Breath LED
Kit purchase
../_images/umsk_kit.png
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Universal Maker Sensor Kit
Course Introduction
In this project, we use a DHT11 sensor, an LCD, and a WS2812 LED strip.
The LCD shows temperature and humidity, while the LED strip breathes in blue, yellow, or red depending on the temperature.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Humiture Sensor Module
I2C LCD 1602
LED Strip
../_images/breath_led_bb.png
Common Connections:
  • DHT11 Humiture Sensor Module
    • DATA: Connect to 7 on the Arduino.
  • I2C LCD 1602
    • SDA: Connect to SDA on the Arduino.
    • SCL: Connect to SCL on the Arduino.
  • LED Strip
    • Din: Connect to a 330Ω resistor then to 6 on the Arduino.
    • +5V: Connect to breadboard’s passive power bus.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit_NeoPixel and install it.
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <Adafruit_NeoPixel.h>
#include "DHT.h"
// -------------------- Pins & Devices --------------------
#define LED_PIN     6
#define NUM_LEDS    8
#define DHTPIN      7           // DATA pin of 4-pin DHT11 connected to D7
#define DHTTYPE     DHT11
// I2C LCD: 16x2, common address 0x27 (if not displayed, try 0x3F)
LiquidCrystal_I2C lcd(0x27, 16, 2);
Adafruit_NeoPixel strip(NUM_LEDS, LED_PIN, NEO_GRB + NEO_KHZ800);
DHT dht(DHTPIN, DHTTYPE);
// -------------------- Breathing parameters --------------------
// One full breathing cycle (dim -> bright -> dim), unit: ms
const unsigned long BREATH_PERIOD = 3000;
// Sensor reading interval
const unsigned long SENSOR_INTERVAL = 2000;
unsigned long lastSensorRead = 0;
// LCD refresh interval
const unsigned long LCD_INTERVAL = 500;
unsigned long lastLcd = 0;
// Current sensor values
float curTemp = NAN;
float curHumi = NAN;
// Colors: Blue (≤25) / Yellow (between 25~30) / Red (≥30)
uint32_t colorBlue;
uint32_t colorYellow;
uint32_t colorRed;
// Current target color
uint32_t targetColor;
  // Optional: enable pull-up on DHT data pin, more stable for raw sensors
  pinMode(DHTPIN, INPUT_PULLUP);
  // LED strip initialization
  strip.begin();
  strip.show();           // Clear
  strip.setBrightness(0); // Start breathing from dark
  // Preset colors
  colorBlue   = strip.Color(0, 0, 255);
  colorYellow = strip.Color(255, 180, 0);
  colorRed    = strip.Color(255, 0, 0);
  // Sensor/LCD
  dht.begin();
  lcd.init();
  lcd.backlight();
  // LCD initial message
  lcd.clear();
  lcd.setCursor(0, 0); lcd.print("WS2812 Breathing");
  lcd.setCursor(0, 1); lcd.print("DHT11 + LCD Ready");
  delay(800);
  lcd.clear();
  const unsigned long now = millis();
  // ---- Timed DHT11 read ----
  if (now - lastSensorRead >= SENSOR_INTERVAL) {
    lastSensorRead = now;
    curTemp = dht.readTemperature(); // Celsius
    curHumi = dht.readHumidity();
    // Select color based on rule:
    // ≤25 -> Blue; ≥30 -> Red; (25,30) -> Yellow
    if (!isnan(curTemp)) {
      if (curTemp <= 25.0) {
        targetColor = colorBlue;
      } else if (curTemp >= 30.0) {
        targetColor = colorRed;
      } else {
        targetColor = colorYellow;
    } else {
      // If read fails, keep last color or default to Yellow
  // ---- Breathing brightness (non-blocking) ----
  uint8_t brightness = breatheBrightness(now, BREATH_PERIOD);
  strip.setBrightness(brightness);
  // All LEDs same color
  for (int i = 0; i < NUM_LEDS; i++) {
    strip.setPixelColor(i, targetColor);
  strip.show();
  // ---- Timed LCD update ----
  if (now - lastLcd >= LCD_INTERVAL) {
    lastLcd = now;
    lcd.print("T:");
    if (isnan(curTemp)) lcd.print("--.-");
    else                printPadded(lcd, curTemp, 4, 1); // width=4, 1 decimal place
    lcd.print("C H:");
    if (isnan(curHumi)) lcd.print("--");
    else                printPadded(lcd, curHumi, 2, 0);
    lcd.print("%  ");
    lcd.print("Mode:");
    if (targetColor == colorBlue)      lcd.print("BLUE     ");
    else if (targetColor == colorRed)  lcd.print("RED      ");
    else                               lcd.print("YELLOW   ");
// Calculate 0..255 breathing brightness (sine wave: 0->255->0)
uint8_t breatheBrightness(unsigned long t, unsigned long period) {
  float phase = (2.0f * PI) * ( (t % period) / (float)period );
  float s = (sinf(phase) + 1.0f) * 0.5f;   // 0..1
  int val = (int)(s * 255.0f);
  if (val < 0)   val = 0;
  if (val > 255) val = 255;
  return (uint8_t)val;
// Print value to LCD with fixed width/decimals (pad with spaces to avoid ghosting)
void printPadded(LiquidCrystal_I2C &lcdRef, float value, int width, int decimals) {
  char buf[16];
  dtostrf(value, width + (decimals ? (decimals + 1) : 0), decimals, buf); // width includes decimal point
  lcdRef.print(buf);
