Flame Monitor 4.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll learn how to use a Flame Sensor, DC Motor, an I2C LCD Display, and the Arduino UNO R4 to monitor fire intensity. The LCD shows real-time readings, while buzzer provide sound alerts for different flame levels.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Flame Sensor Module |
Buzzer Modudle |
7 |
I2C LCD 1602 |
8 |
TA6586 - Motor Driver Chip |
9 |
DC Motor |
Common Connections:
Flame Sensor Module
A0: Connect to A0 on the Arduino.
Buzzer Modudle
I/O: Connect to 10 on the Arduino.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
BI: Connect to 6 on the Arduino.
FI: Connect to 5 on the Arduino.
DC Motor
GND: Connect to TA6586 B0.
VCC: Connect to TA6586 F0.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal_I2C and install it.
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
#include <Wire.h>
// Pin definitions
const int sensorPin = A0; // Flame sensor analog pin
const int buzzerPin = 10; // Buzzer pin
// TA6586 motor driver pins
const int fanFI = 5; // TA6586 FI
const int fanBI = 6; // TA6586 BI
// Threshold values
const int safeThreshold = 200;
const int dangerThreshold = 700;
// LCD object (address 0x27, 16 columns, 2 rows)
LiquidCrystal_I2C lcd(0x27, 16, 2);
int flameValue = 0;
enum FanState {
FAN_STOP,
FAN_LOW,
FAN_HIGH
FanState currentFanState = FAN_STOP;
Serial.begin(9600);
lcd.init();
lcd.backlight();
pinMode(buzzerPin, OUTPUT);
pinMode(fanFI, OUTPUT);
pinMode(fanBI, OUTPUT);
stopFan();
// Startup screen
lcd.setCursor(0, 0);
lcd.print("Flame Monitor");
lcd.setCursor(0, 1);
lcd.print("Initializing");
delay(1200);
lcd.clear();
// Read sensor value
int rawValue = analogRead(sensorPin);
// Convert to intuitive value
flameValue = 1023 - rawValue;
// Serial output for debugging
Serial.print("Raw: ");
Serial.print(rawValue);
Serial.print(" Flame Value: ");
Serial.print(flameValue);
Serial.print(" Fan State: ");
// Status detection
if (flameValue < safeThreshold) {
displayStatus("Status: Safe");
noTone(buzzerPin);
stopFan();
Serial.println("STOP");
else if (flameValue < dangerThreshold) {
displayStatus("Status: Warning");
tone(buzzerPin, 800, 200);
runFanLow();
Serial.println("LOW");
else {
displayStatus("Status: Danger");
tone(buzzerPin, 1000, 400);
runFanHigh();
Serial.println("HIGH");
// Display value
lcd.print("Value: ");
lcd.print(flameValue);
lcd.print(" "); // Clear extra digits if needed
delay(200);
// Function to display status on first row
void displayStatus(const char* text) {
lcd.print(" ");
lcd.print(text);
// Fan control functions
void stopFan() {
if (currentFanState != FAN_STOP) {
Serial.println("Executing stopFan()");
analogWrite(fanFI, 0);
analogWrite(fanBI, 0);
digitalWrite(fanFI, LOW);
digitalWrite(fanBI, LOW);
void runFanLow() {
if (currentFanState != FAN_LOW) {
analogWrite(fanFI, 150); // lower speed
currentFanState = FAN_LOW;
void runFanHigh() {
if (currentFanState != FAN_HIGH) {
analogWrite(fanFI, 255); // full speed
currentFanState = FAN_HIGH;
