Servo Control 2.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Inventor Lab Kit
Arduino Uno R3
Course Introduction
This Arduino project lets you control a servo motor with two buttons: the red button moves it toward 0° and the blue button toward 180°, with LEDs lighting up as feedback.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Digital Servo Motor
Button
LED
../_images/Servo_Control2.0_bb.png
Common Connections:
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 3 on the Arduino.
  • Button1
    • GND: Connect to a 1kΩ resistor, then to negative power bus on the breadboard
    • VCC: Connect to 7 on the Arduino.
  • Button2
    • VCC: Connect to 5 on the Arduino.
  • Blue LED
    • Connect the LED cathode to the to a 1kΩ resistor, then to negative power bus on the breadboard, anode to 6 on the Arduino.
  • Red LED
    • Connect the LED cathode to the to a 1kΩ resistor, then to negative power bus on the breadboard, anode to 4 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
// --- Pin definitions ---
const int servoPin = 3;   // Servo signal wire connected to pin 3
const int redLED   = 4;   // Red LED connected to pin 4 (with resistor)
const int redBtn   = 5;   // Red button connected to pin 5
const int blueLED  = 6;   // Blue LED connected to pin 6 (with resistor)
const int blueBtn  = 7;   // Blue button connected to pin 7
Servo myServo;             // Create a Servo object
int currentAngle = 90;     // Start servo at the middle position (90°)
const int stepSize = 5;    // Servo moves 3° for each button press
// Variables to remember the last button states
bool lastRedState  = HIGH; // HIGH means not pressed (because of INPUT_PULLUP)
bool lastBlueState = HIGH;
  myServo.attach(servoPin);       // Attach the servo to pin 3
  myServo.write(currentAngle);    // Move servo to initial position
  pinMode(redLED, OUTPUT);        // Set LED pins as outputs
  pinMode(blueLED, OUTPUT);
  pinMode(redBtn, INPUT_PULLUP);  // Use internal pull-up resistor
  pinMode(blueBtn, INPUT_PULLUP); // Button is active LOW
  // Read current button states
  bool redPressed  = (digitalRead(redBtn)  == LOW); // LOW means pressed
  bool bluePressed = (digitalRead(blueBtn) == LOW);
  // --- Red button logic ---
  if (redPressed && lastRedState == HIGH) { // Detect new press (not held down)
    delay(50);                              // Small delay to debounce
    if (digitalRead(redBtn) == LOW) {       // Check again to confirm press
      digitalWrite(redLED, HIGH);           // Turn on red LED
      currentAngle = max(0, currentAngle - stepSize); // Move 3° toward 0°
      myServo.write(currentAngle);          // Update servo position
  } else {
    digitalWrite(redLED, LOW);              // Turn off LED when not pressed
  // --- Blue button logic ---
  if (bluePressed && lastBlueState == HIGH) { // Detect new press
    delay(50);                                // Debounce
    if (digitalRead(blueBtn) == LOW) {        // Confirm press
      digitalWrite(blueLED, HIGH);            // Turn on blue LED
      currentAngle = min(180, currentAngle + stepSize); // Move 3° toward 180°
  } else {
    digitalWrite(blueLED, LOW);               // Turn off LED when not pressed
  // Remember button states for next loop
  lastRedState  = redPressed;
  lastBlueState = bluePressed;
