Extinguisher
Kit purchase
../_images/umsk_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, you’ll use two servo motors, a Flame Sensor Module, a water pump driven by an L9110 motor driver, and Arduino to create a tracking fire extinguisher system.
The servos continuously scan the area with the flame sensor and water pump. When a flame is detected, the pump automatically activates to spray water toward the detected direction, creating a simple fire tracking and extinguishing effect.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Power Supply
Digital Servo Motor
L9110 Motor Driver Module
Centrifugal Pump
Flame Sensor Module
../_images/tracking_extinguisher_bb.png
Common Connections:
  • Digital Servo Motor (flame)
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
  • Digital Servo Motor (pump)
    • Connect to 10 on the Arduino.
  • L9110 Motor Driver Module
    • A-1A: Connect to 5 on the Arduino.
    • A-1B: Connect to 6 on the Arduino.
  • Centrifugal Pump
    • Connect to L9110 Motor Driver Module MOTOR A.
  • Flame Sensor Module
    • D0: Connect to 2 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
// Servo pins
const int FLAME_SERVO_PIN = 9;
const int PUMP_SERVO_PIN = 10;
// Flame sensor pin
const int FLAME_PIN = 2;
// L9110 motor driver pins
const int PUMP_IN1 = 5;
const int PUMP_IN2 = 6;
// Servo objects
Servo flameServo;
Servo pumpServo;
// Servo scan settings
const int SCAN_LEFT = 45;
const int SCAN_RIGHT = 135;
const int SCAN_STEP = 2;
const int SERVO_DELAY = 30;
// Flame sensor logic
// Most flame sensor modules output LOW when flame is detected.
// If your module works the opposite way, change LOW to HIGH.
const int FLAME_DETECTED_STATE = LOW;
int currentAngle = SCAN_LEFT;
int direction = 1;
void pumpOn() {
  digitalWrite(PUMP_IN1, HIGH);
  digitalWrite(PUMP_IN2, LOW);
void pumpOff() {
  digitalWrite(PUMP_IN1, LOW);
  pinMode(FLAME_PIN, INPUT);
  pinMode(PUMP_IN1, OUTPUT);
  pinMode(PUMP_IN2, OUTPUT);
  flameServo.attach(FLAME_SERVO_PIN);
  pumpServo.attach(PUMP_SERVO_PIN);
  flameServo.write(currentAngle);
  pumpServo.write(currentAngle);
  pumpOff();
  int flameState = digitalRead(FLAME_PIN);
  bool flameDetected = (flameState == FLAME_DETECTED_STATE);
  if (flameDetected) {
    pumpOn();
  } else {
    pumpOff();
    currentAngle += direction * SCAN_STEP;
    if (currentAngle >= SCAN_RIGHT) {
      currentAngle = SCAN_RIGHT;
      direction = -1;
    if (currentAngle <= SCAN_LEFT) {
      direction = 1;
  delay(SERVO_DELAY);
