Running Light 1.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you will learn how to use Arduino with LEDs, a potentiometer, a button, and an active buzzer to create a running light effect.
Rotate the potentiometer to adjust the speed of the flowing LEDs. Press the button to pause the light at its current position or resume the animation, while the buzzer beeps in sync with the movement.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
220 resistor
Several
Button
LED
Several
Active Buzzer
Potentiometer Sensor Module
../_images/flow_light_bb.png
Common Connections:
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to a 220Ω resistor then to 3 to 10 on the Arduino.
  • Button
    • Connect to breadboard’s negative power bus.
    • Connect to 2 on the Arduino.
  • Active Buzzer
    • +: Connect to 11 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Potentiometer Sensor Module
    • OUT: Connect to A0 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// LED pins
const int ledPins[] = {3, 4, 5, 6, 7, 8, 9, 10};
const int ledCount = 8;
// Potentiometer pin
const int POT_PIN = A0;
// Button pin
const int BUTTON_PIN = 2;
// Active buzzer pin
const int BUZZER_PIN = 11;
int currentLed = 0;
bool isRunning = true;
unsigned long lastLedTime = 0;
unsigned long lastButtonTime = 0;
unsigned long buzzerStartTime = 0;
const unsigned long debounceDelay = 200;
const unsigned long buzzerBeepTime = 40;
bool lastButtonState = HIGH;
bool buzzerActive = false;
  for (int i = 0; i < ledCount; i++) {
    pinMode(ledPins[i], OUTPUT);
    digitalWrite(ledPins[i], LOW);
  pinMode(BUTTON_PIN, INPUT_PULLUP);
  pinMode(BUZZER_PIN, OUTPUT);
  digitalWrite(BUZZER_PIN, LOW);
  digitalWrite(ledPins[currentLed], HIGH);
  handleButton();
  handleBuzzer();
  if (isRunning) {
    int potValue = analogRead(POT_PIN);
    // Adjust flowing speed with the potentiometer
    int flowDelay = map(potValue, 0, 1023, 80, 800);
    if (millis() - lastLedTime >= flowDelay) {
      lastLedTime = millis();
      digitalWrite(ledPins[currentLed], LOW);
      currentLed++;
      if (currentLed >= ledCount) {
        currentLed = 0;
      beepOnce();
void handleButton() {
  bool currentButtonState = digitalRead(BUTTON_PIN);
  if (lastButtonState == HIGH && currentButtonState == LOW) {
    if (millis() - lastButtonTime > debounceDelay) {
      isRunning = !isRunning;
      lastButtonTime = millis();
      beepOnce();
      if (!isRunning) {
        delay(60);
  lastButtonState = currentButtonState;
void beepOnce() {
  digitalWrite(BUZZER_PIN, HIGH);
  buzzerStartTime = millis();
  buzzerActive = true;
void handleBuzzer() {
  if (buzzerActive && millis() - buzzerStartTime >= buzzerBeepTime) {
