Auto Pump
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This program uses an Arduino Uno board with Ultrasonic Sensor Module and a water pump.
The sensor is used to detect the presence of an object.
When an object is detected, the water pump is activated to dispense liquid (liquid hand soap).
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Power Supply |
Ultrasonic Sensor Module |
7 |
TA6586 - Motor Driver Chip |
8 |
Centrifugal Pump |
Common Connections:
Trig: Connect to 3 on the Arduino.
Echo: Connect to 4 on the Arduino.
BI: Connect to 10 on the Arduino.
FI: Connect to 9 on the Arduino.
Centrifugal Pump
Connect to TA6586 B0.
Connect to TA6586 F0.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Arduino.h>
UNO R4 + Ultrasonic (Echo=D4, Trig=D3) + TA6586 Pump Control
Behavior:
- Turn pump ON when distance < ON_THRESHOLD_CM
- Turn pump OFF when distance > OFF_THRESHOLD_CM (hysteresis)
- Median-of-5 sampling; pulseIn timeout; min ON/OFF hold times to avoid chattering
// -------- Pins --------
// Ultrasonic (you asked to swap): Echo -> D4, Trig -> D3
const uint8_t ECHO_PIN = 4;
const uint8_t TRIG_PIN = 3;
// TA6586 motor driver pins (adjust as wired)
const uint8_t MOTOR_BI = 9; // IN1 / Backward input
const uint8_t MOTOR_FI = 10; // IN2 / Forward input
// -------- Tuning --------
const float ON_THRESHOLD_CM = 10.0f; // pump ON below this
const float OFF_THRESHOLD_CM = 12.0f; // pump OFF above this (hysteresis)
const uint8_t SAMPLES = 5; // median-of-5
const uint32_t PULSE_TIMEOUT_US = 30000UL; // 30ms (~5m max), avoid long blocking
// Minimum hold times to protect the pump from rapid toggling
const uint32_t MIN_ON_HOLD_MS = 1500; // keep ON for at least this long
const uint32_t MIN_OFF_HOLD_MS = 800; // keep OFF for at least this long
// Optional: ambient temperature (°C) for speed-of-sound correction
const float AMBIENT_TEMP_C = 20.0f;
// -------- State --------
enum PumpState { PUMP_OFF = 0, PUMP_ON = 1 };
PumpState pumpState = PUMP_OFF;
uint32_t lastToggleMs = 0;
// -------- Pump helpers --------
void pumpForward() { // preferred ON direction (swap with pumpReverse() if needed)
digitalWrite(MOTOR_FI, LOW);
digitalWrite(MOTOR_BI, HIGH);
void pumpReverse() { // alternative ON direction
digitalWrite(MOTOR_BI, LOW);
digitalWrite(MOTOR_FI, HIGH);
void pumpStop() { // stop (coast). For brake, set both HIGH if datasheet recommends.
// -------- Ultrasonic helpers --------
float usPerCm() {
// Speed of sound (m/s) ≈ 331.4 + 0.6*T(°C)
float v = 331.4f + 0.6f * AMBIENT_TEMP_C; // m/s
float us_per_m = 1e6f / v; // µs per meter (one-way)
return (us_per_m * 0.01f) * 2.0f; // round-trip µs for 1 cm (~58 at ~20°C)
float measureOnceCm() {
// Send 10us trigger pulse
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
// Read echo pulse width with timeout
unsigned long dur = pulseIn(ECHO_PIN, HIGH, PULSE_TIMEOUT_US);
if (dur == 0) return NAN; // timeout -> invalid reading
return dur / usPerCm(); // convert to cm
float readDistanceMedianCm() {
float vals[SAMPLES];
for (uint8_t i = 0; i < SAMPLES; i++) {
vals[i] = measureOnceCm();
delay(5); // small gap between pings to avoid cross-talk echoes
// insertion sort (small N) - NANs float to the end
for (uint8_t i = 1; i < SAMPLES; i++) {
float key = vals[i];
int j = i - 1;
while (j >= 0 && (isnan(vals[j]) || vals[j] > key)) {
vals[j + 1] = vals[j];
j--;
vals[j + 1] = key;
return vals[SAMPLES / 2]; // median
// -------- Setup / Loop --------
// Ultrasonic
pinMode(ECHO_PIN, INPUT);
pinMode(TRIG_PIN, OUTPUT);
// Pump driver
pinMode(MOTOR_BI, OUTPUT);
pinMode(MOTOR_FI, OUTPUT);
pumpStop(); // safe default
// Debug serial
Serial.begin(115200);
Serial.println("Ultrasonic + Pump (Echo=D4, Trig=D3) ready.");
float d = readDistanceMedianCm();
uint32_t now = millis();
bool valid = !isnan(d);
// Simple state machine with hysteresis and min hold times
switch (pumpState) {
case PUMP_OFF:
if (valid && d < ON_THRESHOLD_CM && (now - lastToggleMs >= MIN_OFF_HOLD_MS)) {
pumpForward(); // switch to pumpReverse() if direction is wrong
pumpState = PUMP_ON;
lastToggleMs = now;
Serial.println("Pump -> ON");
break;
case PUMP_ON:
if (valid && d > OFF_THRESHOLD_CM && (now - lastToggleMs >= MIN_ON_HOLD_MS)) {
pumpStop();
lastToggleMs = now;
Serial.println("Pump -> OFF");
// Optional safety: if invalid for long time, you may force OFF after MIN_ON_HOLD_MS
// else keep last state to avoid chattering on occasional timeouts.
break;
// Debug print
if (valid) {
Serial.print("Distance(cm): ");
Serial.print(d, 1);
Serial.print(" | State: ");
Serial.println(pumpState == PUMP_ON ? "ON" : "OFF");
} else {
Serial.println("Distance: INVALID (timeout)");
delay(60); // moderate loop rate
