Train Ramp
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll learn how to build an automatic railway crossing using two IR Sensor Modules and two servo motors.
When a train passes the first sensor, the barriers lower to block the road. After the train reaches the second sensor, the barriers rise again, simulating a real railway crossing system.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Digital Servo Motor |
IR Obstacle Avoidance Sensor Module |
Common Connections:
Digital Servo Motor 1
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 9 on the Arduino.
Digital Servo Motor 2
Connect to 10 on the Arduino.
IR Obstacle Avoidance Sensor Module 1
OUT: Connect to 2 on the Arduino.
IR Obstacle Avoidance Sensor Module 2
OUT: Connect to 3 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Servo.h>
// IR sensor pins
const int IR_ENTRY_PIN = 2;
const int IR_EXIT_PIN = 3;
// Servo pins
const int SERVO_1_PIN = 9;
const int SERVO_2_PIN = 10;
// Servo angles
const int GATE_DOWN_ANGLE = 0;
const int GATE_UP_ANGLE = 90;
// Most IR obstacle sensors output LOW when an object is detected.
// If your sensor works the opposite way, change LOW to HIGH.
const int IR_DETECTED_STATE = LOW;
// Debounce
const unsigned long debounceDelay = 200;
Servo gateServo1;
Servo gateServo2;
bool gateOpen = false;
bool lastEntryState = HIGH;
bool lastExitState = HIGH;
unsigned long lastEntryTime = 0;
unsigned long lastExitTime = 0;
pinMode(IR_ENTRY_PIN, INPUT);
pinMode(IR_EXIT_PIN, INPUT);
gateServo1.attach(SERVO_1_PIN);
gateServo2.attach(SERVO_2_PIN);
closeGate();
bool currentEntryState = digitalRead(IR_ENTRY_PIN);
bool currentExitState = digitalRead(IR_EXIT_PIN);
unsigned long now = millis();
// IR Sensor 1 detects the train: raise the barriers
if (lastEntryState != IR_DETECTED_STATE && currentEntryState == IR_DETECTED_STATE) {
if (now - lastEntryTime > debounceDelay) {
openGate();
lastEntryTime = now;
// IR Sensor 2 detects the train: lower the barriers
if (lastExitState != IR_DETECTED_STATE && currentExitState == IR_DETECTED_STATE) {
if (now - lastExitTime > debounceDelay) {
closeGate();
lastExitTime = now;
lastEntryState = currentEntryState;
lastExitState = currentExitState;
void openGate() {
gateOpen = true;
gateServo1.write(GATE_UP_ANGLE);
gateServo2.write(GATE_UP_ANGLE);
void closeGate() {
gateOpen = false;
gateServo1.write(GATE_DOWN_ANGLE);
gateServo2.write(GATE_DOWN_ANGLE);
