Velocity View
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll learn how to use two buttons and the L9110 motor driver module to control the servo speed and visualize it on the LCD screen.
Pressing the red button starts the servo and increases its speed in the clockwise direction. Pressing the green button slows it down and rotates the servo counterclockwise.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R3 |
USB Cable |
Breadboard |
Wires |
Several |
L9110 Motor Driver Module |
TT Motor |
7 |
I2C LCD 1602 |
8 |
Button |
Common Connections:
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
TT Motor
Connect to MOTOR B on the L9110 Motor Driver Module.
B-1B: Connect to 5 on the Arduino.
B-1A: Connect to 6 on the Arduino.
Button
Connect to 11, 10 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
Don’t forget to select the board(Arduino UNO R3) and the correct port before clicking the Upload button.
#include <Wire.h>
// LCD setup
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Button pins
const int greenButtonPin = 10;
const int redButtonPin = 11;
// Motor pins
const int motorPin1 = 5; // TT Motor pin 1
const int motorPin2 = 6; // TT Motor pin 2
// Gear and Speed arrays
String gears[] = {"Back", "0", "1", "2", "3", "4"};
int speeds[] = {110, 0, 110, 150, 200, 255};
// Index to track current gear and speed
int index = 1;
lcd.init();
lcd.backlight();
// Initialize buttons
pinMode(greenButtonPin, INPUT_PULLUP);
pinMode(redButtonPin, INPUT_PULLUP);
// Initialize motor pins
pinMode(motorPin1, OUTPUT);
pinMode(motorPin2, OUTPUT);
// Display initial gear and speed
updateDisplay();
// Increase gear and speed
if (digitalRead(greenButtonPin) == LOW) {
if (index < 5) { // Check to avoid going out of array bounds
index++;
controlMotor();
updateDisplay();
delay(200); // Debouncing
// Decrease gear and speed
if (digitalRead(redButtonPin) == LOW) {
if (index > 0) { // Check to avoid going below 0
index--;
controlMotor();
updateDisplay();
void updateDisplay() {
lcd.clear();
lcd.setCursor(0, 0);
lcd.print("Gear: " + gears[index]);
lcd.setCursor(0, 1);
lcd.print("Speed: " + String(speeds[index]));
void controlMotor() {
if (gears[index] == "Back") {
analogWrite(motorPin1, map(speeds[index], 0, 255, 0, 255));
digitalWrite(motorPin2, LOW);
} else {
digitalWrite(motorPin1, LOW);
analogWrite(motorPin2, map(speeds[index], 0, 255, 0, 255));
