Disarm Timer
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This Arduino project uses a 4x4 keypad, I2C 1602 LCD, LEDs, and a buzzer to simulate a digital bomb countdown system.
Set a 4-digit code and countdown timer using the keypad. The LCD displays instructions and the timer.
Use the correct code to disarm before time runs out, or the red LED and buzzer will trigger to signal “explosion.”
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
KeyPad |
7 |
LED |
8 |
I2C LCD 1602 |
9 |
Passive Buzzer |
Common Connections:
LED
Red: Connect the LED cathode to the negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to 2 on the Arduino.
Green: Connect the LED cathode to the negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to 3 on the Arduino.
Keypad
RowPins: Connect to 5 to 8 on the Arduino.
ColPins: Connect to 9 to 12 on the Arduino.
Passive Buzzer
+: Connect to 4 on the Arduino.
-: Connect to breadboard’s negative power bus.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and Adafruit_Keypad install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <Adafruit_Keypad.h>
// Pin definitions for 4x4 keypad
const byte ROWS = 4, COLS = 4;
char keys[ROWS][COLS] = {
{ '1','2','3','A' },
{ '4','5','6','B' },
{ '7','8','9','C' },
{ '*','0','#','D' }
byte rowPins[ROWS] = { 5, 6, 7, 8 };
byte colPins[COLS] = { 9, 10, 11, 12 };
Adafruit_Keypad keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
// LED and buzzer pins
const int RED_LED_PIN = 2;
const int GREEN_LED_PIN = 3;
const int BUZZER_PIN = 4;
// I2C LCD at address 0x27, 16 columns × 2 rows
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Storage for arm/disarm code and countdown
int armCode[4], inputCode[4];
unsigned long timeLeft = 0;
// Play a simple beep for key presses (1000Hz, 80ms)
void beepKey() {
tone(BUZZER_PIN, 1000, 80);
// Play a lower beep for each countdown tick (800Hz, 100ms)
void beepCount() {
tone(BUZZER_PIN, 800, 100);
// Play three quick beeps when '#' is pressed to arm
void beepHash() {
for (int i = 0; i < 3; i++) {
delay(120);
// Play alternating tones and flash LEDs on disarm success
void beepDisarm() {
digitalWrite(RED_LED_PIN, HIGH);
digitalWrite(GREEN_LED_PIN, LOW);
tone(BUZZER_PIN, 1200, 200);
delay(300);
digitalWrite(RED_LED_PIN, LOW);
digitalWrite(GREEN_LED_PIN, HIGH);
tone(BUZZER_PIN, 800, 200);
delay(300);
noTone(BUZZER_PIN);
Serial.begin(9600);
keypad.begin();
pinMode(RED_LED_PIN, OUTPUT);
pinMode(GREEN_LED_PIN, OUTPUT);
pinMode(BUZZER_PIN, OUTPUT);
// Initialize LCD
lcd.init();
lcd.backlight();
lcd.clear();
// 1. Enter 4-digit arm code
lcd.setCursor(0, 0);
lcd.print("Bomb Activated!");
lcd.setCursor(0, 1);
lcd.print("Code: ");
for (int i = 0, col = 6; i < 4; ) {
keypad.tick();
if (keypad.available()) {
auto e = keypad.read();
if (e.bit.EVENT == KEY_JUST_PRESSED && isDigit(e.bit.KEY)) {
beepKey();
armCode[i++] = e.bit.KEY - '0';
lcd.setCursor(col++, 1);
lcd.print((char)e.bit.KEY);
delay(500);
// 2. Show disarm code
lcd.clear();
lcd.print("Disarm Code:");
for (int i = 0; i < 4; i++) {
lcd.print(armCode[i]);
delay(1000);
// 3. Set countdown time (HH:MM:SS)
lcd.clear();
lcd.print("Time: HH:MM:SS");
lcd.print("SET: ");
int t[6];
for (int i = 0; i < 6; ) {
keypad.tick();
beepKey();
t[i] = e.bit.KEY - '0';
int pos = (i < 2 ? 5 + i : (i < 4 ? 8 + (i - 2) : 11 + (i - 4)));
lcd.setCursor(pos, 1);
i++;
int HH = t[0]*10 + t[1];
int MM = t[2]*10 + t[3];
int SS = t[4]*10 + t[5];
timeLeft = HH*3600UL + MM*60UL + SS;
// 4. Center display initial countdown for 2 seconds
char buf[9];
sprintf(buf, "%02d:%02d:%02d", HH, MM, SS);
lcd.clear();
lcd.print("Time:");
lcd.setCursor((16 - 8) / 2, 1);
lcd.print(buf);
delay(2000);
// 5. Prompt to arm with centered "# To Arm"
lcd.clear();
lcd.setCursor((16 - 7) / 2, 0);
lcd.print("# To Arm");
while (true) {
keypad.tick();
if (e.bit.EVENT == KEY_JUST_PRESSED && e.bit.KEY == '#') {
beepHash();
break;
// 6. Show armed message for 2 seconds
lcd.clear();
lcd.print("Bomb Armed!");
lcd.print("Countdown Started!");
delay(2000);
static unsigned long prev = millis();
static bool disarmMode = false;
static int di = 0;
char buf[9];
keypad.tick();
// 7. Update countdown every second on second line
unsigned long now = millis();
if (now - prev >= 1000) {
prev += 1000;
if (timeLeft > 0) {
timeLeft--;
int h = timeLeft / 3600;
int m = (timeLeft % 3600) / 60;
int s = timeLeft % 60;
sprintf(buf, "%02d:%02d:%02d", h, m, s);
if (!disarmMode) {
lcd.clear();
lcd.print("Time:");
lcd.print(buf);
beepCount();
// 8. Press '*' to disarm (does not pause countdown)
if (e.bit.EVENT == KEY_JUST_PRESSED) {
beepKey();
if (e.bit.KEY == '*' && !disarmMode) {
disarmMode = true;
di = 0;
lcd.clear();
lcd.print("Code:");
timeLeft / 3600,
(timeLeft % 3600) / 60,
timeLeft % 60);
lcd.print("Time:");
lcd.print(buf);
else if (disarmMode && isDigit(e.bit.KEY) && di < 4) {
inputCode[di] = e.bit.KEY - '0';
lcd.setCursor(6 + di, 0);
di++;
if (di == 4) {
bool ok = true;
if (inputCode[i] != armCode[i]) ok = false;
if (ok) {
beepDisarm();
lcd.clear();
lcd.print("Disarmed!");
lcd.print("Well Done!");
while (true); // stop further action
disarmMode = false; // wrong code, back to countdown
// 11. Explode when time reaches zero
if (timeLeft == 0) {
lcd.clear();
lcd.print("THE BOMB");
lcd.print("EXPLODED!!!");
while (true) {
beepKey(); // use same “beep” tone
delay(100);
beepKey();
delay(100);
