Barrier Gate 4.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This project uses an ultrasonic sensor, traffic lights, a servo, and a buzzer to create an automatic gate system.
When a car is detected, the lights change, the gate opens, and the buzzer signals. After the car passes, the gate closes and the red light turns back on.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Traffic Light LED |
Digital Servo Motor |
7 |
Buzzer Modudle |
8 |
Ultrasonic Sensor Module |
Common Connections:
Traffic light LED
R: Connect to 7 on the Arduino.
Y: Connect to 6 on the Arduino.
G: Connect to 5 on the Arduino.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 3 on the Arduino.
Trig: Connect to 11 on the Arduino.
Echo: Connect to 10 on the Arduino.
Buzzer Module
I/0: Connect to 2 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
// Ultrasonic sensor pins
const int trigPin = 11;
const int echoPin = 10;
// Traffic light pins
const int redPin = 7;
const int yellowPin = 6;
const int greenPin = 5;
// Servo and buzzer pins
const int servoPin = 3;
const int buzzerPin = 2;
Servo myServo;
// Play one beep
void beepOnce(int freq, int dur) {
tone(buzzerPin, freq, dur);
delay(dur * 1.2);
noTone(buzzerPin);
// Play three short beeps
void beepTriple() {
for (int i = 0; i < 3; i++) {
tone(buzzerPin, 1500, 120);
delay(150);
noTone(buzzerPin);
delay(80);
// Smoothly open the gate
void openGate() {
for (int pos = 0; pos <= 90; pos++) {
myServo.write(pos);
delay(10); // smooth speed
// Smoothly close the gate
void closeGate() {
for (int pos = 90; pos >= 0; pos--) {
myServo.write(pos);
delay(10);
// Read distance once
float getDistance() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
long duration = pulseIn(echoPin, HIGH, 25000); // 25ms timeout
if (duration == 0) return 999; // no echo
return duration * 0.034 / 2;
Serial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(redPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(buzzerPin, OUTPUT);
myServo.attach(servoPin);
myServo.write(0); // gate starts closed
digitalWrite(redPin, HIGH); // red ON at start
float distance = getDistance();
Serial.print("Distance: ");
Serial.println(distance);
// Car detected
if (distance < 10) {
// Yellow + warning beep
digitalWrite(redPin, LOW);
digitalWrite(yellowPin, HIGH);
digitalWrite(greenPin, LOW);
beepOnce(1000, 300);
delay(1000);
// Green light + open gate
digitalWrite(yellowPin, LOW);
digitalWrite(greenPin, HIGH);
openGate(); // smooth motion (no ultrasonic during movement)
beepTriple(); // pass signal
delay(1500);
// Red light + close gate
closeGate(); // smooth motion
beepOnce(800, 200);
delay(500);
delay(200); // small delay between checks
