Dino Run 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this project, you’ll learn how to use a light sensor and a servo motor with the Arduino R4 UNO to create a dino run game version 2.0.
When the ambient light suddenly drops—such as when a shadow passes—the servo will quickly activate to simulate a mechanical response, like pressing a button.
This project demonstrates basic sensor input, signal filtering, and actuator control.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Digital Servo Motor |
Photoresistor |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 9 on the Arduino.
Photoresistor Module
VCC: Connect to A0 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Servo.h>
// Pin definitions
const int lightSensorPin = A0;
const int servoPin = 9;
// Detection parameters
const int lightDropThreshold = 400; // Increase threshold: trigger only if drop exceeds 400
unsigned int baselineLight = 0; // Baseline light level at startup
// Trigger cooldown
const unsigned long detectionCooldown = 1000;
unsigned long lastDetectionTime = 0;
Servo myServo;
myServo.attach(servoPin);
myServo.write(0);
pinMode(lightSensorPin, INPUT);
Serial.begin(9600);
// Initialize baseline light value: average over multiple readings
delay(1000); // Wait for stable startup
baselineLight = getAverageLight(10); // Average of 10 readings
Serial.print("Baseline light value: ");
Serial.println(baselineLight);
int currentLight = getAverageLight(5); // Current light average (more stable)
unsigned long currentTime = millis();
Serial.print("Current light: ");
Serial.println(currentLight);
// Check if there's a significant drop in light
if ((baselineLight - currentLight) > lightDropThreshold && currentTime - lastDetectionTime > detectionCooldown) {
myServo.write(90); // Rotate
delay(150); // Hold the position
myServo.write(0); // Return to original position
lastDetectionTime = currentTime;
delay(10);
// Get average light value to avoid accidental triggers
int getAverageLight(int samples) {
long total = 0;
for (int i = 0; i < samples; i++) {
total += analogRead(lightSensorPin);
delay(1); // Small delay between readings
return total / samples;
