(int dist) {
  if (dist > 0 && dist <= threshold) {
    digitalWrite(redLED, HIGH);
    digitalWrite(greenLED, LOW);
    int beepDelay = map(dist, 1, threshold, 50, 300); // Closer = faster beep
    digitalWrite(buzzerPin, HIGH);
    delay(5);
    digitalWrite(buzzerPin, LOW);
    delay(beepDelay);
  } else {
    digitalWrite(redLED, LOW);
    digitalWrite(greenLED, HIGH);
void sendData(int angle, int dist) {
  Serial.print(angle);
  Serial.print(",");
  Serial.print(dist);
  Serial.print(".");
