Lights Off
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you will learn how to use Arduino along with servo motor, buttons, LED, and resistor to create a light play game.
Pressing the button to start.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
220Ω resistor |
Button |
7 |
LED |
8 |
Digital Servo Motor |
Common Connections:
LED
Connect the LED cathode to the negative power bus on the breadboard, and the LED anode to a 1kΩ resistor then to 5 on the Arduino.
Button-ON
Connect to breadboard’s negative power bus.
Connect to 2 on the Arduino.
Button-OFF
Connect to 3 on the Arduino.
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to 9 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 WIFI/Minima) and the correct port before clicking the Upload button.
#include <Servo.h>
// Pins
const int BUTTON_ON_PIN = 2;
const int BUTTON_OFF_PIN = 3;
const int LED_PIN = 5;
const int SERVO_PIN = 9;
// Servo angles
const int SERVO_HOME_ANGLE = 0;
const int SERVO_PRESS_ANGLE = 30;
// Timing
const unsigned long WAIT_BEFORE_PRESS = 2000;
const unsigned long SERVO_PRESS_TIME = 600;
const unsigned long DEBOUNCE_DELAY = 200;
Servo switchServo;
bool lightOn = false;
bool servoTriggered = false;
bool lastButtonOnState = HIGH;
bool lastButtonOffState = HIGH;
unsigned long lightOnTime = 0;
unsigned long lastButtonOnTime = 0;
unsigned long lastButtonOffTime = 0;
pinMode(BUTTON_ON_PIN, INPUT_PULLUP);
pinMode(BUTTON_OFF_PIN, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
switchServo.attach(SERVO_PIN);
switchServo.write(SERVO_HOME_ANGLE);
digitalWrite(LED_PIN, LOW);
handleButtons();
if (lightOn && !servoTriggered) {
if (millis() - lightOnTime >= WAIT_BEFORE_PRESS) {
pressOffButton();
servoTriggered = true;
void handleButtons() {
bool currentButtonOnState = digitalRead(BUTTON_ON_PIN);
bool currentButtonOffState = digitalRead(BUTTON_OFF_PIN);
unsigned long now = millis();
if (lastButtonOnState == HIGH && currentButtonOnState == LOW) {
if (now - lastButtonOnTime > DEBOUNCE_DELAY) {
lightOn = true;
lightOnTime = now;
digitalWrite(LED_PIN, HIGH);
lastButtonOnTime = now;
if (lastButtonOffState == HIGH && currentButtonOffState == LOW) {
if (now - lastButtonOffTime > DEBOUNCE_DELAY) {
lightOn = false;
lastButtonOffTime = now;
lastButtonOnState = currentButtonOnState;
lastButtonOffState = currentButtonOffState;
void pressOffButton() {
switchServo.write(SERVO_PRESS_ANGLE);
delay(SERVO_PRESS_TIME);
if (digitalRead(BUTTON_OFF_PIN) == LOW) {
lightOn = false;
