Speed Detection 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
This Arduino project detects speed using two IR sensors and a servo. When an object passes the first sensor, a timer starts; it stops at the second sensor.
Using the known distance, the system calculates speed and maps it to a servo angle.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Digital Servo Motor |
IR Obstacle Avoidance Sensor Module |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 9 on the Arduino.
IR Obstacle Avoidance Sensor Module Front
OUT: Connect to 2 on the Arduino.
IR Obstacle Avoidance Sensor Module Back
OUT: Connect to 3 on the Arduino.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Servo.h>
#define IR1_PIN 2
#define IR2_PIN 3
#define SERVO_PIN 9
Servo myServo;
unsigned long t1 = 0;
unsigned long t2 = 0;
bool waitingForIR2 = false;
float distance_cm = 10.0; // Distance between IR1 and IR2 in cm
float speed = 0; // Speed in cm/s
Serial.begin(9600);
pinMode(IR1_PIN, INPUT);
pinMode(IR2_PIN, INPUT);
myServo.attach(SERVO_PIN);
// Initialize servo to -90° (corresponds to 180° in servo signal)
myServo.write(180);
delay(500);
// Detect vehicle passing IR1
if (digitalRead(IR1_PIN) == LOW && !waitingForIR2) {
t1 = millis();
waitingForIR2 = true;
Serial.println("IR1 triggered");
delay(50); // Debounce delay
// Detect vehicle passing IR2
if (waitingForIR2 && digitalRead(IR2_PIN) == LOW) {
t2 = millis();
Serial.println("IR2 triggered");
// Calculate speed in cm/s
float timeTaken = (t2 - t1) / 1000.0;
if (timeTaken > 0) {
speed = distance_cm / timeTaken;
Serial.print("Speed: ");
Serial.print(speed);
Serial.println(" cm/s");
// Map speed to servo angle (-90 to +90), max speed = 60 cm/s
int angle = map(constrain(speed, 0, 60), 0, 60, -90, 90);
angle = constrain(angle, -90, 90);
// Convert -90~90 to servo range 0~180 (-90° → 180, +90° → 0)
int servoPos = 90 - angle;
myServo.write(servoPos);
delay(1000); // Display time
// Return to -90° (servo signal 180°)
myServo.write(180);
delay(500);
