Parking Lot
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this project, you will use an Arduino board, a servo motor, IR sensors, and a traffic light module to build an intelligent parking lot barrier system.
The system detects vehicles with IR sensors, automatically controls the barrier gate, updates the car count on the LCD, and manages the traffic light for safe entry and exit.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
IR Obstacle Avoidance Sensor Module |
Digital Servo Motor |
7 |
I2C LCD 1602 |
8 |
Traffic Light LED |
Common Connections:
Traffic light LED
R: Connect to 4 on the Arduino.
Y: Connect to 5 on the Arduino.
G: Connect to 6 on the Arduino.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 9 on the Arduino.
IR Obstacle Avoidance Sensor Module 1
OUT: Connect to 2 on the Arduino.
IR Obstacle Avoidance Sensor Module 2
OUT: Connect to 3 on the Arduino.
I2C LCD 1602
SDA: Connect to SDA on the Arduino.
SCL: Connect to SCL on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Servo.h>
// LCD setup
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Servo setup
Servo gateServo;
const int SERVO_PIN = 9;
// IR sensor pins
const int IR1_PIN = 2;
const int IR2_PIN = 3;
// Traffic light module pins
const int RED_PIN = 4;
const int YELLOW_PIN = 5;
const int GREEN_PIN = 6;
// Status variable
int carCount = 2;
enum State {
IDLE,
ENTER_WAIT_YELLOW, // Detected at entrance, yellow light blinking
ENTER_WAIT_GREEN, // Raise barrier, green light
ENTER_WAIT_EXIT, // Waiting for IR2 to count
EXIT_WAIT_YELLOW, // Detected at exit, yellow light blinking
EXIT_WAIT_GREEN, // Raise barrier, green light
EXIT_WAIT_EXIT // Waiting for IR1 to count
State state = IDLE;
// Timing variables
unsigned long stateStartTime = 0;
const unsigned long YELLOW_BLINK_TIME = 2000;
const unsigned long GREEN_TIME = 1000;
bool yellowBlinkState = false;
unsigned long lastBlinkTime = 0;
const unsigned long BLINK_INTERVAL = 300;
// LCD
lcd.init();
lcd.backlight();
lcd.setCursor(0, 0);
lcd.print("Parking Lot");
lcd.setCursor(0, 1);
lcd.print("Car Count: ");
lcd.print(carCount);
// Servo
gateServo.attach(SERVO_PIN);
gateServo.write(0); // Initial down
// IR sensors
pinMode(IR1_PIN, INPUT);
pinMode(IR2_PIN, INPUT);
// Traffic light
pinMode(RED_PIN, OUTPUT);
pinMode(YELLOW_PIN, OUTPUT);
pinMode(GREEN_PIN, OUTPUT);
setTrafficLight('R');
bool ir1State = digitalRead(IR1_PIN) == LOW;
bool ir2State = digitalRead(IR2_PIN) == LOW;
unsigned long now = millis();
switch(state) {
case IDLE:
gateServo.write(0); // Down
// Detect entry
if (ir1State) {
state = ENTER_WAIT_YELLOW;
stateStartTime = now;
lastBlinkTime = now;
// Detect exit
else if (ir2State) {
state = EXIT_WAIT_YELLOW;
break;
case ENTER_WAIT_YELLOW:
// Non-blocking yellow light blinking
if (now - lastBlinkTime > BLINK_INTERVAL) {
yellowBlinkState = !yellowBlinkState;
digitalWrite(YELLOW_PIN, yellowBlinkState ? HIGH : LOW);
if (now - stateStartTime > YELLOW_BLINK_TIME) {
digitalWrite(YELLOW_PIN, LOW);
setTrafficLight('G');
gateServo.write(90); // Raise barrier
state = ENTER_WAIT_GREEN;
break;
case ENTER_WAIT_GREEN:
// Allow car to pass during green light
if (now - stateStartTime > GREEN_TIME) {
// Wait for IR2 detection (car passes IR2 to count)
state = ENTER_WAIT_EXIT;
break;
case ENTER_WAIT_EXIT:
// Count only after IR2 is detected
if (ir2State) {
carCount++;
updateLCD();
gateServo.write(0); // Barrier down
state = IDLE;
// Wait for IR2 to be released before allowing next entry
while (digitalRead(IR2_PIN) == LOW) { delay(10); }
break;
case EXIT_WAIT_YELLOW:
state = EXIT_WAIT_GREEN;
break;
case EXIT_WAIT_GREEN:
state = EXIT_WAIT_EXIT;
break;
case EXIT_WAIT_EXIT:
// Count only after IR1 is detected
if (ir1State) {
if (carCount > 0) carCount--;
updateLCD();
state = IDLE;
// Wait for IR1 to be released before allowing next exit
while (digitalRead(IR1_PIN) == LOW) { delay(10); }
break;
// Traffic light control
void setTrafficLight(char color) {
switch (color) {
case 'R':
digitalWrite(RED_PIN, HIGH);
digitalWrite(GREEN_PIN, LOW);
break;
case 'Y':
digitalWrite(RED_PIN, LOW);
digitalWrite(YELLOW_PIN, HIGH);
break;
case 'G':
digitalWrite(GREEN_PIN, HIGH);
break;
// Update LCD display
void updateLCD() {
lcd.setCursor(11, 1);
