Tetris5.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project uses MAX7219 8x8 Dot Matrix module, Joystick Module, buzzer to play a classic Tetris game.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Joystick Module
MAX7219 Dot Matrix Module
../_images/Tetris_5.0_bb.png
Common Connections:
  • MAX7219 Dot Matrix Module
    • CLK: Connect to 5 on the Arduino.
    • CS: Connect to 3 on the Arduino.
    • DIN: Connect to 6 on the Arduino.
  • Buzzer
    • +: Connect to 11 on the Arduino.
    • -: Connect to breadboard’s negative power bus.
  • Joystick Module
    • VRY: Connect to A1 on the Arduino.
    • VRX: Connect to A0 on the Arduino.
    • SW: Connect to 2 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for LedControl and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <LedControl.h>
// MAX7219 LED matrix pins
#define DIN_PIN     6
#define CLK_PIN     5
#define CS_PIN      3
#define NUM_MODULES 4
LedControl lc(DIN_PIN, CLK_PIN, CS_PIN, NUM_MODULES);
// Joystick and buzzer pins
#define VRx A0
#define VRy A1
#define SW  2
#define BUZZER_PIN 11
// Game screen size
const int SCREEN_W = 8;
const int PREVIEW_MODULE = 3;
const int GAME_MODULES = NUM_MODULES - 1;
const int SCREEN_H = SCREEN_W * GAME_MODULES;
// Stores the locked blocks on the game field
uint8_t field[SCREEN_H];
// Timing for movement and display refresh
unsigned long lastDrop = 0;
unsigned long dropInterval = 500;
unsigned long lastMove = 0;
const unsigned long moveInterval = 200;
const unsigned long refreshInterval = 33;
unsigned long lastRefresh = 0;
// Button debounce settings
unsigned long lastButtonCheck = 0;
const unsigned long debounceDelay = 30;
bool lastButtonState = HIGH;
bool buttonPressedEvent = false;
// Non-blocking buzzer state
bool buzzerOn = false;
unsigned long buzzerOffTime = 0;
// Short delay before locking a landed block
bool pendingLock = false;
unsigned long lockTime = 0;
const unsigned long lockDelay = 30;
// Short delay before spawning the next block
bool waitingForNextBlock = false;
unsigned long nextBlockTime = 0;
const unsigned long nextBlockDelay = 120;
// Saves the last LED state to reduce flicker
uint8_t prevBuf[NUM_MODULES][SCREEN_W];
// Stores the current falling block
struct Block {
  const int (*shape)[2];  // Points to the current block shape
  int len;                // Number of small squares in the block
  int x, y;               // Block position on the game field
  int rotation;           // Current rotation state
  char type;              // Block type: I, O, T, L, J, S, or Z
} current;
char nextType;
// I block rotations
const int I_SHAPE[2][4][2] = {
  {{0,0},{0,1},{0,2},{0,3}},
  {{-1,1},{0,1},{1,1},{2,1}}
// O block rotation
const int O_SHAPE[1][4][2] = {
  {{0,0},{1,0},{0,1},{1,1}}
// T block rotations
const int T_SHAPE[4][4][2] = {
  {{1,0},{0,1},{1,1},{2,1}},
  {{1,0},{1,1},{1,2},{0,1}},
  {{0,1},{1,1},{2,1},{1,2}},
  {{1,0},{1,1},{1,2},{2,1}}
// L block rotations
const int L_SHAPE[4][4][2] = {
  {{0,0},{0,1},{0,2},{1,2}},
  {{0,0},{1,0},{2,0},{0,1}},
  {{0,0},{1,0},{1,1},{1,2}},
  {{2,0},{0,1},{1,1},{2,1}}
// J block rotations
const int J_SHAPE[4][4][2] = {
  {{1,0},{1,1},{1,2},{0,2}},
  {{0,0},{0,1},{1,1},{2,1}},
  {{0,0},{1,0},{0,1},{0,2}},
  {{0,0},{1,0},{2,0},{2,1}}
// S block rotations
const int S_SHAPE[2][4][2] = {
  {{1,0},{2,0},{0,1},{1,1}},
  {{1,0},{1,1},{2,1},{2,2}}
// Z block rotations
const int Z_SHAPE[2][4][2] = {
  {{0,0},{1,0},{1,1},{2,1}},
  {{2,0},{1,1},{2,1},{1,2}}
// Letter patterns for the GAME OVER screen
static const uint8_t PAT_G[8] = {0x3C,0x42,0x40,0x4E,0x42,0x42,0x3C,0x00};
static const uint8_t PAT_A[8] = {0x18,0x24,0x42,0x7E,0x42,0x42,0x42,0x00};
static const uint8_t PAT_M[8] = {0x42,0x66,0x5A,0x5A,0x42,0x42,0x42,0x00};
static const uint8_t PAT_E[8] = {0x7E,0x40,0x5C,0x40,0x40,0x40,0x7E,0x00};
static const uint8_t PAT_O[8] = {0x3C,0x42,0x42,0x42,0x42,0x42,0x3C,0x00};
static const uint8_t PAT_V[8] = {0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00};
static const uint8_t PAT_R[8] = {0x7C,0x42,0x42,0x7C,0x48,0x44,0x42,0x00};
// Play a blocking beep for simple startup sounds
void beep(int duration) {
  digitalWrite(BUZZER_PIN, HIGH);
  delay(duration);
  digitalWrite(BUZZER_PIN, LOW);
// Start a beep without stopping the game
void startBeep(unsigned long duration) {
  buzzerOn = true;
  buzzerOffTime = millis() + duration;
// Turn off the buzzer when its time is up
void updateBuzzer() {
  if (buzzerOn && millis() >= buzzerOffTime) {
    buzzerOn = false;
// Play the startup sound
void soundStart() {
  beep(60);
  delay(80);
  beep(60);
  delay(80);
  beep(120);
// Play the rotate sound
void soundRotate() {
  startBeep(40);
// Play the landing sound
void soundLand() {
  startBeep(70);
// Play the game over sound
void soundGameOver() {
  beep(120);
  delay(80);
  beep(120);
  delay(80);
  beep(250);
// Clear all LED matrix modules
void clearAll() {
  for (int m = 0; m < NUM_MODULES; m++) {
    lc.clearDisplay(m);
// Read the joystick button without freezing the game
bool readButton() {
  bool currentState = digitalRead(SW);
  unsigned long now = millis();
  if (currentState != lastButtonState) {
    lastButtonCheck = now;
    lastButtonState = currentState;
  if ((now - lastButtonCheck) > debounceDelay) {
    if (currentState == LOW && !buttonPressedEvent) {
      buttonPressedEvent = true;
      return true;
    if (currentState == HIGH) {
  return false;
// Get the LED pattern for a letter
const uint8_t* letterPattern(char c) {
  switch (c) {
    case 'G': return PAT_G;
    case 'A': return PAT_A;
    case 'M': return PAT_M;
    case 'E': return PAT_E;
    case 'O': return PAT_O;
    case 'V': return PAT_V;
    case 'R': return PAT_R;
    default:  return PAT_E;
// Pick a random block type
char randomBlockType() {
  const char types[] = {'I', 'O', 'T', 'L', 'J', 'S', 'Z'};
  return types[random(7)];
// Get the default shape for the preview window
const int (*getShapeByType(char type))[2] {
  if      (type == 'I') return I_SHAPE[0];
  else if (type == 'O') return O_SHAPE[0];
  else if (type == 'T') return T_SHAPE[0];
  else if (type == 'L') return L_SHAPE[0];
  else if (type == 'J') return J_SHAPE[0];
  else if (type == 'S') return S_SHAPE[0];
  else if (type == 'Z') return Z_SHAPE[0];
  return O_SHAPE[0];
// Set the current block type and position
void setBlockByType(char type, int sx, int sy) {
  current.rotation = 0;
  current.type = type;
  current.len = 4;
  current.x = sx;
  current.y = sy;
  if      (type == 'I') current.shape = I_SHAPE[0];
  else if (type == 'O') current.shape = O_SHAPE[0];
  else if (type == 'T') current.shape = T_SHAPE[0];
  else if (type == 'L') current.shape = L_SHAPE[0];
  else if (type == 'J') current.shape = J_SHAPE[0];
  else if (type == 'S') current.shape = S_SHAPE[0];
  else if (type == 'Z') current.shape = Z_SHAPE[0];
// Draw the upcoming block on the preview matrix
void drawNextBlock() {
  uint8_t preview[8] = {};
  const int (*shape)[2] = getShapeByType(nextType);
  int offsetX = 3;
  int offsetY = 3;
  if (nextType == 'I') {
    offsetX = 4;
    offsetY = 3;
  } else if (nextType == 'O') {
    offsetX = 4;
    offsetY = 4;
  for (int i = 0; i < 4; i++) {
    int x = offsetX + shape[i][0];
    int y = offsetY + shape[i][1];
    if (x >= 0 && x < 8 && y >= 0 && y < 8) {
      preview[y] |= (1 << x);
  // Add a simple border line for the preview area
  for (int row = 0; row < 8; row++) {
    preview[row] |= (1 << 0);
    lc.setRow(PREVIEW_MODULE, row, preview[row]);
    prevBuf[PREVIEW_MODULE][row] = preview[row];
// Create a new falling block
void spawnBlock() {
  int sx = SCREEN_W / 2 - 2;
  setBlockByType(nextType, sx, 0);
  nextType = randomBlockType();
// Show the game over animation
void gameOverSequence() {
  soundGameOver();
  for (int i = 0; i < 3; i++) {
    clearAll();
    delay(300);
      for (int r = 0; r < SCREEN_W; r++) {
        lc.setRow(m, r, 0xFF);
    delay(300);
  const char* w1 = "GAME";
  for (int seg = 0; seg < 4; seg++) {
    const uint8_t* pat = letterPattern(w1[seg]);
    uint8_t rot[8] = {};
    for (int y = 0; y < 8; y++) {
      for (int x = 0; x < 8; x++) {
        if (pat[y] & (1 << x)) {
          int nx = 7 - y;
          int ny = x;
          rot[ny] |= (1 << nx);
    int module = NUM_MODULES - 1 - seg;
      lc.setRow(module, row, rot[row]);
  delay(1000);
  const char* w2 = "OVER";
    const uint8_t* pat = letterPattern(w2[seg]);
          int nx = 7 - y;
          int ny = x;
  delay(1200);
  // Wait for the player to press and release the button
  while (digitalRead(SW) != LOW) {
    delay(10);
  while (digitalRead(SW) == LOW) {
    delay(10);
// Start a new game
void resetGame() {
  memset(field, 0, sizeof(field));
  clearAll();
      prevBuf[m][r] = 0;
  buzzerOn = false;
  spawnBlock();
  drawNextBlock();
  writeBuffer();
  soundStart();
  lastDrop = millis();
  lastRefresh = millis();
// Build and send the LED display buffer
void writeBuffer() {
  uint8_t buf[NUM_MODULES][SCREEN_W] = {};
  for (int y = 0; y < SCREEN_H; y++) {
    uint8_t row = field[y];
    if (!row) continue;
    int mod = 2 - (y / SCREEN_W);
    int bit = 1 << (7 - (y % SCREEN_W));
    for (int x = 0; x < SCREEN_W; x++) {
      if (row & (1 << x)) {
        buf[mod][x] |= bit;
  // Draw the falling block unless the game is between blocks
  if (!waitingForNextBlock) {
    for (int i = 0; i < current.len; i++) {
      int xx = current.x + current.shape[i][0];
      int yy = current.y + current.shape[i][1];
      if (xx < 0 || xx >= SCREEN_W || yy < 0 || yy >= SCREEN_H) {
        continue;
      int mod = 2 - (yy / SCREEN_W);
      int bit = 1 << (7 - (yy % SCREEN_W));
      buf[mod][xx] |= bit;
  // Update only changed rows
  for (int m = 0; m < 3; m++) {
      if (buf[m][r] != prevBuf[m][r]) {
        lc.setRow(m, r, buf[m][r]);
        prevBuf[m][r] = buf[m][r];
// Check if the block would hit a wall, floor, or placed block
bool checkCollision(int nx, int ny) {
    int xx = nx + current.shape[i][0];
    int yy = ny + current.shape[i][1];
    if (xx < 0 || xx >= SCREEN_W || yy >= SCREEN_H) {
      return true;
    if (yy >= 0 && (field[yy] & (1 << xx))) {
      return true;
  return false;
// Check if the block locks at the top of the field
bool isAtTop() {
    if (current.y + current.shape[i][1] == 0) {
      return true;
  return false;
// Add the current block to the field
void placeBlock() {
    if (yy >= 0 && yy < SCREEN_H) {
      field[yy] |= (1 << xx);
  // Clear full rows
    if (field[y] == 0xFF) {
      for (int j = y; j > 0; j--) {
        field[j] = field[j - 1];
      field[0] = 0;
// Lock the current block after it lands
void lockCurrentBlock(unsigned long now) {
  if (isAtTop()) {
    gameOverSequence();
    resetGame();
    return;
  placeBlock();
  waitingForNextBlock = true;
  soundLand();
  writeBuffer();
  nextBlockTime = now + nextBlockDelay;
// Rotate the current block
void rotateBlock() {
  int limit =
    (current.type == 'I' ||
    current.type == 'S' ||
    current.type == 'Z') ? 2 :
    (current.type == 'O' ? 1 : 4);
  int nr = (current.rotation + 1) % limit;
  const int (*ns)[2] = nullptr;
  if      (current.type == 'I') ns = I_SHAPE[nr];
  else if (current.type == 'O') ns = O_SHAPE[0];
  else if (current.type == 'T') ns = T_SHAPE[nr];
  else if (current.type == 'L') ns = L_SHAPE[nr];
  else if (current.type == 'J') ns = J_SHAPE[nr];
  else if (current.type == 'S') ns = S_SHAPE[nr];
  else if (current.type == 'Z') ns = Z_SHAPE[nr];
  Block bak = current;
  current.shape = ns;
  current.rotation = nr;
  // Undo the rotation if it does not fit
  if (checkCollision(current.x, current.y)) {
    current = bak;
  } else {
    soundRotate();
  pinMode(SW, INPUT_PULLUP);
  pinMode(BUZZER_PIN, OUTPUT);
  randomSeed(analogRead(A2));
  // Turn on and clear each LED matrix
    lc.shutdown(m, false);
    lc.setIntensity(m, 8);
    lc.clearDisplay(m);
      prevBuf[m][r] = 0;
  resetGame();
  // Keep buzzer timing updated
  updateBuzzer();
  // Finish locking the block after the landing delay
  if (pendingLock) {
    if (now >= lockTime) {
      lockCurrentBlock(now);
    if (now - lastRefresh >= refreshInterval) {
      writeBuffer();
      lastRefresh = now;
    return;
  // Spawn the next block after a short pause
  if (waitingForNextBlock) {
    if (now >= nextBlockTime) {
      spawnBlock();
      drawNextBlock();
      lastDrop = now;
      lastRefresh = now;
      writeBuffer();
      lastRefresh = now;
    return;
  // Read joystick left/right movement
  int ax = analogRead(VRx);
  // Move left or right at a controlled speed
  if (now - lastMove > moveInterval) {
    if (ax < 400 && !checkCollision(current.x + 1, current.y)) {
      current.x++;
      lastMove = now;
    } else if (ax > 600 && !checkCollision(current.x - 1, current.y)) {
      current.x--;
      lastMove = now;
  // Rotate when the joystick button is pressed
  if (readButton()) {
    rotateBlock();
  // Read joystick up/down movement
  int ay = analogRead(VRy);
  // Push down to make the block fall faster
  dropInterval = 700 - constrain(map(ay, 512, 1023, 0, 690), 0, 690);
  // Move the block down automatically
  if (now - lastDrop > dropInterval) {
    lastDrop = now;
    if (!checkCollision(current.x, current.y + 1)) {
      current.y++;
      writeBuffer();
      // Start the lock delay when the block reaches the bottom
      if (checkCollision(current.x, current.y + 1)) {
        pendingLock = true;
        lockTime = now + lockDelay;
    } else {
      pendingLock = true;
      lockTime = now;
  // Refresh the display regularly
    writeBuffer();
    lastRefresh = now;
