RFID Access2.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Inventor Lab Kit
Arduino Uno R3
Course Introduction
In this lesson, we’ll build a 2.0 access-control system using the MFRC522 module, a 1602 LCD, and an active buzzer.
Valid cards light the green LED and play an “access granted” tone; invalid cards light the red LED and trigger a warning alarm.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Active Buzzer
I2C LCD 1602
MFRC522 Module
Power Supply Module
LED
Resistor
1KΩ × 4
../_images/RFID_Access2.0_bb.png
Common Connections:
  • MFRC522 Module
    • SDA: Connect to 10 on the Arduino.
    • SCK: Connect to 13 on the Arduino.
    • MOSI: Connect to 11 on the Arduino.
    • MISO: Connect to 12 on the Arduino.
    • RST: Connect to 9 on the Arduino.
    • 3.3V: Connect to breadboard’s passive power bus.
  • Active Buzzer
    • +: Connect to 6 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the Green LED anode to the 5 on the Arduino through a 1 kΩ resistor, the Red LED cathode to the 6 on the Arduino through a 1 kΩ resistor.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
  • To install the library, use the Arduino Library Manager and search for MFRC522 and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <SPI.h>                  // SPI library for RFID communication
#include <MFRC522.h>              // RFID library for MFRC522 module
#include <Wire.h>                 // I2C library for LCD
#include <LiquidCrystal_I2C.h>    // LCD library for I2C-based LCDs
// Pin definitions
#define SS_PIN         10         // RFID SDA (SS) pin
#define RST_PIN        9          // RFID reset pin
#define RED_LED_PIN    4          // Red LED pin
#define GREEN_LED_PIN  5          // Green LED pin
#define BUZZER_PIN     6          // Active buzzer pin
// Create RFID and LCD objects
MFRC522 rfid(SS_PIN, RST_PIN);
LiquidCrystal_I2C lcd(0x27, 16, 2);  // LCD address (change if needed), 16 columns x 2 rows
// UID of the authorized card (replace with your own card UID)
byte authorizedUID[4] = {0x36, 0xE2, 0xC4, 0xF7};
  Serial.begin(9600);          // Start serial monitor for debugging
  SPI.begin();                 // Initialize SPI communication
  rfid.PCD_Init();             // Initialize RFID reader
  lcd.init();                  // Initialize the LCD
  lcd.backlight();             // Turn on LCD backlight
  pinMode(RED_LED_PIN, OUTPUT);
  pinMode(GREEN_LED_PIN, OUTPUT);
  pinMode(BUZZER_PIN, OUTPUT);
  // Set default state: red LED on, LCD shows prompt
  digitalWrite(RED_LED_PIN, HIGH);
  lcd.setCursor(0, 0);
  lcd.print("Scan your card");
  // Wait for a new card
  if (!rfid.PICC_IsNewCardPresent() || !rfid.PICC_ReadCardSerial()) return;
  // Print the scanned UID to the Serial Monitor
  Serial.print("Card UID: ");
  for (byte i = 0; i < rfid.uid.size; i++) {
    Serial.print(rfid.uid.uidByte[i] < 0x10 ? " 0" : " ");
    Serial.print(rfid.uid.uidByte[i], HEX);
  Serial.println();
  // Check if the scanned card is authorized
  bool authorized = compareUID(rfid.uid.uidByte, rfid.uid.size);
  showAccessResult(authorized);
  // Stop communicating with the current card
  rfid.PICC_HaltA();
  rfid.PCD_StopCrypto1();
// Compare scanned UID with the authorized one
bool compareUID(byte *uid, byte len) {
  if (len != 4) return false;
  for (byte i = 0; i < 4; i++) {
    if (uid[i] != authorizedUID[i]) return false;
  return true;
// Display access result and give feedback
void showAccessResult(bool granted) {
  if (granted) {
    // Access granted:
    // Turn off red LED, turn on green LED, show welcome message
    digitalWrite(RED_LED_PIN, LOW);
    digitalWrite(GREEN_LED_PIN, HIGH);
    lcd.clear();
    lcd.print("Welcome!");
    shortBeep();
    delay(1000);
    // Reset to default state
    digitalWrite(GREEN_LED_PIN, LOW);
    lcd.clear();
  } else {
    // Access denied:
    // Flash red LED, beep 3 times, show denial message
    lcd.clear();
    lcd.print("Access Denied");
    deniedFeedback(1500);  // Flash and beep for 1.5 seconds
    lcd.clear();
// Play a short beep (used for access granted)
void shortBeep() {
  digitalWrite(BUZZER_PIN, HIGH);
  delay(200);
  digitalWrite(BUZZER_PIN, LOW);
// Flash red LED and beep 3 times over a duration
void deniedFeedback(unsigned long duration) {
  unsigned long start = millis();
  int flashState = LOW;
  unsigned long lastFlash = 0;
  int beepCount = 0;
  unsigned long lastBeep = 0;
  bool beeping = false;
  while (millis() - start < duration) {
    unsigned long now = millis();
    // Toggle red LED every 100ms
    if (now - lastFlash >= 100) {
      flashState = !flashState;
      digitalWrite(RED_LED_PIN, flashState);
      lastFlash = now;
    // Play 3 beeps, each 100ms long, spaced 200ms apart
    if (beepCount < 3) {
      if (!beeping && (now - lastBeep >= 200)) {
        lastBeep = now;
        beeping = true;
      if (beeping && (now - lastBeep >= 100)) {
        beeping = false;
        beepCount++;
  // Ensure everything is off after feedback
