Pocket Arcade
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll use an OLED display, input controls, and a game manager system with Arduino to create a retro-style arcade game.
Players interact through button inputs to control on-screen actions, while the game manager updates the gameplay at ~60 FPS. The system includes an intro screen, high-score tracking, and smooth frame rendering for an engaging experience.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Button |
OLED Display Module |
Common Connections:
OLED Display Module
SDA: Connect to A4 on the Arduino.
SCK: Connect to A5 on the Arduino.
Button
button1: Connect to the breadboard’s negative power bus, and the other end to 2 on the Arduino board.
button2: Connect to the breadboard’s negative power bus, and the other end to 3 on the Arduino board.
button3: Connect to the breadboard’s negative power bus, and the other end to 10 on the Arduino board.
button4: Connect to the breadboard’s negative power bus, and the other end to 11 on the Arduino board.
Writing the Code
Use the C code
Pocket_Arcade. You can click herePocket_Arcade.zipto download it.To install the library, use the Arduino Library Manager and search for config and display and gamemanager and highscore and install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
// GameSystem.ino - Hack_updt
#include "config.h"
#include "display.h"
#include "input.h"
#include "gamemanager.h"
#include "highscore.h"
void intro(){
display.clearDisplay();
display.drawBitmap(0, 0, epd_bitmap_Intro, 128, 64, 1);
display.display();
Serial.begin(115200);
initDisplay();
intro();
delay(12000);
initInput();
initHighscores();
initGameManager();
updateInput();
updateGameManager();
delay(16); // ~60 FPS
