Radar Guard 11.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
This project creates a servo-based ultrasonic scanner with LEDs and a buzzer. The ultrasonic sensor sweeps left and right to detect objects. When something gets too close, the red LED and buzzer turn on as an alarm, and when the area is safe, the green LED lights up.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Ultrasonic Sensor Module
1kΩ resistor
Digital Servo Motor
Active Buzzer
LED
Button
../_images/Radar_Guard11.0_bb.png
Common Connections:
  • Red LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to 3 on the Arduino.
  • Green LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to 4 on the Arduino.
  • Button Left
    • Connect to the breadboard’s negative power bus, and the other end to 8 on the Arduino board.
  • Button Right
    • Connect to the breadboard’s negative power bus, and the other end to 9 on the Arduino board.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 12 on the Arduino.
  • Active Buzzer
    • +: Connect to 2 on the Arduino.
  • Ultrasonic Sensor Module
    • Trig: Connect to 11 on the Arduino.
    • Echo: Connect to 10 on the Arduino.
Writing the Code
  • Build the circuit.
  • Upload the code to the Arduino board using Arduino IDE.
  • In the Arduino IDE, check the current Arduino port(COMx).
  • The ArduinoRadarGUI is used here. You can click here Radar_Guard11.0.zip to download it.
  • Open ArduinoLidarGUI.pde in the Processing IDE .
  • Modify the code in line 35 to ensure the correct port number(COMx).
  • Run the Processing sketch to visualize the radar data.
#include <Servo.h>
// Ultrasonic sensor pins
const int trigPin   = 11;
const int echoPin   = 10;
// Output devices
const int servoPin  = 12;
const int buzzerPin = 2;    // Active buzzer: HIGH = sound
const int ledGreen = 4;
const int ledRed   = 3;
// Control buttons
// Blue button: rotate servo to the right
// Red button: rotate servo to the left
const int btnBlue = 8;
const int btnRed  = 9;
// Servo control
Servo radarServo;
int currentAngle = 90;      // Start from center position
int servoDir = 0;           // -1 = left, 0 = stop, 1 = right
const int servoStep = 1;    // Move 1 degree each update
const unsigned long servoInterval = 20;
unsigned long lastServoMillis = 0;
// Direction hold (fix for button switching issue)
unsigned long lastDirChangeMillis = 0;
const unsigned long dirHoldTime = 50; // ms
// Ultrasonic detection
const int alertDistance = 20;   // Alarm distance (cm)
int triggerCount = 0;
unsigned long lastPingMillis = 0;
const unsigned long pingInterval = 60;
// System state
enum RadarState { SAFE, ALERT };
RadarState radarState = SAFE;
// Alarm blinking control
unsigned long lastAlertMillis = 0;
bool alertToggle = false;
const unsigned long alertInterval = 120;
// Last valid distance for radar output
int lastDistance = 40;
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(ledGreen, OUTPUT);
  pinMode(ledRed, OUTPUT);
  pinMode(btnBlue, INPUT_PULLUP);
  pinMode(btnRed, INPUT_PULLUP);
  radarServo.attach(servoPin);
  radarServo.write(currentAngle);
  digitalWrite(ledGreen, HIGH);
  digitalWrite(ledRed, LOW);
  digitalWrite(buzzerPin, LOW);
  Serial.begin(9600);
  readButtons();
  updateServo();
  updateDistance();
  handleAlert();
  sendRadarData();
void readButtons() {
  bool bluePressed = (digitalRead(btnBlue) == LOW);
  bool redPressed  = (digitalRead(btnRed)  == LOW);
  if (bluePressed) {
    servoDir = 1;   // Rotate right
    lastDirChangeMillis = millis();
  else if (redPressed) {
    servoDir = -1;  // Rotate left
  else {
    // Keep last direction for a short time
    if (millis() - lastDirChangeMillis > dirHoldTime) {
      servoDir = 0;
void updateServo() {
  if (millis() - lastServoMillis >= servoInterval) {
    lastServoMillis = millis();
    currentAngle += servoDir * servoStep;
    currentAngle = constrain(currentAngle, 0, 180);
void updateDistance() {
  // Skip distance check during alarm
  if (radarState == ALERT) return;
  if (millis() - lastPingMillis < pingInterval) return;
  lastPingMillis = millis();
  int distance = getDistance();
  if (distance <= 0) return;
  lastDistance = distance;
  if (distance < alertDistance) {
    triggerCount++;
  } else {
    triggerCount = 0;
  if (triggerCount >= 5) {
    radarState = ALERT;
void handleAlert() {
  if (radarState == ALERT) {
    if (millis() - lastAlertMillis >= alertInterval) {
      lastAlertMillis = millis();
      alertToggle = !alertToggle;
      digitalWrite(ledRed, alertToggle);
      digitalWrite(buzzerPin, alertToggle);
      digitalWrite(ledGreen, LOW);
    int dist = getDistance();
    if (dist >= alertDistance && dist > 0) {
      radarState = SAFE;
      triggerCount = 0;
  else {
void sendRadarData() {
  // Processing expects: angle,distance.
  Serial.print(currentAngle);
  Serial.print(",");
  Serial.print(lastDistance);
  Serial.print(".");
int getDistance() {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(echoPin, HIGH, 12000);
  if (duration == 0) return -1;
  return duration * 0.034 / 2;
