Tilt LED 2.0
Kit purchase
../_images/ultimate_sensor_kit.png
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This project controls an array of LEDs based on the tilt angle detected by an MPU6050 sensor.
The LEDs illuminate in response to X-axis tilt, visually indicating the board’s orientation.
Tilt angles are continuously calculated from acceleration data provided by the MPU6050, and corresponding LEDs activate according to predefined angle thresholds.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4
USB Type-C cable
Wires
Several
1kΩ resistor
Several
LED
Several
MPU6050 Module
../_images/mpu6050_2.0_bb.png
Common Connections:
  • LED
    • Connect the LEDs cathode to a 1kΩ resistor then to the negative power bus on the breadboard, and the LEDs anode to 8 to 13 on the Arduino.
  • MPU6050
    • SDA: Connect to SDA on the Arduino.
    • SCL: Connect to SCL on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for MPU6050 and install it.
  • Don’t forget to select the board(Arduino UNO R3) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <MPU6050.h>
MPU6050 mpu;
// LED pins 7-13 on Arduino
const int ledPins[] = {13, 12, 11, 10, 9, 8, 7};
int ledCount = sizeof(ledPins) / sizeof(ledPins[0]); // LED count
// Tilt angle thresholds for LEDs
const float thresholds[] = {-30, -15, -5, 5, 15, 30};
  Wire.begin(); // Init I2C
  Serial.begin(9600); // Init serial
  // Init MPU6050
  mpu.initialize();
  if (!mpu.testConnection()) {
    Serial.println("MPU6050 connection failed");
    while (1); // Stop if MPU6050 fails
  // Set LED pins as output
  for (int i = 0; i < ledCount; i++) {
    pinMode(ledPins[i], OUTPUT);
  int16_t ax, ay, az; // Acceleration data
  // Get MPU6050 acceleration
  mpu.getAcceleration(&ax, &ay, &az);
  // Calculate tilt angle (X-axis)
  float angleX = atan2(ay, az) * 180 / PI;
  // Update LEDs based on angle
  updateLEDs(angleX);
  delay(100); // Stabilize output
void updateLEDs(float angleX) {
  // Turn off all LEDs
    digitalWrite(ledPins[i], LOW);
  // Get the LED index for the angle
  int ledIndex = getLEDIndex(angleX);
  // Turn on the correct LED
  if (ledIndex >= 0 && ledIndex < ledCount) {
    digitalWrite(ledPins[ledIndex], HIGH);
// Determine the LED index for the angle
int getLEDIndex(float angleX) {
  // Find the matching LED
  for (int i = 0; i < ledCount - 1; i++) {
    if (angleX < thresholds[i]) {
      return i; // Return matching LED index
  return ledCount - 1; // Return last LED if angle exceeds thresholds
