RFID Access4.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Inventor Lab Kit
Arduino Uno R3
Course Introduction
In this lesson, we’ll build a 4.0 access-control system using the MFRC522 module, leds, a digital servo motor, and gas sensor module.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
MQ-2 Gas Sensor Module
LED
MFRC522 Module
Power Supply Module
Digital Servo Motor
1kΩ resistor
../_images/RFID_Access4.0_bb.png
Common Connections:
  • MFRC522 Module
    • IRQ: Connect to 7 on the Arduino.
    • SDA: Connect to 6 on the Arduino.
    • SCK: Connect to 5 on the Arduino.
    • MOSI: Connect to 4 on the Arduino.
    • MISO: Connect to 3 on the Arduino.
    • RST: Connect to 2 on the Arduino.
    • 3.3V: Connect to breadboard’s passive power bus.
  • MQ-2 Gas Sensor Module
    • A0: Connect to A0 on the Arduino.
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to 1kΩ resistor then to 11 on the Arduino.
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
Writing the Code
  • The RFID1 library is used here. You can click here RFID1.zip to download it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <rfid1.h>      // Library for RFID reader
#include <Servo.h>      // Library for servo motor
#define ID_LEN 4
RFID1 rfid;
Servo myServo;
// Pin setup
const int servoPin  = 9;
const int ledPin    = 11;
const int smokePin  = A0;
// Your RFID card UID
uchar userId[ID_LEN] = {0x36, 0xE2, 0xC4, 0xF7};
uchar userIdRead[ID_LEN];
// Smoke threshold (>200 = danger)
const int smokeThreshold = 200;
// State flags
bool smokeAlert       = false;
bool smokeRecovering  = false;
unsigned long smokeRecoverStart = 0;
bool cardAction       = false;     // Door opened by valid card
unsigned long cardTimer = 0;
int targetPos  = 0;   // Target position for servo
int currentPos = 0;   // Current position for servo
// Set target angle for servo
void setServoAngle(int angle) {
  targetPos = constrain(angle, 0, 90);
// Move servo smoothly (non-blocking)
void servoSmoothRun() {
  static unsigned long lastStep = 0;
  if (millis() - lastStep >= 15) {
    lastStep = millis();
    if (currentPos < targetPos) currentPos++;
    else if (currentPos > targetPos) currentPos--;
    myServo.write(currentPos);
// Blink LED without delay()
void ledBlinkNonBlock() {
  static unsigned long lastBlink = 0;
  static bool ledState = false;
  if (millis() - lastBlink >= 120) {
    lastBlink = millis();
    ledState = !ledState;
    digitalWrite(ledPin, ledState);
// Read UID from RFID card
void getId() {
  uchar status, str[MAX_LEN];
  status = rfid.anticoll(str);
  if (status == MI_OK) {
    for (int i = 0; i < ID_LEN; i++) userIdRead[i] = str[i];
    rfid.halt();
// Compare UID with stored valid UID
bool idVerify() {
    if (userIdRead[i] != userId[i]) return false;
  return true;
// Clear UID buffer
void clearBuffer() {
  for (int i = 0; i < ID_LEN; i++) userIdRead[i] = 0;
// LED blink for invalid card
void denyAccessBlink() {
  for (int i = 0; i < 4; i++) {
    digitalWrite(ledPin, HIGH); delay(200);
    digitalWrite(ledPin, LOW);  delay(200);
// Setup runs once
  rfid.begin(7, 5, 4, 3, 6, 2);
  rfid.init();
  pinMode(ledPin, OUTPUT);
  myServo.attach(servoPin);
  myServo.write(0);
  currentPos = 0;
  targetPos  = 0;
// Main loop runs repeatedly
  // Valid card opening (smooth + wait 1s)
  if (cardAction) {
    if (currentPos < 90) {
      servoSmoothRun();
      return;
    if (cardTimer == 0) {
      cardTimer = millis();
    if (millis() - cardTimer >= 1000) {
      setServoAngle(0);
      cardAction = false;
      cardTimer  = 0;
    servoSmoothRun();
    return;
  // Smoke detection logic
  int smokeVal = analogRead(smokePin);
  bool allowRFID = false;
  if (smokeVal > smokeThreshold) {     // Danger smoke
    smokeAlert       = true;
    setServoAngle(90);
    ledBlinkNonBlock();
    allowRFID = false;
  else if (smokeVal > 50) {            // Light smoke
    ledBlinkNonBlock();
    allowRFID = false;
  else {                               // No smoke
    if (smokeAlert) {
      if (!smokeRecovering) {
        smokeRecovering = true;
        smokeRecoverStart = millis();
      if (millis() - smokeRecoverStart < 1000) {
        ledBlinkNonBlock();
        allowRFID = false;
      } else {
        smokeAlert       = false;
        setServoAngle(0);
        allowRFID = true;
    } else {
      allowRFID = true;
  // RFID scanning if safe
  if (allowRFID) {
    status = rfid.request(PICC_REQIDL, str);
      getId();
      if (idVerify()) {
        setServoAngle(90);
        cardAction = true;
        cardTimer  = 0;
      } else {
        denyAccessBlink();
      clearBuffer();
  // Keep servo moving
  servoSmoothRun();
