LED control 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you will use Arduino together with two IR obstacle sensors and a row of LEDs to create an automatic directional light-flow effect.
When the left sensor detects an object, the LEDs light up in a forward flowing pattern. When the right sensor is triggered, the LEDs flow in the opposite direction.
Each sensor controls one direction of the animation, allowing the LEDs to respond dynamically based on which side an obstacle is detected.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Several |
IR Obstacle Avoidance Sensor Module |
7 |
LED |
Several |
Common Connections:
LED
Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to 1kΩ resistor then to 5 to 10 on the Arduino.
IR Obstacle Avoidance Sensor Module 1
OUT: Connect to 3 on the Arduino.
IR Obstacle Avoidance Sensor Module 2
OUT: Connect to 12 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// Obstacle sensors
// These sensors output LOW when an object is detected
const int sensorLeft = 3; // Triggers forward flow
const int sensorRight = 12; // Triggers backward flow
// LED pins in order from left to right
const int ledPins[] = {5, 6, 7, 8, 9, 10};
const int ledCount = 6;
// Time between LED steps
int delayTime = 80;
// Set all LEDs as outputs
for (int i = 0; i < ledCount; i++) {
pinMode(ledPins[i], OUTPUT);
// Sensors are digital inputs
pinMode(sensorLeft, INPUT);
pinMode(sensorRight, INPUT);
// Read sensors (LOW means obstacle found)
bool leftDetected = (digitalRead(sensorLeft) == LOW);
bool rightDetected = (digitalRead(sensorRight) == LOW);
// Forward flow: LEDs move from pin 5 → 10
if (leftDetected) {
digitalWrite(ledPins[i], HIGH); // Light current LED
delay(delayTime);
if (i > 0) {
digitalWrite(ledPins[i - 1], LOW); // Turn off previous LED
digitalWrite(ledPins[ledCount - 1], LOW); // Clear last LED
// Backward flow: LEDs move from pin 10 → 5
if (rightDetected) {
for (int i = ledCount - 1; i >= 0; i--) {
delay(delayTime);
if (i < ledCount - 1) {
digitalWrite(ledPins[i + 1], LOW); // Turn off previous LED
digitalWrite(ledPins[0], LOW); // Clear last LED
