Light Show
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you will learn how to use Arduino along with LEDs, and resistors to create a light show.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
1kΩ resistor |
Several |
LED |
Several |
Common Connections:
LED
Connect the LEDs cathode to negative power bus on the breadboard, and the LEDs anode to a 1kΩ resistor then to the 2 to 13 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// Define LED pins
const int ledPins[] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13};
const int numLeds = 12;
// Set all LED pins as outputs and turn them off
for (int i = 0; i < numLeds; i++) {
pinMode(ledPins[i], OUTPUT);
digitalWrite(ledPins[i], LOW);
waterfallEffect(true); // Waterfall (forward)
waterfallEffect(false); // Waterfall (reverse)
bouncingEffect(); // Bouncing (in and out)
bouncingEffect();
waveEffect(); // Wave pattern
waveEffect();
alternatingEffect(); // Alternating even/odd LEDs
runningBackEffect(); // Running light back and forth
ladderEffect(); // Ladder on/off sequence
progressiveKeepEffect(); // Progressive lighting
dualSlidingEffect(); // Dual sliding from ends to center and back
void dualSlidingEffect() {
// Move inward, blinking symmetrically
for (int i = 0; i < numLeds / 2; i++) {
for (int j = 0; j < 3; j++) {
digitalWrite(ledPins[i], HIGH);
digitalWrite(ledPins[numLeds - 1 - i], HIGH);
delay(10);
digitalWrite(ledPins[numLeds - 1 - i], LOW);
delay(10);
delay(50);
// Move outward, blinking symmetrically
for (int i = numLeds / 2 - 1; i >= 0; i--) {
delay(10);
delay(10);
delay(50);
// Waterfall effect: LEDs turn on/off in sequence
void waterfallEffect(bool direction) {
if (direction) {
delay(50);
delay(50);
} else {
for (int i = numLeds - 1; i >= 0; i--) {
delay(50);
delay(50);
// Bouncing effect: inward and outward lighting
void bouncingEffect() {
delay(50);
delay(50);
delay(50);
delay(50);
// Wave effect: LEDs create a moving wave
void waveEffect() {
if (i > 1) digitalWrite(ledPins[i - 2], LOW);
delay(50);
if (i < numLeds - 2) digitalWrite(ledPins[i + 2], LOW);
delay(50);
for (int i = 0; i < 2; i++) {
// Alternating blink effect: even/odd LEDs alternate
void alternatingEffect() {
for (int i = 0; i < 5; i++) {
for (int j = 0; j < numLeds; j += 2) {
digitalWrite(ledPins[j], HIGH);
digitalWrite(ledPins[j + 1], LOW);
delay(300);
digitalWrite(ledPins[j], LOW);
digitalWrite(ledPins[j + 1], HIGH);
delay(300);
// Running effect: light moves left-to-right and back
void runningBackEffect() {
delay(50);
delay(50);
// Ladder effect: sequential on/off like climbing steps
void ladderEffect() {
delay(50);
delay(50);
// Progressive keep effect: gradually light LEDs and keep previous ones on
void progressiveKeepEffect() {
for (int round = 0; round < numLeds; round++) {
for (int i = numLeds - 1; i >= numLeds - round; i--) {
for (int i = 0; i < numLeds - round; i++) {
if (i > 0) {
digitalWrite(ledPins[i - 1], LOW);
delay(50);
if (numLeds - round - 1 >= 0) {
digitalWrite(ledPins[numLeds - round - 1], LOW);
// Center spread effect: LEDs light from the center outwards and then back
// (Not called in the loop)
void centerSpreadEffect() {
int center = numLeds / 2;
for (int offset = 0; offset < center; offset++) {
digitalWrite(ledPins[center - offset - 1], HIGH);
digitalWrite(ledPins[center + offset], HIGH);
delay(100);
for (int offset = center - 1; offset >= 0; offset--) {
digitalWrite(ledPins[center - offset - 1], LOW);
digitalWrite(ledPins[center + offset], LOW);
delay(100);
