Gas Leak Monitor 3.0
Kit purchase
../_images/umsk_kit.png
Includes Arduino board
PURCHASE LINK
Ultimate Sensor Kit
Arduino Uno R4 Minima
Universal Maker Sensor Kit
Course Introduction
This Arduino project uses an MQ-2 gas sensor, Traffic Light LED Module, and a buzzer to detect gas concentration in real time.
SN
COMPONENT INTRODUCTION
QUANTITY
PURCHASE LINK
Arduino UNO R4 WIFI
USB Type-C cable
Wires
Several
Buzzer Modudle
Traffic Light LED
MQ-2 Gas Sensor Module
../_images/Gas_Monitor3.0_bb.png
Common Connections:
  • MQ-2 Gas Sensor Module
    • A0: Connect to A0 on the Arduino.
  • Buzzer Modudle
    • I/O: Connect to 2 on the Arduino.
  • Traffic light LED
    • R: Connect to 3 on the Arduino.
    • Y: Connect to 4 on the Arduino.
    • G: Connect to 5 on the Arduino.
Writing the Code
  • Don’t forget to select the board(Arduino UNO R4 WIFI) and the correct port before clicking the Upload button.
// -------- Pin definitions --------
#define PIN_SMOKE  A0   // MQ-2 smoke sensor
#define PIN_BUZZER 2    // Buzzer
#define PIN_R      3    // Red LED
#define PIN_Y      4    // Yellow LED
#define PIN_G      5    // Green LED
// -------- Thresholds --------
#define SAFE_TH 100     // Safe level
#define ALERT_TH 300    // Alarm level (changed to 300)
// -------- State definition --------
enum Level {
  LV_SAFE,
  LV_WARN,
  LV_ALERT
Level currentLevel = LV_SAFE;
Level lastLevel = LV_SAFE;
// -------- Setup --------
  pinMode(PIN_BUZZER, OUTPUT);
  pinMode(PIN_R, OUTPUT);
  pinMode(PIN_Y, OUTPUT);
  pinMode(PIN_G, OUTPUT);
  Serial.begin(9600);   // Open serial monitor
// -------- Main loop --------
  int smokeValue = analogRead(PIN_SMOKE);   // Read smoke value
  currentLevel = decideLevel(smokeValue);   // Decide current level
  // Beep once when level changes
  if (currentLevel != lastLevel) {
    immediateBeep(currentLevel);
    lastLevel = currentLevel;
  serviceLevel(currentLevel);               // Handle LEDs and buzzer
  Serial.print("Smoke value: ");
  Serial.println(smokeValue);
// -------- Decide smoke level --------
Level decideLevel(int value) {
  if (value < SAFE_TH) return LV_SAFE;
  if (value < ALERT_TH) return LV_WARN;
  return LV_ALERT;
// -------- Beep on level change --------
void immediateBeep(Level lv) {
  if (lv == LV_WARN) {
    tone(PIN_BUZZER, 1200, 80);   // Short warning beep
  } else if (lv == LV_ALERT) {
    tone(PIN_BUZZER, 2000, 150);  // Strong alarm beep
// -------- Handle current level --------
void serviceLevel(Level lv) {
  unsigned long now = millis();
  switch (lv) {
    case LV_SAFE:
      digitalWrite(PIN_G, HIGH);  // Green on
      digitalWrite(PIN_Y, LOW);
      digitalWrite(PIN_R, LOW);
      noTone(PIN_BUZZER);
      break;
    case LV_WARN:
      warnService(now);
      break;
    case LV_ALERT:
      alertService(now);
      break;
// -------- WARN mode --------
void warnService(unsigned long now) {
  const unsigned long period = 1000; // 1 second cycle
  unsigned long phase = now % period;
  digitalWrite(PIN_G, LOW);
  // Yellow LED slow blink
  if (phase < 700) {
    digitalWrite(PIN_Y, HIGH);
  } else {
  // Short beep at start of cycle
  if (phase < 80) {
    tone(PIN_BUZZER, 1200);
  } else {
    noTone(PIN_BUZZER);
// -------- ALERT mode --------
void alertService(unsigned long now) {
  const unsigned long period = 250; // Fast blink
  if (phase < 120) {
    digitalWrite(PIN_R, HIGH);     // Red LED on
    tone(PIN_BUZZER, 2000);        // Alarm sound
  } else {
    noTone(PIN_BUZZER);
