Angle Controller
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you’ll learn how to use the MPU6050 module with the Arduino to control a servo motor.
In this setup, the servo’s angle changes according to the tilt of the MPU6050 sensor. As you tilt the module, the Arduino reads the pitch angle and smoothly adjusts the servo position based on the sensor’s orientation.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Digital Servo Motor
MPU6050 Module
../_images/Angle_Controller_bb.png
Common Connections:
  • Digital Servo Motor
    • Connect to breadboard’s positive power bus.
    • Connect to breadboard’s negative power bus.
    • Connect to 9 on the Arduino.
  • MPU6050
    • SDA: Connect to A4 on the Arduino.
    • SCL: Connect to A5 on the Arduino.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit_MPU6050 , Adafruit_Sensor and install it.
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_Sensor.h>
#include <Servo.h>
#include <math.h>
// Create MPU6050 object
Adafruit_MPU6050 mpu;
// Create Servo object
Servo servo;
const int servoPin = 9;    // Pin for servo signal
const int samples = 25;    // Number of readings to average
// Map a float from one range to another
float mapFloat(float x, float in_min, float in_max, float out_min, float out_max) {
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
// Compute Euclidean distance of two values
float distVal(float a, float b) {
  return sqrt(a * a + b * b);
// Calculate rotation around Y axis (pitch) in degrees
float getYRotation(float ax, float ay, float az) {
  float radians = atan2(ax, distVal(ay, az));
  return -degrees(radians);  // Negate to match original orientation
  Serial.begin(115200);
  Wire.begin();
  if (!mpu.begin()) {
    Serial.println("MPU6050 initialization failed");
    while (1) {
      delay(10);
  Serial.println("MPU6050 initialized");
  // Set sensor ranges and filter
  mpu.setAccelerometerRange(MPU6050_RANGE_8_G);
  mpu.setGyroRange(MPU6050_RANGE_500_DEG);
  mpu.setFilterBandwidth(MPU6050_BAND_21_HZ);
  // Attach servo to pin
  servo.attach(servoPin);
  delay(100);  // Allow sensor to stabilize
  float totalAngle = 0;
  // Take multiple readings and sum their angles
  for (int i = 0; i < samples; i++) {
    sensors_event_t accel, gyro, temp;
    mpu.getEvent(&accel, &gyro, &temp);
    float angleY = getYRotation(accel.acceleration.x,
                                accel.acceleration.y,
                                accel.acceleration.z);
    totalAngle += angleY;
    // Optional small delay (e.g., delay(5);) for even sampling intervals
  // Compute average angle
  float avgAngle = totalAngle / samples;
  // Map from [-90, 90] to [180, 0] for reversed direction
  float servoAngle = mapFloat(avgAngle, -90.0, 90.0, 180.0, 0.0);
  servoAngle = constrain(servoAngle, 0.0, 180.0);
  // Move servo
  servo.write((int)servoAngle);
  // Print debug info
  Serial.print("Avg Y Angle: ");
  Serial.print(avgAngle);
  Serial.print("  ->  Servo Angle: ");
  Serial.println(servoAngle);
  delay(100);  // Update every 100 ms
