Snake Game
  • 🎁 Looking for parts?Check out our all-in-one kits below — packed with components, beginner-friendly guides, and tons of fun.
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
In this lesson, we’ll use a MAX7219 Dot Matrix Module, a joystick module, and an Arduino board to play a Snake game.
The snake’s movement will be controlled using the joystick.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Joystick Module
../_images/Snake_Game_bb.png
Common Connections:
  • MAX7219 Dot Matrix Module
    • CLK: Connect to 11 on the Arduino.
    • CS: Connect to 10 on the Arduino.
    • DIN: Connect to 12 on the Arduino.
  • Joystick Module
    • SW: Connect to 2 on the Arduino.
    • VRY: Connect to A1 on the Arduino.
    • VRX: Connect to A0 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LedControl and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <LedControl.h>
// Initialize the LED matrix
LedControl lc = LedControl(12, 11, 10, 1); // DIN, CLK, CS, single matrix
// Joystick pin configuration
const int xPin = A0;  // VRX connected to A0
const int yPin = A1;  // VRY connected to A1
const int swPin = 2;  // SW connected to digital pin 2
// Define grid size
#define GRID_SIZE 8
// Snake settings
int snake[64][2];      // Stores the position of each segment of the snake, max 64 segments
int snakeLength = 3;   // Initial length of the snake
int direction = 0;     // Snake's movement direction: 0=right, 1=down, 2=left, 3=up
bool gameOverFlag = false; // Flag to indicate if the game is over
// Dynamic speed control
int moveSpeed = 300;     // Initial movement speed (in ms)
const int minSpeed = 100; // Minimum speed (in ms) to avoid uncontrollable gameplay
// Food position
int foodX, foodY;
  lc.shutdown(0, false);  // Wake up the LED matrix
  lc.setIntensity(0, 5);  // Set brightness level
  lc.clearDisplay(0);     // Clear the display
  pinMode(swPin, INPUT_PULLUP); // Configure joystick button as input
  Serial.begin(9600);
  // Initialize the snake's position and spawn the first food
  resetGame();
  // Check if the game is over
  if (gameOverFlag) {
    if (digitalRead(swPin) == LOW) { // Restart the game if the joystick button is pressed
      delay(200); // Debounce delay
      resetGame();
    return;
  // Update direction at a higher frequency
  static unsigned long lastDirectionTime = 0;
  if (millis() - lastDirectionTime > 50) { // Check direction every 50ms
    updateDirection();
    lastDirectionTime = millis();
  // Control the snake's movement
  static unsigned long lastMoveTime = 0;
  if (millis() - lastMoveTime > moveSpeed) { // Move snake based on its speed
    updateSnake();
    if (checkCollision()) { // Check for collisions
      gameOver();
      return;
    displaySnakeAndFood(); // Refresh the display
    lastMoveTime = millis();
// Reset the game state to initial conditions
void resetGame() {
  lc.clearDisplay(0);
  snakeLength = 3;
  direction = 0;
  moveSpeed = 300; // Reset movement speed
  snake[0][0] = 4; snake[0][1] = 2; // Snake head
  snake[1][0] = 4; snake[1][1] = 1; // Snake body
  snake[2][0] = 4; snake[2][1] = 0; // Snake tail
  // Spawn the first food
  generateFood();
  // Display the initial state
// Update the snake's position based on its direction
void updateSnake() {
  // Check if the snake eats the food
  if (snake[0][0] == foodX && snake[0][1] == foodY) {
    snakeLength++; // Increase the snake's length
    generateFood(); // Spawn new food
    // Increase speed by decreasing delay, but do not go below minimum speed
    moveSpeed = max(minSpeed, moveSpeed - 40);
  // Update each segment's position from tail to head
  for (int i = snakeLength - 1; i > 0; i--) {
    snake[i][0] = snake[i - 1][0];
    snake[i][1] = snake[i - 1][1];
  // Update the head's position based on the direction
  if (direction == 0) snake[0][1] += 1;       // Move right
  else if (direction == 1) snake[0][0] += 1;  // Move down
  else if (direction == 2) snake[0][1] -= 1;  // Move left
  else if (direction == 3) snake[0][0] -= 1;  // Move up
// Display the snake and the food on the LED matrix
void displaySnakeAndFood() {
  lc.clearDisplay(0); // Clear the LED matrix
  for (int i = 0; i < snakeLength; i++) {
    // Rotate the coordinates 90 degrees to match LED matrix orientation
    int rotatedRow = snake[i][1];               // New row = logical column
    int rotatedCol = GRID_SIZE - 1 - snake[i][0]; // New column = GRID_SIZE - 1 - row
    if (rotatedRow >= 0 && rotatedRow < GRID_SIZE &&
        rotatedCol >= 0 && rotatedCol < GRID_SIZE) { // Ensure the point is within bounds
      lc.setLed(0, rotatedRow, rotatedCol, true); // Light up the snake segment
  // Display the food
  int rotatedFoodRow = foodY;                // New row = logical column
  int rotatedFoodCol = GRID_SIZE - 1 - foodX; // New column = GRID_SIZE - 1 - row
  lc.setLed(0, rotatedFoodRow, rotatedFoodCol, true);
// Update the direction based on joystick input
void updateDirection() {
  int xValue = analogRead(xPin);
  int yValue = analogRead(yPin);
  if (xValue < 300 && direction != 0) direction = 2; // Move left
  else if (xValue > 700 && direction != 2) direction = 0; // Move right
  else if (yValue < 300 && direction != 1) direction = 3; // Move up
  else if (yValue > 700 && direction != 3) direction = 1; // Move down
// Check for collisions with boundaries or self
bool checkCollision() {
  // Check boundary collision
  if (snake[0][0] < 0 || snake[0][0] >= GRID_SIZE ||
      snake[0][1] < 0 || snake[0][1] >= GRID_SIZE) {
    return true; // Collided with boundary
  // Check self-collision
  for (int i = 1; i < snakeLength; i++) {
    if (snake[0][0] == snake[i][0] && snake[0][1] == snake[i][1]) {
      return true; // Collided with itself
  return false;
// Handle game over state
void gameOver() {
  gameOverFlag = true;
  // Display an end-game animation
  for (int i = 0; i < GRID_SIZE; i++) {
    for (int j = 0; j < GRID_SIZE; j++) {
      lc.setLed(0, i, j, true); // Light up all LEDs
  delay(2000); // Hold the animation for 2 seconds
  lc.clearDisplay(0);
// Randomly generate a new food position
void generateFood() {
  // Maintain a list of unoccupied positions
  int availablePositions[GRID_SIZE * GRID_SIZE][2];
  int availableCount = 0;
  // Traverse the matrix and find unoccupied positions
  for (int x = 0; x < GRID_SIZE; x++) {
    for (int y = 0; y < GRID_SIZE; y++) {
      bool isOccupied = false;
        if (snake[i][0] == x && snake[i][1] == y) {
          isOccupied = true;
          break;
      if (!isOccupied) {
        availablePositions[availableCount][0] = x;
        availablePositions[availableCount][1] = y;
        availableCount++;
  // Randomly select a position from the unoccupied list
  if (availableCount > 0) {
    int randomIndex = random(0, availableCount);
    foodX = availablePositions[randomIndex][0];
    foodY = availablePositions[randomIndex][1];
