Basketball Game 2.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Ultimate Sensor Kit |
Arduino Uno R4 Minima |
Universal Maker Sensor Kit |
Course Introduction
In this lesson, we will learn how to use the Ultrasonic Sensor Module, a 4-digit display, and a buzzer with the Arduino Board to build an automatic scoring system.
When an object quickly passes within the detection range, the system registers a score, updates the display, and plays a short sound.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
4-Digit Segment Display Module |
Ultrasonic Sensor Module |
7 |
Buzzer Modudle |
Common Connections:
Trig: Connect to 3 on the Arduino.
Echo: Connect to 2 on the Arduino.
CLK: Connect to 9 on the Arduino.
DIO: Connect to 8 on the Arduino.
Buzzer Module
I/0: Connect to 4 on the Arduino.
+: Connect to breadboard’s red power bus.
-: Connect to breadboard’s negative power bus.
Writing the Code
To install the library, use the Arduino Library Manager and search for TM1637Display and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <TM1637Display.h>
// TM1637 pins
const int CLK_PIN = 9;
const int DIO_PIN = 8;
// Ultrasonic sensor pins
const int TRIG_PIN = 3;
const int ECHO_PIN = 2;
// Buzzer pin
const int BUZZER_PIN = 4;
// Create display object
TM1637Display display(CLK_PIN, DIO_PIN);
// Score value
int score = 0;
// Detection settings
const float DETECT_DISTANCE = 10.0; // cm
const unsigned long cooldownTime = 800; // ms
const unsigned long detectHoldTime = 120; // ms
bool ballDetected = false;
unsigned long detectHoldStart = 0;
unsigned long lastScoreTime = 0;
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(BUZZER_PIN, OUTPUT);
display.setBrightness(7);
display.showNumberDec(score, true);
// Get distance in cm
float getDistanceCM() {
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
long duration = pulseIn(ECHO_PIN, HIGH, 12000); // shorter timeout for faster response
if (duration == 0) {
return 999.0;
float distance = duration * 0.0343 / 2.0;
return distance;
// Read multiple times quickly and use the minimum value
float getFastDistanceCM() {
float minDistance = 999.0;
for (int i = 0; i < 3; i++) {
float d = getDistanceCM();
if (d < minDistance) {
minDistance = d;
delayMicroseconds(300);
return minDistance;
// Play a short goal sound
void playGoalBeep() {
tone(BUZZER_PIN, 2000, 120);
float distance = getFastDistanceCM();
bool currentDetected = (distance <= DETECT_DISTANCE);
unsigned long currentMillis = millis();
if (currentDetected) {
detectHoldStart = currentMillis;
if (!ballDetected && (currentMillis - lastScoreTime > cooldownTime)) {
ballDetected = true;
score++;
if (score > 9999) {
score = 9999;
playGoalBeep();
lastScoreTime = currentMillis;
} else {
if (ballDetected && (currentMillis - detectHoldStart > detectHoldTime)) {
