Radar Guard 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, we will learn how to use the Ultrasonic Sensor Module, Digital Servo Motor, and I2C LCD 1602 with the Arduino Board to create a radar defense system version 2.0.
When the ultrasonic sensor module is running, it emits an audible alarm and flashes the red LED if it detects an obstacle within its sensing range. If no obstacle is detected, indicating a safe state, the green LED stays on.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Ultrasonic Sensor Module |
7 |
LED |
8 |
I2C LCD 1602 |
9 |
Digital Servo Motor |
10 |
Passive Buzzer |
Common Connections:
LED
Connect the LEDs anode to a 1kΩ resistor then to the 3, 4 on Arduino, and the LEDs cathode to negative power bus on the breadboard.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 12 on the Arduino.
Passive Buzzer
+: Connect to 2 on the Arduino.
-: Connect to breadboard’s negative power bus.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Trig: Connect to 11 on the Arduino.
Echo: Connect to 10 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
#include <Wire.h>
// Servo and ultrasonic sensor
Servo radarServo;
const int trigPin = 11;
const int echoPin = 10;
const int servoPin = 12;
// LEDs and passive buzzer (controlled by tone()/noTone())
const int redLed = 3;
const int greenLed = 4;
const int buzzer = 2;
// I2C LCD (address 0x27, 16×2 characters)
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Configuration parameters
const int alertDistance = 30; // distance threshold for alert (cm)
const unsigned long updateInterval = 20; // servo scan interval (ms)
const int triggerThreshold = 2; // number of consecutive detections needed
const unsigned long displayDuration = 500; // LCD display time (ms)
const unsigned long blinkInterval = 200; // LED blink interval (ms)
// Scanning state
int currentAngle = 0;
int increment = 1;
unsigned long lastServoUpdate = 0;
// Alert control
bool displayAlarm = false; // whether showing text on LCD
bool alarmActive = false; // whether in blink alert state
int triggerCount = 0;
int detectedAngle = 0;
unsigned long displayStartTime = 0;
unsigned long lastBlinkTime = 0;
bool blinkState = false;
radarServo.attach(servoPin);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
// buzzer uses tone()/noTone(), no pinMode needed
lcd.init();
lcd.backlight();
lcd.clear();
// show idle state
lcdSetEmpty();
digitalWrite(greenLed, HIGH);
unsigned long now = millis();
// 1. Smooth scanning & distance measurement
if (now - lastServoUpdate >= updateInterval) {
lastServoUpdate = now;
radarServo.write(currentAngle);
if (currentAngle % 5 == 0) {
float d = getDistance();
// if not already showing or blinking an alert
if (!displayAlarm && !alarmActive) {
if (d < alertDistance) triggerCount++;
else triggerCount = 0;
if (triggerCount >= triggerThreshold) {
triggerCount = 0;
detectedAngle = currentAngle;
startAlarmDisplay();
// if currently blinking and object is out of range, exit alert
else if (alarmActive && d >= alertDistance) {
exitAlarm();
// update servo angle back and forth between 0°–180°
currentAngle += increment;
if (currentAngle >= 180) {
currentAngle = 180; increment = -1;
} else if (currentAngle <= 0) {
currentAngle = 0; increment = 1;
// 2. Manage LCD display duration & transition to blinking
if (displayAlarm) {
// if display time has passed, switch to blinking state
if (now - displayStartTime >= displayDuration) {
alarmActive = true;
lastBlinkTime = now;
else if (alarmActive) {
alarmBlink();
// start showing alert text (for displayDuration)
void startAlarmDisplay() {
displayAlarm = true;
displayStartTime = millis();
digitalWrite(greenLed, LOW);
digitalWrite(redLed, LOW);
noTone(buzzer);
lcd.clear();
// first line: centered "{detectedAngle}°"
char buf[6];
sprintf(buf, "%d", detectedAngle);
int len1 = strlen(buf) + 1;
int start1 = (16 - len1) / 2;
lcd.setCursor(start1, 0);
lcd.print(buf);
lcd.write(223);
// second line: centered "Foreign Body"
const char* msg = "Foreign Body";
int len2 = strlen(msg);
int start2 = (16 - len2) / 2;
lcd.setCursor(start2, 1);
lcd.print(msg);
// non-blocking blink of red LED and buzzer
void alarmBlink() {
if (now - lastBlinkTime >= blinkInterval) {
blinkState = !blinkState;
digitalWrite(redLed, blinkState);
if (blinkState) tone(buzzer, 1000);
else noTone(buzzer);
// exit alert and return to idle state
void exitAlarm() {
triggerCount = 0;
noTone(buzzer);
lcdSetEmpty();
// show idle state on LCD
void lcdSetEmpty() {
lcd.clear();
lcd.setCursor(1, 0);
lcd.print("Area is Empty");
// perform ultrasonic distance measurement (cm)
float getDistance() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
long duration = pulseIn(echoPin, HIGH, 30000);
return duration * 0.034 / 2;
