Barrier Gate 5.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
This project uses an ultrasonic sensor, MFRC522 Module, a servo, and a buzzer to create an automatic gate system.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
MFRC522 Module |
Digital Servo Motor |
7 |
Buzzer Modudle |
8 |
Ultrasonic Sensor Module |
Common Connections:
MFRC522 Module
SDA: Connect to 6 on the Arduino.
SCK: Connect to 5 on the Arduino.
MOSI: Connect to 4 on the Arduino.
MISO: Connect to 3 on the Arduino.
IRQ: Connect to 7 on the Arduino.
RST: Connect to 2 on the Arduino.
3.3V: Connect to breadboard’s passive power bus.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 9 on the Arduino.
Trig: Connect to 11 on the Arduino.
Echo: Connect to 10 on the Arduino.
Buzzer Module
I/0: Connect to 12 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Writing the Code
The
RFID1library is used here. You can click hereRFID1.zipto download it.Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
#include <rfid1.h>
// Ultrasonic sensor pins
const int trigPin = 11;
const int echoPin = 10;
// Servo motor pin
const int servoPin = 9;
// Buzzer pin
const int buzzerPin = 12;
// RFID module
RFID1 rfid;
// Length of RFID UID (4 bytes)
#define ID_LEN 4
// Authorized card UID
uchar userId[ID_LEN] = {0x33, 0xF8, 0xB8, 0x1A};
// Buffer for scanned UID
uchar userIdRead[ID_LEN];
// Distance settings (cm)
const int ENTRY_DISTANCE = 12; // Detect vehicle approaching
const int CLEAR_DISTANCE = 25; // Detect vehicle leaving
const int CLEAR_COUNT = 7; // About 1 second (7 × 150 ms)
// Minimum time the gate stays open (ms)
const unsigned long MIN_OPEN_TIME = 2000;
// System states
enum GateMode {
WAIT_ENTRY, // Waiting for vehicle to enter (ultrasonic)
WAIT_EXIT // Waiting for vehicle to exit (RFID)
GateMode mode = WAIT_ENTRY;
// Servo object
Servo myServo;
// Play a simple beep sound
void beepOnce(int freq, int dur) {
tone(buzzerPin, freq, dur);
delay(dur * 1.2);
noTone(buzzerPin);
// Beep sound for unauthorized card
void beepError() {
for (int i = 0; i < 2; i++) {
tone(buzzerPin, 800);
delay(120);
noTone(buzzerPin);
delay(80);
// Open the gate smoothly
void openGate() {
for (int pos = 0; pos <= 90; pos++) {
myServo.write(pos);
delay(10);
// Close the gate smoothly
void closeGate() {
for (int pos = 90; pos >= 0; pos--) {
myServo.write(pos);
delay(10);
// Measure distance using ultrasonic sensor (cm)
float getDistance() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
long duration = pulseIn(echoPin, HIGH, 25000);
if (duration == 0) return 999;
return duration * 0.034 / 2;
// Read RFID card UID
bool getId() {
uchar status, str[MAX_LEN];
status = rfid.anticoll(str);
if (status == MI_OK) {
for (int i = 0; i < ID_LEN; i++) {
userIdRead[i] = str[i];
rfid.halt();
return true;
return false;
// Compare scanned UID with authorized UID
bool idVerify() {
if (userIdRead[i] != userId[i]) return false;
return true;
// Clear UID buffer
void clearBuffer() {
userIdRead[i] = 0;
Serial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzerPin, OUTPUT);
myServo.attach(servoPin);
myServo.write(0); // Gate starts closed
// RFID initialization (pin order must match wiring)
rfid.begin(7, 5, 4, 3, 6, 2);
rfid.init();
Serial.println("System Ready - WAIT_ENTRY");
// Entry mode: ultrasonic detection
if (mode == WAIT_ENTRY) {
float distance = getDistance();
Serial.print("Distance: ");
Serial.println(distance);
if (distance < ENTRY_DISTANCE) {
beepOnce(1000, 200);
openGate();
// Wait until the vehicle completely leaves
int clearCounter = 0;
while (clearCounter < CLEAR_COUNT) {
float d = getDistance();
if (d > CLEAR_DISTANCE)
clearCounter++;
else
clearCounter = 0;
delay(150);
closeGate();
mode = WAIT_EXIT;
delay(500);
// Exit mode: RFID verification
else if (mode == WAIT_EXIT) {
status = rfid.request(PICC_REQIDL, str);
clearBuffer();
if (getId() && idVerify()) {
beepOnce(1500, 150);
openGate();
// Keep gate open for a minimum time
unsigned long openTime = millis();
while (millis() - openTime < MIN_OPEN_TIME) {
delay(50);
// Wait until the vehicle leaves
clearCounter++;
else
clearCounter = 0;
delay(150);
closeGate();
mode = WAIT_ENTRY;
delay(500);
else {
beepError();
delay(100);
