RGB Controll
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
Inventor Lab Kit
Arduino Uno R3
Course Introduction
In this lesson, you’ll learn how to use a potentiometer with the Arduino UNO R4 to control an RGB LED.
As you turn the knob, the LED color smoothly transitions through red, yellow, green, and blue, creating a dynamic color blending effect.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 Minima/Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Potentiometer
RGB LED
../_images/RGB_color_bb.png
Common Connections:
  • RGB LED
    • R: Connect to 9 on the Arduino.
    • Y: Connect to 10 on the Arduino.
    • G: Connect to 11 on the Arduino.
  • Potentiometer
    • OUT: Connect to A0 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
// RGB LED pins
const int redPin = 9;
const int greenPin = 10;
const int bluePin = 11;
// Potentiometer pin
const int potPin = A0;
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  Serial.begin(9600);
  // Read potentiometer value (0–1023)
  int potValue = analogRead(potPin);
  Serial.println(potValue);
  // Map the potentiometer value to 0–765 range for color blending
  int range = map(potValue, 0, 1023, 0, 765);
  int r = 0, g = 0, b = 0;
  // Blend RGB colors based on range
  if (range <= 255) {
    r = 255;
    g = range;
    b = 0;
  } else if (range <= 510) {
    r = 510 - range;
    g = 255;
    b = range - 255;
  } else {
    r = 0;
    g = 765 - range;
    b = 255;
  // Set RGB LED color
  analogWrite(redPin, 255 - r);   // Inverted for common cathode
  analogWrite(greenPin, 255 - g);
  analogWrite(bluePin, 255 - b);
  delay(20);
