PRS Machine 3.0
Kit purchase
Includes Arduino board |
PURCHASE LINK |
Elite Explorer Kit |
Arduino Uno R4 WiFi |
3 in 1 Ultimate Starter Kit |
Arduino Uno R4 Minima |
Course Introduction
In this project, you will use an Arduino board, a servo motor, OLED screen, Active Buzzer, and an Ultrasonic Sensor Module to build a PRS machine3.0.
SN |
COMPONENT INTRODUCTION |
QUANTITY |
PURCHASE LINK |
Arduino UNO R4 Minima/Arduino UNO R4 WIFI |
USB Type-C cable |
Breadboard |
Wires |
Several |
Ultrasonic Sensor Module |
OLED Display Module |
7 |
Active Buzzer |
8 |
Digital Servo Motor |
Common Connections:
Digital Servo Motor
Connect to breadboard’s positive power bus.
Connect to breadboard’s negative power bus.
Connect to 3 on the Arduino.
Active Buzzer
+: Connect to 4 on the Arduino.
-: Connect to breadboard’s negative power bus.
Ultrasonic Sensor Module Front
Trig: Connect to 10 on the Arduino.
Echo: Connect to 11 on the Arduino.
OLED Display Module
SDA: Connect to A4 on the Arduino.
SCK: Connect to A5 on the Arduino.
Writing the Code
To install the library, use the Arduino Library Manager and search for Adafruit_GFX and Adafruit SSD1306 and install it.
Don’t forget to select the board(Arduino UNO R4 Minima/WIFI) and the correct port before clicking the Upload button.
#include <Wire.h>
#include <Servo.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// OLED screen settings
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(
SCREEN_WIDTH,
SCREEN_HEIGHT,
&Wire,
OLED_RESET
// Ultrasonic sensor pins
const int trigPin = 10;
const int echoPin = 11;
// Servo and active buzzer pins
const int servoPin = 3;
const int buzzerPin = 4;
// Distance settings in centimeters
const int triggerDistance = 8;
const int resetDistance = 10;
Servo gameServo;
// Prevent the game from triggering repeatedly
// while your hand is still close to the sensor.
bool hasPlayed = false;
// Variables for the servo's idle shaking motion
int shakePos = 60;
bool movingRight = true;
// Prevent unnecessary OLED refreshes in idle mode
bool idleFaceShown = false;
Serial.begin(9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(buzzerPin, OUTPUT);
gameServo.attach(servoPin);
gameServo.write(90);
// Use noise from an analog pin to make random results less predictable.
randomSeed(analogRead(A0));
// Start the OLED display.
if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println("OLED not found. Check the wiring and I2C address.");
while (true);
drawIdleFace();
float distance = readDistance();
Serial.print("Distance: ");
Serial.print(distance);
Serial.println(" cm");
// Start a new round when your hand is closer than triggerDistance.
if (distance > 0 && distance < triggerDistance && !hasPlayed) {
playGame();
hasPlayed = true;
// Reset the game when your hand moves away.
// The small gap between triggerDistance and resetDistance helps reduce false triggers.
if (distance >= resetDistance || distance == -1) {
hasPlayed = false;
// While waiting, move the servo back and forth and show the idle face.
if (!hasPlayed) {
shakeAnimation();
if (!idleFaceShown) {
drawIdleFace();
idleFaceShown = true;
delay(30);
float readDistance() {
// Send a short pulse to trigger the ultrasonic sensor.
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Measure how long it takes for the echo signal to return.
// The timeout prevents the program from waiting too long.
long duration = pulseIn(echoPin, HIGH, 30000);
// If no echo is received, return -1 as an invalid reading.
if (duration == 0) {
return -1;
// Convert travel time to distance in centimeters.
return duration / 58.0;
void shakeAnimation() {
// Move the servo from 60 degrees to 120 degrees, then back again.
if (movingRight) {
shakePos += 3;
if (shakePos >= 120) {
movingRight = false;
} else {
shakePos -= 3;
if (shakePos <= 60) {
movingRight = true;
gameServo.write(shakePos);
void playGame() {
// Randomly choose Rock, Paper, or Scissors.
int gameResult = random(0, 3);
// Randomly choose a result face.
// 1 = Happy, 2 = Angry, 3 = Surprised
// The idle face is only used while waiting.
int faceResult = random(1, 4);
if (gameResult == 0) {
gameServo.write(0);
Serial.println("ROCK");
} else if (gameResult == 1) {
Serial.println("PAPER");
} else {
gameServo.write(180);
Serial.println("SCISSORS");
if (faceResult == 1) {
drawHappyFace();
Serial.println("Face: Happy");
} else if (faceResult == 2) {
drawAngryFace();
Serial.println("Face: Angry");
} else {
drawSurprisedFace();
Serial.println("Face: Surprised");
playResultSound();
// Keep the result on the screen briefly before returning to idle mode.
delay(500);
void playResultSound() {
// This code is for an active buzzer.
// If you are using a passive buzzer, use tone() instead.
digitalWrite(buzzerPin, HIGH);
delay(120);
digitalWrite(buzzerPin, LOW);
delay(80);
delay(120);
void drawIdleFace() {
display.clearDisplay();
// Calm eyes
display.fillRoundRect(20, 18, 28, 14, 6, SSD1306_WHITE);
display.fillRoundRect(80, 18, 28, 14, 6, SSD1306_WHITE);
// Small smile
display.drawPixel(50, 48, SSD1306_WHITE);
display.drawPixel(51, 49, SSD1306_WHITE);
display.fillRoundRect(52, 50, 24, 4, 2, SSD1306_WHITE);
display.drawPixel(77, 49, SSD1306_WHITE);
display.drawPixel(78, 48, SSD1306_WHITE);
display.display();
void drawHappyFace() {
// Smiling eyes
display.fillRoundRect(18, 18, 32, 8, 4, SSD1306_WHITE);
display.fillRoundRect(78, 18, 32, 8, 4, SSD1306_WHITE);
// Big smile
display.fillRoundRect(40, 40, 48, 20, 10, SSD1306_WHITE);
display.fillRoundRect(45, 40, 38, 10, 5, SSD1306_BLACK);
display.display();
void drawAngryFace() {
// Slanted eyebrows
display.fillTriangle(14, 14, 50, 14, 50, 24, SSD1306_WHITE);
display.fillTriangle(78, 14, 114, 14, 78, 24, SSD1306_WHITE);
// Narrow eyes
display.fillRoundRect(18, 24, 30, 12, 4, SSD1306_WHITE);
display.fillRoundRect(80, 24, 30, 12, 4, SSD1306_WHITE);
// Flat mouth
display.fillRoundRect(44, 48, 40, 8, 3, SSD1306_WHITE);
display.display();
void drawSurprisedFace() {
// Wide eyes with small pupils
display.fillRoundRect(18, 10, 32, 26, 8, SSD1306_WHITE);
display.fillCircle(34, 23, 3, SSD1306_BLACK);
display.fillRoundRect(78, 10, 32, 26, 8, SSD1306_WHITE);
display.fillCircle(94, 23, 3, SSD1306_BLACK);
// Open mouth
display.fillRoundRect(56, 38, 16, 22, 8, SSD1306_WHITE);
display.fillRoundRect(60, 42, 8, 14, 4, SSD1306_BLACK);
display.display();
