Smart Stop 5.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, you’ll learn how to use an L9110 Motor Driver Module, an Ultrasonic Sensor Module, an I2C LCD Module, an Buzzer module and a TT motor with the Arduino UNO R4 to create a Smart Stop 5.0 system.
As the obstacle gets closer to the Ultrasonic Sensor Module, the LCD screen displays the distance to obstacles and the servo speed.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Cable |
Breadboard |
Wires |
Several |
L9110 Motor Driver Module |
Ultrasonic Sensor Module |
7 |
TT Motor |
8 |
Buzzer Modudle |
9 |
I2C LCD 1602 |
Common Connections:
Trig: Connect to 10 on the Arduino.
Echo: Connect to 11 on the Arduino.
TT Motor
Connect to MOTOR B on the L9110 Motor Driver Module.
B-1B: Connect to 2 on the Arduino.
B-1A: Connect to 3 on the Arduino.
Buzzer Module
I/0: Connect to 4 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
I2C LCD 1602
SDA: Connect to A4 on the Arduino.
SCL: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LiquidCrystal I2C and install it.
Don’t forget to select the board(Arduino UNO R4 WiFi) and the correct port before clicking the Upload button.
#include <Wire.h>
// I2C LCD (16x2)
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Motor driver pins (L9110)
const int motorPinA = 3;
const int motorPinB = 2;
// Ultrasonic sensor pins
const int trigPin = 10;
const int echoPin = 11;
// Passive buzzer pin
const int buzzerPin = 4;
// Distance thresholds (cm)
const int STOP_DISTANCE = 5;
const int SLOW_DISTANCE = 20;
// Motor speed range (PWM)
const int MIN_MOTOR_PWM = 75;
const int MAX_MOTOR_PWM = 255;
// Variables for non-blocking buzzer
unsigned long previousBeepTime = 0;
bool beepState = false;
// Set motor pins
pinMode(motorPinA, OUTPUT);
pinMode(motorPinB, OUTPUT);
// Set ultrasonic pins
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
// Set buzzer pin
pinMode(buzzerPin, OUTPUT);
// Fix motor direction
digitalWrite(motorPinB, LOW);
// Initialize LCD
lcd.init();
lcd.backlight();
// Startup message
lcd.setCursor(0, 0);
lcd.print("Smart Stop");
lcd.setCursor(0, 1);
lcd.print("Ready...");
delay(1000);
lcd.clear();
// Read distance (cm)
int distance = readDistance();
// Calculate motor speed
int speed = calculateSpeed(distance);
// Control motor
controlMotor(speed);
// Update buzzer and display
updateBuzzer(distance);
updateLCD(distance);
delay(50);
// Measure distance using ultrasonic sensor
int readDistance() {
long duration;
// Send trigger pulse
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read echo time (with timeout)
duration = pulseIn(echoPin, HIGH, 25000);
// If no signal, return far distance
if (duration == 0) return 100;
// Convert to cm
return duration / 58;
// Convert distance to motor speed
int calculateSpeed(int distance) {
// Stop if too close
if (distance <= STOP_DISTANCE) {
// Slow down in warning range
if (distance <= SLOW_DISTANCE) {
return map(distance,
STOP_DISTANCE,
SLOW_DISTANCE,
MIN_MOTOR_PWM,
MAX_MOTOR_PWM);
// Full speed when safe
return MAX_MOTOR_PWM;
// Control motor speed (PWM)
void controlMotor(int speed) {
analogWrite(motorPinA, speed);
// Control buzzer without delay()
void updateBuzzer(int distance) {
unsigned long currentTime = millis();
// Fast beep when very close
if (currentTime - previousBeepTime >= 100) {
previousBeepTime = currentTime;
beepState = !beepState;
beepState ? tone(buzzerPin, 2000) : noTone(buzzerPin);
// Slow beep in warning range
else if (distance <= SLOW_DISTANCE) {
if (currentTime - previousBeepTime >= 500) {
beepState ? tone(buzzerPin, 800) : noTone(buzzerPin);
// No sound when safe
else {
noTone(buzzerPin);
beepState = false;
// Update LCD display
void updateLCD(int distance) {
// Line 1: system state
lcd.print("STOP ");
lcd.print("SLOW ");
else {
lcd.print("SAFE ");
// Line 2: distance value
lcd.print("Dist:");
lcd.print(distance);
lcd.print("cm ");
