Tetris6.0
Kit purchase
Includes Arduino board
PURCHASE LINK
Elite Explorer Kit
Arduino Uno R4 WiFi
3 in 1 Ultimate Starter Kit
Arduino Uno R4 Minima
Course Introduction
This Arduino project uses an OLED display, two buttons, joystick, and buzzer to play a classic Tetris game with sound effects and joystick-controlled moves.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Joystick Module
OLED Display Module
Button
../_images/tetris6.0_bb.png
Common Connections:
  • OLED Display Module
    • SDA: Connect to SDA on the Arduino.
    • SCK: Connect to SCL on the Arduino.
  • Joystick Module
    • VRY: Connect to A1 on the Arduino.
    • VRX: Connect to A0 on the Arduino.
  • Rotate Button
    • Connect to the breadboard’s negative power bus, and the other end to 6 on the Arduino board.
  • Reset Button
    • Connect to the breadboard’s negative power bus, and the other end to 4 on the Arduino board.
Writing the Code
  • To install the library, use the Arduino Library Manager and search for Adafruit_GFX and Adafruit SSD1306 and install it.
  • Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
  Mini Tetris for Arduino UNO R4
  Compatible boards:
  - Arduino UNO R4 Minima
  - Arduino UNO R4 WiFi
  Hardware:
  - 128x64 SSD1306 I2C OLED
  - Analog joystick
  - Rotate button
  - Reset button
  Controls:
  - Joystick left/right: move
  - Joystick down: soft drop
  - D4 button: rotate
  - D7 button: restart
#include <Arduino.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Pin configuration
const uint8_t JOYSTICK_X_PIN = A0;
const uint8_t JOYSTICK_Y_PIN = A1;
const uint8_t ROTATE_BUTTON_PIN = 4;
const uint8_t RESET_BUTTON_PIN = 6;
// OLED configuration
const uint8_t OLED_ADDRESS = 0x3C;
const int SCREEN_WIDTH = 128;
const int SCREEN_HEIGHT = 64;
const int OLED_RESET = -1;
Adafruit_SSD1306 display(
  SCREEN_WIDTH,
  SCREEN_HEIGHT,
  &Wire,
  OLED_RESET
// Change to 0 or 2 if the screen orientation is reversed.
const uint8_t DISPLAY_ROTATION = 0;
// Tetris board configuration
const int BOARD_COLS = 10;
const int BOARD_ROWS = 13;
// Each game cell is 6 x 4 pixels.
const int CELL_WIDTH = 6;
const int CELL_HEIGHT = 4;
// Board position on the OLED.
const int BOARD_X = 5;
const int BOARD_Y = 5;
// Sidebar position.
const int SIDEBAR_X = 68;
// Input configuration
const int ADC_CENTER = 512;
const int JOYSTICK_DEADZONE = 120;
// Set to true if pushing joystick down gives lower ADC values.
const bool INVERT_JOYSTICK_Y = false;
const unsigned long MOVE_REPEAT_TIME = 150;
const unsigned long DROP_REPEAT_TIME = 80;
const unsigned long BUTTON_DEBOUNCE_TIME = 35;
// Game timing
const unsigned long BASE_DROP_TIME = 600;
const unsigned long MIN_DROP_TIME = 80;
const int LINES_PER_LEVEL = 10;
// Tetromino definitions
const int8_t SHAPES[7][4][4] = {
  // I
    {0, 0, 0, 0},
    {1, 1, 1, 1},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
  // O
    {1, 1, 0, 0},
    {1, 1, 0, 0},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
  // T
    {0, 1, 0, 0},
    {1, 1, 1, 0},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
  // S
    {0, 1, 1, 0},
    {1, 1, 0, 0},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
  // Z
    {1, 1, 0, 0},
    {0, 1, 1, 0},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
  // J
    {1, 0, 0, 0},
    {1, 1, 1, 0},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
  // L
    {0, 0, 1, 0},
    {1, 1, 1, 0},
    {0, 0, 0, 0},
    {0, 0, 0, 0}
const int8_t SHAPE_SIZES[7] = {
  4, 2, 3, 3, 3, 3, 3
// Game structures
struct Piece {
  int8_t shape[4][4];
  int8_t size;
  int8_t x;
  int8_t y;
struct DebouncedButton {
  uint8_t pin;
  bool lastRawState;
  bool stableState;
  unsigned long lastChangeTime;
  void begin(uint8_t buttonPin) {
    pin = buttonPin;
    pinMode(pin, INPUT_PULLUP);
    lastRawState = digitalRead(pin);
    stableState = lastRawState;
    lastChangeTime = millis();
  bool pressed() {
    bool rawState = digitalRead(pin);
    if (rawState != lastRawState) {
      lastRawState = rawState;
    if (
      millis() - lastChangeTime >= BUTTON_DEBOUNCE_TIME
      if (rawState != stableState) {
        stableState = rawState;
        if (stableState == LOW) {
          return true;
    return false;
// Game state
uint8_t board[BOARD_ROWS][BOARD_COLS];
Piece currentPiece;
Piece nextPiece;
int score = 0;
int clearedLines = 0;
int level = 1;
bool gameOver = false;
unsigned long dropInterval = BASE_DROP_TIME;
unsigned long lastGravityTime = 0;
unsigned long lastHorizontalMove = 0;
unsigned long lastSoftDrop = 0;
DebouncedButton rotateButton;
DebouncedButton resetButton;
// Piece generation
void createRandomPiece(Piece &piece) {
  int type = random(0, 7);
  memcpy(
    piece.shape,
    SHAPES[type],
    sizeof(piece.shape)
  piece.size = SHAPE_SIZES[type];
  piece.x = (BOARD_COLS - 4) / 2;
  piece.y = 0;
// Collision detection
bool pieceCollides(
  const Piece &piece,
  int offsetX = 0,
  int offsetY = 0,
  const int8_t rotatedShape[][4] = nullptr
  for (int row = 0; row < 4; row++) {
    for (int column = 0; column < 4; column++) {
      int8_t occupied;
      if (rotatedShape != nullptr) {
        occupied = rotatedShape[row][column];
      } else {
        occupied = piece.shape[row][column];
      if (!occupied) {
        continue;
      int boardX =
        piece.x + column + offsetX;
      int boardY =
        piece.y + row + offsetY;
      if (
        boardX < 0 ||
        boardX >= BOARD_COLS ||
        boardY >= BOARD_ROWS
        return true;
      if (
        boardY >= 0 &&
        board[boardY][boardX]
        return true;
  return false;
// Rotation
void rotateCurrentPiece() {
  int8_t rotated[4][4];
  memset(rotated, 0, sizeof(rotated));
  for (int row = 0; row < currentPiece.size; row++) {
    for (
      int column = 0;
      column < currentPiece.size;
      column++
      rotated[column]
            [currentPiece.size - 1 - row] =
        currentPiece.shape[row][column];
  const int kickOffsets[] = {
    0, 1, -1, 2, -2
  for (int offset : kickOffsets) {
    if (
      !pieceCollides(
        currentPiece,
        offset,
        0,
        rotated
      currentPiece.x += offset;
      memcpy(
        currentPiece.shape,
        rotated,
        sizeof(currentPiece.shape)
      return;
// Line clearing
int clearCompletedLines() {
  int lineCount = 0;
  for (
    int row = BOARD_ROWS - 1;
    row >= 0;
    row--
    bool complete = true;
    for (
      int column = 0;
      column < BOARD_COLS;
      column++
      if (!board[row][column]) {
        complete = false;
        break;
    if (!complete) {
      continue;
    for (
      int moveRow = row;
      moveRow > 0;
      moveRow--
      memcpy(
        board[moveRow],
        board[moveRow - 1],
        sizeof(board[moveRow])
    memset(
      board[0],
      0,
      sizeof(board[0])
    lineCount++;
    row++;
  return lineCount;
// Lock and spawn
void lockCurrentPiece() {
      if (!currentPiece.shape[row][column]) {
        continue;
      int boardX =
        currentPiece.x + column;
      int boardY =
        currentPiece.y + row;
      if (
        boardY >= 0 &&
        boardY < BOARD_ROWS &&
        boardX >= 0 &&
        boardX < BOARD_COLS
        board[boardY][boardX] = 1;
  int linesNow = clearCompletedLines();
  const int scoreTable[] = {
    0, 100, 300, 500, 800
  score += scoreTable[linesNow] * level;
  clearedLines += linesNow;
  level =
    clearedLines / LINES_PER_LEVEL + 1;
  long newDropTime =
    (long)BASE_DROP_TIME -
    (long)(level - 1) * 50L;
  if (newDropTime < MIN_DROP_TIME) {
    newDropTime = MIN_DROP_TIME;
  dropInterval =
    (unsigned long)newDropTime;
  currentPiece = nextPiece;
  createRandomPiece(nextPiece);
  if (pieceCollides(currentPiece)) {
    gameOver = true;
// Game initialization
void startNewGame() {
  memset(board, 0, sizeof(board));
  score = 0;
  clearedLines = 0;
  level = 1;
  gameOver = false;
  lastGravityTime = millis();
  lastSoftDrop = 0;
  randomSeed(
    analogRead(A2) ^
    micros()
  createRandomPiece(currentPiece);
// Input processing
void processJoystick() {
  if (gameOver) {
    return;
  unsigned long currentTime = millis();
  int joystickX =
    analogRead(JOYSTICK_X_PIN);
  int joystickY =
    analogRead(JOYSTICK_Y_PIN);
  int horizontalOffset =
    joystickX - ADC_CENTER;
  int verticalOffset =
    joystickY - ADC_CENTER;
  if (INVERT_JOYSTICK_Y) {
    verticalOffset = -verticalOffset;
  // Horizontal movement
  int moveDirection = 0;
  if (
    horizontalOffset <
    -JOYSTICK_DEADZONE
    moveDirection = -1;
  } else if (
    horizontalOffset >
    JOYSTICK_DEADZONE
    moveDirection = 1;
  if (moveDirection != 0) {
    if (
      lastHorizontalMove == 0 ||
      currentTime - lastHorizontalMove >=
        MOVE_REPEAT_TIME
      if (
        !pieceCollides(
          currentPiece,
          moveDirection,
          0
        currentPiece.x += moveDirection;
      lastHorizontalMove = currentTime;
  } else {
  // Soft drop
  if (
    verticalOffset >
    JOYSTICK_DEADZONE
    if (
      lastSoftDrop == 0 ||
      currentTime - lastSoftDrop >=
        DROP_REPEAT_TIME
      if (
        !pieceCollides(
          currentPiece,
          0,
        currentPiece.y++;
        score++;
      } else {
        lockCurrentPiece();
      lastSoftDrop = currentTime;
      lastGravityTime = currentTime;
  } else {
    lastSoftDrop = 0;
void processButtons() {
  if (rotateButton.pressed()) {
    if (!gameOver) {
      rotateCurrentPiece();
  if (resetButton.pressed()) {
    startNewGame();
// Gravity
void updateGravity() {
  if (gameOver) {
    return;
  if (
    currentTime - lastGravityTime <
    dropInterval
    return;
  if (
    !pieceCollides(
      currentPiece,
      0,
    currentPiece.y++;
  } else {
    lockCurrentPiece();
// OLED drawing
void drawBoardBorder() {
  display.drawRect(
    0,
    0,
    SCREEN_WIDTH,
    SCREEN_HEIGHT,
    SSD1306_WHITE
  display.drawRect(
    BOARD_X - 1,
    BOARD_Y - 1,
    CELL_WIDTH * BOARD_COLS + 2,
    CELL_HEIGHT * BOARD_ROWS + 2,
    SSD1306_WHITE
void drawFixedBlocks() {
  for (int row = 0; row < BOARD_ROWS; row++) {
    for (
      int column = 0;
      column++
        continue;
      display.fillRect(
        BOARD_X +
          column * CELL_WIDTH,
        BOARD_Y +
          row * CELL_HEIGHT,
        CELL_WIDTH - 1,
        CELL_HEIGHT - 1,
        SSD1306_WHITE
void drawCurrentPiece() {
        continue;
      int drawY =
      if (drawY < 0) {
        continue;
      display.fillRect(
        BOARD_X +
          (currentPiece.x + column) *
          CELL_WIDTH,
        BOARD_Y +
          drawY * CELL_HEIGHT,
        CELL_WIDTH - 1,
        CELL_HEIGHT - 1,
        SSD1306_WHITE
void drawNextPiece() {
  const int previewCellSize = 4;
  int previewX =
    SIDEBAR_X + 4;
  int previewY = 13;
  for (
    int row = 0;
    row < nextPiece.size;
    row++
    for (
      int column = 0;
      column < nextPiece.size;
      column++
      if (!nextPiece.shape[row][column]) {
        continue;
      display.fillRect(
        previewX +
          column * previewCellSize,
        previewY +
          row * previewCellSize,
        previewCellSize - 1,
        SSD1306_WHITE
void drawSidebar() {
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(
    SIDEBAR_X,
  display.print("NEXT");
  display.drawRect(
    SIDEBAR_X - 2,
    3,
    28,
    25,
    SSD1306_WHITE
  drawNextPiece();
  display.setCursor(
    SIDEBAR_X,
    32
  display.print("SCORE");
  display.setCursor(
    SIDEBAR_X,
    41
  display.print(score);
  display.setCursor(
    SIDEBAR_X,
    51
  display.print("LV:");
  display.print(level);
void drawGameScreen() {
  display.clearDisplay();
  drawBoardBorder();
  drawFixedBlocks();
  drawCurrentPiece();
  drawSidebar();
  display.display();
// Game over screen
void drawGameOverScreen() {
  display.drawRect(
    0,
    0,
    SCREEN_WIDTH,
    SCREEN_HEIGHT,
    SSD1306_WHITE
    SSD1306_WHITE
  display.setCursor(
    35,
    10
  display.print("GAME OVER");
  display.drawLine(
    8,
    22,
    119,
    22,
    SSD1306_WHITE
  display.setCursor(
    28,
    29
  display.print("SCORE: ");
  display.setCursor(
    20,
    43
  display.print("PRESS RESET");
  display.setCursor(
    30,
    53
  display.print("TO RESTART");
  display.display();
// Setup
  Serial.begin(115200);
  rotateButton.begin(
    ROTATE_BUTTON_PIN
  resetButton.begin(
    RESET_BUTTON_PIN
  analogReadResolution(10);
  Wire.begin();
  Wire.setClock(100000);
  delay(300);
  if (
    !display.begin(
      SSD1306_SWITCHCAPVCC,
      OLED_ADDRESS
    Serial.println(
      "SSD1306 OLED initialization failed."
    while (true) {
      delay(100);
  display.setRotation(
    DISPLAY_ROTATION
    SSD1306_WHITE
  display.setCursor(
    25,
    20
  display.print("MINI TETRIS");
  display.setCursor(
    20,
    36
  display.print("ARDUINO UNO R4");
  display.display();
  delay(1200);
  startNewGame();
// Main loop
  processButtons();
  processJoystick();
  updateGravity();
  if (gameOver) {
    drawGameOverScreen();
  } else {
    drawGameScreen();
  delay(10);
