Color Memory 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, you’ll use four LCDs, four buttons, and a passive buzzer with the Arduino R4 UNO to create a color memory game.
At the start of the game, an LED lights up at random. The player must press the corresponding button to proceed. A wrong input ends the game.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima |
USB Type-C cable |
Breadboard |
Wires |
Several |
Passive Buzzer |
Button |
7 |
LED |
8 |
1kΩ resistor |
Common Connections:
LEDS
White: Connect the LED anode to 10 on the Arduino, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Blue: Connect the LED anode to 8 on the Arduino, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Green: Connect the LED anode to 6 on the Arduino, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Yellow: Connect the LED anode to 4**on the Arduino , and the **cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Red: Connect the LED anode to 2 on the Arduino, and the cathode to a 1kΩ resistor, then to the negative power bus on the breadboard.
Passive Buzzer
+: Connect to 12 on the Arduino.
-: Connect to breadboard’s negative power bus.
Buttons
White Button: Connect to the White LED’s cathode on the breadboard, and the other end to 11 on the Arduino board.
Blue Button: Connect to the Blue LED’s cathode on the breadboard, and the other end to 9 on the Arduino board.
Green Butto: Connect to the Green LED’s cathode on the breadboard, and the other end to 7 on the Arduino board.
Yellow Butto: Connect to the Yellow LED’s cathode on the breadboard, and the other end to 5 on the Arduino board.
Red Butto: Connect to the Red LED’s cathode on the breadboard, and the other end to 3 on the Arduino board.
Writing the Code
Don’t forget to select the board(Arduino UNO R4 Minima) and the correct port before clicking the Upload button.
// ==== LED and Button pin definitions ====
const int redLED = 2; // Red LED pin
const int yellowLED = 4; // Yellow LED pin
const int greenLED = 6; // Green LED pin
const int blueLED = 8; // Blue LED pin
const int whiteLED = 10; // White LED pin (new)
const int redButton = 3; // Red button pin
const int yellowButton = 5; // Yellow button pin
const int greenButton = 7; // Green button pin
const int blueButton = 9; // Blue button pin
const int whiteButton = 11; // White button pin (new)
const int buzzer = 12; // Buzzer pin
// ==== Game data ====
int sequence[100]; // Store the game sequence (LED colors)
int playerInput[100]; // Store what the player presses
int level = 0; // Current length of the sequence
bool gameOver = false; // Flag to check if the game is over
// Set LED pins as output
pinMode(redLED, OUTPUT);
pinMode(yellowLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(blueLED, OUTPUT);
pinMode(whiteLED, OUTPUT);
// Set button pins as input with pull-up resistors
pinMode(redButton, INPUT_PULLUP);
pinMode(yellowButton, INPUT_PULLUP);
pinMode(greenButton, INPUT_PULLUP);
pinMode(blueButton, INPUT_PULLUP);
pinMode(whiteButton, INPUT_PULLUP);
pinMode(buzzer, OUTPUT);
Serial.begin(9600); // For debugging if needed
// Start the game
startGame();
if (!gameOver) {
// Show the sequence to the player
playSequence();
// Wait for player's input
if (!getPlayerInput()) {
// If wrong, end the game
endGame();
} else {
delay(500); // Small pause before next round
} else {
// Restart the game after short delay
delay(1500);
startGame();
// Reset and start a new game
void startGame() {
level = 0; // Reset sequence length
gameOver = false;
// Flash all LEDs and play a tone to show game start
allLEDsOn();
tone(buzzer, 1000, 500);
delay(500);
allLEDsOff();
// Make random numbers different each time
randomSeed(analogRead(A0));
delay(500);
// Add 2 new random colors to the sequence and replay all
void playSequence() {
sequence[level] = random(1, 6); // First new color (1–5)
sequence[level + 1] = random(1, 6); // Second new color
level += 2; // Increase sequence length by 2
// Show the sequence step by step
for (int i = 0; i < level; i++) {
lightUpLED(sequence[i]);
delay(300);
// Read the player's input and check if correct
bool getPlayerInput() {
bool inputReceived = false;
// Wait until a button is pressed
while (!inputReceived) {
if (digitalRead(redButton) == LOW) {
playerInput[i] = 1;
lightUpLED(1);
inputReceived = true;
} else if (digitalRead(yellowButton) == LOW) {
playerInput[i] = 2;
lightUpLED(2);
} else if (digitalRead(greenButton) == LOW) {
playerInput[i] = 3;
lightUpLED(3);
} else if (digitalRead(blueButton) == LOW) {
playerInput[i] = 4;
lightUpLED(4);
} else if (digitalRead(whiteButton) == LOW) {
playerInput[i] = 5;
lightUpLED(5);
// Check if player's input matches the sequence
if (playerInput[i] != sequence[i]) {
return false; // Wrong input
delay(200); // Small pause before next input
return true; // All correct
// Show "game over" animation
void endGame() {
gameOver = true;
for (int i = 0; i < 5; i++) {
allLEDsOn();
tone(buzzer, 1000, 200);
delay(200);
allLEDsOff();
delay(200);
// Turn on one LED and play its tone
void lightUpLED(int color) {
switch (color) {
case 1: digitalWrite(redLED, HIGH); tone(buzzer, 500, 300); break;
case 2: digitalWrite(yellowLED, HIGH); tone(buzzer, 600, 300); break;
case 3: digitalWrite(greenLED, HIGH); tone(buzzer, 700, 300); break;
case 4: digitalWrite(blueLED, HIGH); tone(buzzer, 800, 300); break;
case 5: digitalWrite(whiteLED, HIGH); tone(buzzer, 900, 300); break;
delay(300);
noTone(buzzer); // Stop the sound
allLEDsOff(); // Turn off all LEDs
// Helper: turn on all LEDs
void allLEDsOn() {
// Helper: turn off all LEDs
void allLEDsOff() {
digitalWrite(redLED, LOW);
digitalWrite(yellowLED, LOW);
digitalWrite(greenLED, LOW);
digitalWrite(blueLED, LOW);
digitalWrite(whiteLED, LOW);
