Radar Guard 3.0
✅ Share your creations and get real feedback
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, we will learn how to use the Ultrasonic Sensor Module, Digital Servo Motor, and MAX7219 Dot Matrix Module with the Arduino Board to create a radar defense system version 3.0.
When the ultrasonic sensor module detects an object, it will display the object’s range on the MAX7219 Dot Matrix Module.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Ultrasonic Sensor Module |
Digital Servo Motor |
7 |
MAX7219 Dot Matrix Module |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 2 on the Arduino.
Trig: Connect to 4 on the Arduino.
Echo: Connect to 3 on the Arduino.
CLK: Connect to 11 on the Arduino.
CS: Connect to 10 on the Arduino.
DIN: Connect to 12 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for LedControl and install it.
Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
#include <LedControl.h>
#include <Servo.h>
// hardware pins
LedControl lc(12, 11, 10, 4); // DIN=12, CLK=11, CS=10, 4 modules
Servo radarServo;
const int servoPin = 2; // servo control pin
const int trigPin = 4; // HC-SR04 Trig pin
const int echoPin = 3; // HC-SR04 Echo pin
// timing
const unsigned long updateInterval = 20; // ms per step
unsigned long lastUpdate = 0;
int currentAngle = 0;
int increment = 1;
// thresholds for rows 0..7
const int thresholds[8] = { 32, 28, 24, 20, 16, 12, 8, 4 };
Serial.begin(9600);
// init LED matrix
for (int m = 0; m < 4; m++) {
lc.shutdown(m, false);
lc.setIntensity(m, 8);
lc.clearDisplay(m);
// init servo
radarServo.attach(servoPin);
radarServo.write(currentAngle);
// init ultrasonic
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
unsigned long now = millis();
if (now - lastUpdate < updateInterval) return;
lastUpdate = now;
// 1) move servo to currentAngle
// 2) measure distance
float d = getDistance();
Serial.print("Angle: ");
Serial.print(currentAngle);
Serial.print("°, Distance: ");
Serial.print(d);
Serial.println(" cm");
// 3) map angle -> step -> module & col
int step = map(currentAngle, 0, 180, 31, 0);
int module = step / 8;
int col = 7 - (step % 8);
// 4) always light row 0 at (module,col)
lc.setLed(module, 0, col, true);
// then for each deeper threshold light extra rows
for (int r = 1; r < 8; r++) {
if (d <= thresholds[r]) {
lc.setLed(module, r, col, true);
// 5) update angle
currentAngle += increment;
// 6) at each end clear all before reversing
if (currentAngle >= 180) {
currentAngle = 180;
increment = -1;
clearAll();
} else if (currentAngle <= 0) {
currentAngle = 0;
increment = 1;
clearAll();
// perform ultrasonic distance measurement (cm)
float getDistance() {
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
long dur = pulseIn(echoPin, HIGH, 30000);
return dur * 0.034 / 2;
// helper: clear entire display
void clearAll() {
lc.clearDisplay(m);
