LED control 3.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Universal Maker Sensor Kit
Course Introduction
In this lesson, you will use Arduino together with two Ultrasonic Sensor Modules and a row of LEDs to create an automatic directional light-flow effect.
When the left sensor detects an object, the LEDs light up in a forward flowing pattern. When the right sensor is triggered, the LEDs flow in the opposite direction.
Each sensor controls one direction of the animation, allowing the LEDs to respond dynamically based on which side an obstacle is detected.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima
USB Type-C cable
Wires
Several
1kΩ resistor
Several
LED
Several
../_images/LED_Control3.0_bb.png
Common Connections:
  • LED
    • Connect the LEDs cathode to the negative power bus on the breadboard, and the LEDs anode to 1kΩ resistor then to 5 to 10 on the Arduino.
  • Ultrasonic Sensor Module Right
    • Trig: Connect to 11 on the Arduino.
    • Echo: Connect to 12 on the Arduino.
  • Ultrasonic Sensor Module Left
    • Trig: Connect to 3 on the Arduino.
    • Echo: Connect to 4 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// ================= Ultrasonic pins =================
// Left ultrasonic sensor
const int trigLeft  = 3;
const int echoLeft  = 4;
// Right ultrasonic sensor
const int trigRight = 11;
const int echoRight = 12;
// ================= LED pins =================
int ledPins[] = {5, 6, 7, 8, 9, 10};
int ledCount = 6;
// ================= Distance levels (cm) =================
int farLimit  = 15;   // slow
int midLimit  = 10;   // medium
int nearLimit = 5;    // fast
// ================= LED speed =================
int slowDelay = 100;
int midDelay  = 60;
int fastDelay = 30;
  // Set ultrasonic pins
  pinMode(trigLeft, OUTPUT);
  pinMode(echoLeft, INPUT);
  pinMode(trigRight, OUTPUT);
  pinMode(echoRight, INPUT);
  // Set LED pins
  for (int i = 0; i < ledCount; i++) {
    pinMode(ledPins[i], OUTPUT);
  Serial.begin(9600);
  // Read distance from both ultrasonic sensors
  float leftDistance  = readDistance(trigLeft, echoLeft);
  float rightDistance = readDistance(trigRight, echoRight);
  // Get LED speed based on distance
  int leftSpeed  = getSpeedByDistance(leftDistance);
  int rightSpeed = getSpeedByDistance(rightDistance);
  // Left sensor → LEDs flow left to right
  if (leftSpeed > 0) {
    flowForward(leftSpeed);
  // Right sensor → LEDs flow right to left
  if (rightSpeed > 0) {
    flowBackward(rightSpeed);
  delay(80); // short pause between measurements
// ================= Functions =================
// Convert distance to LED speed
int getSpeedByDistance(float d) {
  if (d <= 0) return -1;       // invalid reading
  if (d < nearLimit) return fastDelay;
  if (d < midLimit)  return midDelay;
  if (d < farLimit)  return slowDelay;
  return -1;                  // no trigger
// Measure distance using ultrasonic sensor
float readDistance(int trigPin, int echoPin) {
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  long duration = pulseIn(echoPin, HIGH, 25000);
  if (duration == 0) return -1; // no echo
  return duration / 58.0;       // convert to cm
// LEDs flow from left to right
void flowForward(int d) {
    digitalWrite(ledPins[i], HIGH);
    delay(d);
    if (i > 0) {
      digitalWrite(ledPins[i - 1], LOW);
  digitalWrite(ledPins[ledCount - 1], LOW);
// LEDs flow from right to left
void flowBackward(int d) {
  for (int i = ledCount - 1; i >= 0; i--) {
    delay(d);
    if (i < ledCount - 1) {
      digitalWrite(ledPins[i + 1], LOW);
  digitalWrite(ledPins[0], LOW);
