Radar Guard 4.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This project implements a basic radar system using an Arduino Uno, a servo motor, an ultrasonic sensor (HC-SR04), an LED, and a buzzer.
The system scans the environment by rotating the ultrasonic sensor between 15 and 165 degrees, measuring distances to nearby objects.
If an object is detected within 15 cm, an LED lights up, and a buzzer sounds. The angle and distance data are sent to the serial port, allowing for real-time visualization using the Processing IDE.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R3 |
USB Type-C cable |
Breadboard |
Wires |
Several |
Ultrasonic Sensor Module |
Digital Servo Motor |
7 |
Active Buzzer |
8 |
LED |
9 |
Transistor |
1(S8050) |
10 |
1kΩ resistor |
Common Connections:
LED
Connect the LEDs cathode tot the negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to 4 on the Arduino.
transistor
emitter: Connect to breadboard’s negative power bus.
base: Connect a 1kΩ resistor then to 5 on the Arduino.
collector: Connect to the buzzer.
Buzzer
+: Connect to breadboard’s positive power bus.
-: Connect to transistor .
Digital Servo Motor
Connect to 12 on the Arduino.
Trig: Connect to 10 on the Arduino.
Echo: Connect to 11 on the Arduino.
Writing the Code
Build the circuit.
Upload the code to the Arduino board using Arduino IDE.
In the Arduino IDE, check the current Arduino port(COMx).
The
ArduinoSonarGUIis used here. You can click hereArduinoSonarGUI.zipto download it.Open ArduinoSonarGUI.pde in the Processing IDE .
Modify the code in line 35 to ensure the correct port number(COMx).
Run the Processing sketch to visualize the sonar data.
arduino code
This code controls a servo motor to rotate an ultrasonic sensor and measure distances.
The sensor scans from 15 to 165 degrees and back, calculating the distance to objects
and sending the angle and distance data to the serial port. The data can be used in the
Processing IDE to visualize a real-time radar.
An LED and buzzer are activated if an object is detected within 15 cm.
Board: Arduino Uno R4 (or R3)
Component: Ultrasonic distance Sensor(HC-SR04)
Source Code From:https://howtomechatronics.com/projects/arduino-radar-project/
Modified by wulu from SunFounder 2024.08
#include <Servo.h> // Include Servo library
// Define pins for the ultrasonic sensor
const int trigPin = 10;
const int echoPin = 11;
// Variables for measuring distance
long duration;
int distance;
const int servoPin = 12;
Servo myServo; // Create a Servo object to control the motor
const int ledPin = 4; // Pin for LED
const int buzzerPin = 5; // Pin for Buzzer
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
pinMode(ledPin, OUTPUT); // Set ledPin as an OUTPUT
pinMode(buzzerPin, OUTPUT); // Set buzzerPin as an OUTPUT
Serial.begin(9600);
myServo.attach(servoPin); // Defines on which pin is the servo motor attached
// rotates the servo motor from 15 to 165 degrees
for (int i = 15; i <= 165; i++) {
myServo.write(i); // Set servo position
delay(30); // Wait for the servo to reach the position
distance = calculateDistance(); // Measure distance at this angle
handleAlerts(); // Check distance and handle alerts
Serial.print(i); // Sends the current degree into the Serial Port
Serial.print(","); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
Serial.print(distance); // Sends the distance value into the Serial Port
Serial.print("."); // Sends addition character right next to the previous value needed later in the Processing IDE for indexing
// Repeats the previous lines from 165 to 15 degrees
for (int i = 165; i > 15; i--) {
myServo.write(i);
delay(30);
Serial.print(i);
Serial.print(",");
Serial.print(".");
// Function to read the sensor data and calculate the distance
int calculateDistance() {
digitalWrite(trigPin, LOW); // Set trig pin to low to ensure a clean pulse
delayMicroseconds(2); // Delay for 2 microseconds
digitalWrite(trigPin, HIGH); // Send a 10 microsecond pulse by setting trig pin to high
delayMicroseconds(10);
digitalWrite(trigPin, LOW); // Set trig pin back to low
// Measure the pulse width of the echo pin and calculate the distance value
float distance = pulseIn(echoPin, HIGH) / 58.00; // Formula: (340m/s * 1us) / 2
return distance;
void handleAlerts() {
// Activate LED and buzzer if object is within 15 cm
if (distance <= 15) {
digitalWrite(ledPin, HIGH); // Turn on LED
tone(buzzerPin, 500); // Turn on Buzzer with a 500 Hz tone
} else {
digitalWrite(ledPin, LOW); // Turn off LED
noTone(buzzerPin); // Turn off Buzzer
