Tetris4.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project uses MAX7219 8x8 Dot Matrix module, four buttons to play a classic Tetris game.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Button
MAX7219 Dot Matrix Module
../_images/Tetris_4.0_bb.png
Common Connections:
  • MAX7219 Dot Matrix Module
    • CLK: Connect to 12 on the Arduino.
    • CS: Connect to 10 on the Arduino.
    • DIN: Connect to 11 on the Arduino.
  • Button 1
    • Connect to the breadboard’s negative power bus, and the other end to 3 on the Arduino board.
  • Button 2
    • Connect to the breadboard’s negative power bus, and the other end to 4 on the Arduino board.
  • Button 3
    • Connect to the breadboard’s negative power bus, and the other end to 5 on the Arduino board.
  • Button 4
    • Connect to the breadboard’s negative power bus, and the other end to 6 on the Arduino board.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LedControl and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <LedControl.h>
// MAX7219 wiring (DIN -> D11, CLK -> D12, CS -> D10)
const uint8_t PIN_DIN = 11;
const uint8_t PIN_CLK = 12;
const uint8_t PIN_CS  = 10;
// Create a MAX7219 controller (1 device)
LedControl lc = LedControl(PIN_DIN, PIN_CLK, PIN_CS, 1);
// Button pins (INPUT_PULLUP: pressed = LOW)
const uint8_t PIN_LEFT   = 5;
const uint8_t PIN_RIGHT  = 6;
const uint8_t PIN_DOWN   = 3;   // Hold to fall faster
const uint8_t PIN_ROTATE = 4;   // Press to rotate / start game
// Playfield data: 8 rows, each row uses 8 bits (1 = occupied)
// field[y] corresponds to row y (0 = top, 7 = bottom)
byte field[8];
// Falling timing (gravity)
unsigned long lastDrop = 0;
unsigned long baseDropInterval = 500;   // Normal falling speed (ms)
unsigned long fastDropInterval = 120;   // Faster falling speed when holding DOWN
unsigned long currentDropInterval = 500;
// Key repeat and debounce timing
unsigned long lastMoveTime = 0;
const unsigned long moveRepeatInterval = 120;  // Repeat speed for LEFT/RIGHT when held
bool lastRotateState = HIGH;
unsigned long lastRotateTime = 0;
const unsigned long rotateDebounce = 150;      // Prevent rotating too fast
// Game state flags
bool gameRunning = false;
bool gameOver = false;
// A single point (x, y) used to describe block shapes
struct Point { int8_t x; int8_t y; };
// One shape can have up to 4 rotations
struct ShapeDef {
  const Point* rots[4];
  uint8_t rotCount;
// Current falling block (x, y is the block origin)
// y can be negative so the block can spawn above the screen
struct Block {
  uint8_t shapeId;   // 0..6
  uint8_t rot;       // 0..rotCount-1
  int8_t x;          // x position
  int8_t y;          // y position (can be negative for off-screen spawn)
// I block (2 rotations)
const Point I0[4] = {{-1,0},{0,0},{1,0},{2,0}};
const Point I1[4] = {{0,-1},{0,0},{0,1},{0,2}};
// O block (1 rotation)
const Point O0[4] = {{0,0},{1,0},{0,1},{1,1}};
// T block (4 rotations)
const Point T0[4] = {{-1,0},{0,0},{1,0},{0,1}};
const Point T1[4] = {{0,-1},{0,0},{0,1},{1,0}};
const Point T2[4] = {{-1,0},{0,0},{1,0},{0,-1}};
const Point T3[4] = {{0,-1},{0,0},{0,1},{-1,0}};
// L block (4 rotations)
const Point L0[4] = {{-1,0},{0,0},{1,0},{1,1}};
const Point L1[4] = {{0,-1},{0,0},{0,1},{1,-1}};
const Point L2[4] = {{-1,-1},{-1,0},{0,0},{1,0}};
const Point L3[4] = {{-1,1},{0,-1},{0,0},{0,1}};
// J block (4 rotations)
const Point J0[4] = {{-1,0},{0,0},{1,0},{-1,1}};
const Point J1[4] = {{0,-1},{0,0},{0,1},{1,1}};
const Point J2[4] = {{1,-1},{-1,0},{0,0},{1,0}};
const Point J3[4] = {{-1,-1},{0,-1},{0,0},{0,1}};
// S block (2 rotations)
const Point S0[4] = {{0,0},{1,0},{-1,1},{0,1}};
const Point S1[4] = {{0,-1},{0,0},{1,0},{1,1}};
// Z block (2 rotations)
const Point Z0[4] = {{-1,0},{0,0},{0,1},{1,1}};
const Point Z1[4] = {{1,-1},{0,0},{1,0},{0,1}};
// All 7 block types
const ShapeDef shapes[7] = {
  { {I0, I1, nullptr, nullptr}, 2 },      // I
  { {O0, nullptr, nullptr, nullptr}, 1 }, // O
  { {T0, T1, T2, T3}, 4 },                // T
  { {L0, L1, L2, L3}, 4 },                // L
  { {J0, J1, J2, J3}, 4 },                // J
  { {S0, S1, nullptr, nullptr}, 2 },      // S
  { {Z0, Z1, nullptr, nullptr}, 2 }       // Z
Block cur;
// Check if a specific bit (x) is set in a row byte
inline bool rowHas(byte row, int8_t x) {
  return (row & (1 << x)) != 0;
// Reverse bit order in a byte (used to match your LED module orientation)
byte reverse8(byte b) {
  b = (b & 0xF0) >> 4 | (b & 0x0F) << 4;
  b = (b & 0xCC) >> 2 | (b & 0x33) << 2;
  b = (b & 0xAA) >> 1 | (b & 0x55) << 1;
  return b;
// Collision test for a block at (nx, ny) with a given rotation
// Notes:
// - Left/right boundaries are always checked
// - Bottom boundary is checked
// - py < 0 is allowed (block above the visible screen)
// - Overlap with field[] is checked only when py >= 0
bool checkCollision(int8_t nx, int8_t ny, uint8_t shapeId, uint8_t rot) {
  const ShapeDef& sd = shapes[shapeId];
  const Point* pts = sd.rots[rot];
  for (uint8_t i = 0; i < 4; i++) {
    int8_t px = nx + pts[i].x;
    int8_t py = ny + pts[i].y;
    if (px < 0 || px > 7) return true;
    if (py > 7) return true;
    if (py >= 0) {
      if (rowHas(field[py], px)) return true;
  return false;
// Try moving the current block; return false if blocked
bool moveBlock(int8_t dx, int8_t dy) {
  int8_t nx = cur.x + dx;
  int8_t ny = cur.y + dy;
  if (checkCollision(nx, ny, cur.shapeId, cur.rot)) return false;
  cur.x = nx;
  cur.y = ny;
  return true;
// Rotate the block (with a small "wall-kick" so rotation feels smoother)
void rotateBlock() {
  const ShapeDef& sd = shapes[cur.shapeId];
  if (sd.rotCount <= 1) return;
  uint8_t oldRot = cur.rot;
  uint8_t nextRot = (cur.rot + 1) % sd.rotCount;
  if (!checkCollision(cur.x, cur.y, cur.shapeId, nextRot)) {
    cur.rot = nextRot;
    return;
  // Wall-kick: try shifting left or right by 1 if rotation is blocked
  if (!checkCollision(cur.x - 1, cur.y, cur.shapeId, nextRot)) {
    cur.x -= 1;
    cur.rot = nextRot;
    return;
  if (!checkCollision(cur.x + 1, cur.y, cur.shapeId, nextRot)) {
    cur.x += 1;
    cur.rot = nextRot;
    return;
  // Rotation failed, restore previous state
  cur.rot = oldRot;
// Lock the current block into the field[] (only visible pixels are stored)
void placeBlock() {
  const Point* pts = sd.rots[cur.rot];
    int8_t px = cur.x + pts[i].x;
    int8_t py = cur.y + pts[i].y;
    if (px >= 0 && px <= 7 && py >= 0 && py <= 7) {
      field[py] |= (1 << px);
// Remove full lines (0xFF) and shift everything above down
void clearLines() {
  for (int8_t y = 7; y >= 0; y--) {
    if (field[y] == 0xFF) {
      for (int8_t yy = y; yy > 0; yy--) {
        field[yy] = field[yy - 1];
      field[0] = 0;
      y++; // Re-check the same row after shifting
// Reset field and timers for a new game
void resetGame() {
  for (uint8_t i = 0; i < 8; i++) field[i] = 0;
  gameOver = false;
  lastDrop = millis();
// Create a new block above the visible top so it "slides in"
void spawnBlock() {
  cur.shapeId = (uint8_t)random(0, 7);
  cur.rot = 0;
  cur.x = 3;
  cur.y = -1;
  // I block is 4-wide in horizontal state, so shift left to avoid edge issues
  if (cur.shapeId == 0) {
    cur.x = 2;
    cur.y = -1;
  // If the new block already hits existing blocks, the game ends
  if (checkCollision(cur.x, cur.y, cur.shapeId, cur.rot)) {
    gameOver = true;
// Convert your logical 8x8 frame into the correct LED orientation
// This mapping is based on your module: rotate 90° clockwise + reverse bits
void drawMapped(const byte src[8]) {
  byte rotated[8] = {0};
  for (int y = 0; y < 8; y++) {
    for (int x = 0; x < 8; x++) {
      if (src[y] & (1 << x)) {
        rotated[x] |= (1 << (7 - y));
  for (int row = 0; row < 8; row++) {
    rotated[row] = reverse8(rotated[row]);
    lc.setRow(0, row, rotated[row]);
// Build a frame = field + current block, then display it
void drawFrame() {
  byte frame[8];
  for (uint8_t y = 0; y < 8; y++) frame[y] = field[y];
  if (gameRunning && !gameOver) {
        frame[py] |= (1 << px);
  drawMapped(frame);
// Simple blinking animation when game is over
void showGameOverAnim() {
  static unsigned long lastBlink = 0;
  static bool on = false;
  unsigned long now = millis();
  if (now - lastBlink > 300) {
    lastBlink = now;
    on = !on;
  byte full[8];
  for (int i = 0; i < 8; i++) full[i] = on ? 0xFF : 0x00;
  drawMapped(full);
// Read buttons and apply control (move/rotate/speed)
void handleInput() {
  bool leftPressed   = (digitalRead(PIN_LEFT)   == LOW);
  bool rightPressed  = (digitalRead(PIN_RIGHT)  == LOW);
  bool downPressed   = (digitalRead(PIN_DOWN)   == LOW);
  bool rotatePressed = (digitalRead(PIN_ROTATE) == LOW);
  // DOWN changes falling speed (soft drop)
  currentDropInterval = downPressed ? fastDropInterval : baseDropInterval;
  // LEFT/RIGHT: allow holding the button (repeat movement)
  if (now - lastMoveTime >= moveRepeatInterval) {
    if (leftPressed && !rightPressed) {
      moveBlock(-1, 0);
      lastMoveTime = now;
    } else if (rightPressed && !leftPressed) {
      moveBlock(1, 0);
      lastMoveTime = now;
  // ROTATE: only rotate once per press (debounced)
  if (rotatePressed != lastRotateState) {
    if (now - lastRotateTime > rotateDebounce) {
      lastRotateTime = now;
      if (rotatePressed) {
        rotateBlock();
    lastRotateState = rotatePressed;
// Helper used for "press to start/restart"
bool rotatePressedNow() {
  return digitalRead(PIN_ROTATE) == LOW;
  // Use A0 noise as a simple random seed (A0 is unused here)
  randomSeed(analogRead(A0));
  pinMode(PIN_LEFT, INPUT_PULLUP);
  pinMode(PIN_RIGHT, INPUT_PULLUP);
  pinMode(PIN_DOWN, INPUT_PULLUP);
  pinMode(PIN_ROTATE, INPUT_PULLUP);
  lc.shutdown(0, false);
  lc.setIntensity(0, 8);
  lc.clearDisplay(0);
  resetGame();
  drawFrame();
  // Not running: show idle/game over screen, press ROTATE to start
  if (!gameRunning) {
    if (gameOver) showGameOverAnim();
    else drawFrame();
    if (rotatePressedNow()) {
      delay(30);
        resetGame();
        spawnBlock();
        gameRunning = !gameOver;
        // Wait for release to avoid an instant rotate
        while (rotatePressedNow()) { delay(10); }
    return;
  // Running: read input and apply gravity
  handleInput();
  if (now - lastDrop >= currentDropInterval) {
    lastDrop = now;
    // If the block can't move down, lock it and spawn a new one
    if (!moveBlock(0, 1)) {
      placeBlock();
      clearLines();
      spawnBlock();
      if (gameOver) {
  drawFrame();
