Speed Detection 3.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project functions as a basic speed detection system using two Ultrasonic Sensor Modules and an LCD display and buzzer moudle. When an object passes the first sensor, a timer starts; it stops at the second sensor.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
I2C LCD 1602
Buzzer Modudle
../_images/Speed_Detection3.0_bb.png
Common Connections:
  • I2C LCD 1602
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
  • Ultrasonic Sensor Module Front
    • Trig: Connect to 4 on the Arduino.
    • Echo: Connect to 3 on the Arduino.
  • Ultrasonic Sensor Module Back
    • Trig: Connect to 11 on the Arduino.
    • Echo: Connect to 10 on the Arduino.
  • Buzzer Module
    • I/0: Connect to 9 on the Arduino.
    • +: Connect to breadboard’s red power bus.
    • -: Connect to breadboard’s negative power bus.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
// ---------------- LCD ----------------
// I2C LCD (address: 0x27, 16x2)
LiquidCrystal_I2C lcd(0x27, 16, 2);
// ---------------- Ultrasonic Sensor Pins ----------------
// Front ultrasonic sensor
#define TRIG1 4
#define ECHO1 3
// Back ultrasonic sensor
#define TRIG2 11
#define ECHO2 10
// ---------------- Passive Buzzer ----------------
#define BUZZER_PIN 9
// ---------------- Parameters ----------------
float gateDistance = 1.30;   // Distance between two sensors (meters)
float speedLimit   = 40.0;   // Speed limit (km/h)
float triggerDist  = 15.0;   // Detection distance (cm)
// ---------------- State Variables ----------------
bool firstGateTriggered = false;
bool speedCalculated    = false;
unsigned long t1 = 0;
unsigned long t2 = 0;
// ---------------- Ultrasonic Distance Function ----------------
// Measure distance using ultrasonic sensor (return: cm)
float getDistanceCM(int trigPin, int echoPin) {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(echoPin, HIGH, 30000);
  if (duration == 0) return -1;
  return duration * 0.034 / 2;
  // Set pin modes for ultrasonic sensors
  pinMode(TRIG1, OUTPUT);
  pinMode(ECHO1, INPUT);
  pinMode(TRIG2, OUTPUT);
  pinMode(ECHO2, INPUT);
  // Set buzzer pin as output
  pinMode(BUZZER_PIN, OUTPUT);
  // Initialize LCD
  lcd.init();
  lcd.backlight();
  // Show startup message
  lcd.setCursor(0, 0);
  lcd.print("Speed Detector");
  lcd.setCursor(0, 1);
  lcd.print("Waiting...");
  // Read distances from both ultrasonic sensors
  float d1 = getDistanceCM(TRIG1, ECHO1);
  delay(40);  // Prevent ultrasonic interference
  float d2 = getDistanceCM(TRIG2, ECHO2);
  // First sensor detects object
  if (!firstGateTriggered && d1 > 0 && d1 < triggerDist) {
    firstGateTriggered = true;
    t1 = millis();
    lcd.clear();
    lcd.print("Vehicle detected");
    lcd.print("Measuring...");
  // Second sensor detects object
  if (firstGateTriggered && !speedCalculated && d2 > 0 && d2 < triggerDist) {
    t2 = millis();
    speedCalculated = true;
    float deltaT = (t2 - t1) / 1000.0;
    lcd.clear();
    if (deltaT > 0.05) {  // Ignore false trigger
      float speed = (gateDistance / deltaT) * 3.6;
      lcd.print("Speed:");
      lcd.print(speed, 1);
      lcd.print("km/h");
      if (speed > speedLimit) {
        lcd.print("Over Speed!");
        // Beep 3 times
        for (int i = 0; i < 3; i++) {
          tone(BUZZER_PIN, 2000);
          delay(200);
          noTone(BUZZER_PIN);
          delay(200);
      } else {
        lcd.print("Normal");
    } else {
      lcd.print("Invalid data");
    delay(3000);
    // Reset system
    lcd.clear();
