BestFriend
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this lesson, we will learn how to use an OLED with Arduino to play the “BEST FRIENDS” animation.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
OLED Display Module |
Common Connections:
OLED Display Module
SDA: Connect to SDA on the Arduino.
SCK: Connect to SCL on the Arduino.
GND: Connect to GND on the Arduino.
VCC: Connect to 5V on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit SSD1306 and Adafruit GFX and install it.
The
VideoFrame.his used here. You can click hereVideoFrame_R4.zipto download it.Then place
VideoFrame.hin the same folder as the following code.Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
OLED Animation Player
Arduino UNO R4 WiFi / Minima
Display:
SSD1306 128x64 I2C
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include "VideoFrame.h"
// OLED settings
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define OLED_ADDRESS 0x3C
Adafruit_SSD1306 display(
SCREEN_WIDTH,
SCREEN_HEIGHT,
&Wire,
OLED_RESET
// Animation variables
uint16_t currentFrame = 0;
unsigned long previousFrameTime = 0;
// Setup
Serial.begin(115200);
// UNO R4 standard I2C
Wire.begin();
// Faster I2C
Wire.setClock(400000);
delay(200);
if (!display.begin(
SSD1306_SWITCHCAPVCC,
OLED_ADDRESS
Serial.println(
F("SSD1306 initialization failed!")
while (true) {
delay(100);
Serial.println(
F("SSD1306 initialized.")
Serial.print(
F("Frames: ")
Serial.println(
TOTAL_FRAMES
display.clearDisplay();
display.display();
previousFrameTime = millis();
// Main loop
unsigned long currentTime = millis();
if (
currentTime - previousFrameTime >=
FRAME_DELAY
Use += instead of = currentTime
to keep animation timing more stable.
previousFrameTime += FRAME_DELAY;
// Clear previous image
IMPORTANT:
The source frames use Adafruit GFX
horizontal bitmap format.
So drawBitmap() must be used.
display.drawBitmap(
0,
0,
video_frames[currentFrame],
SCREEN_WIDTH,
SCREEN_HEIGHT,
SSD1306_WHITE
// Send frame to OLED
display.display();
// Next frame
currentFrame++;
if (
currentFrame >= TOTAL_FRAMES
currentFrame = 0;
Recover if playback falls too far behind.
if (
millis() - previousFrameTime >
FRAME_DELAY * 2
